    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 64.4k Views 5 Watching
      sdetweil @dave_
      @dave_ something is using the port again
      do this again
      sudo netstat -a -p | grep 1900
      D S 2 Replies Last reply Reply Quote 0
        dave_ @sdetweil
        @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
        No response
          @sdetweil in config.js add
          disabled: true,
          to the MMM_AlexaControl module def
                module: 'MMM-AlexaControl',
                disabled: true,          /// add this line
                 position: whatever,
                config:{
          and restart MM, then in another window to the netstat -a -p command again
            it is hard to help if you don’t respond
              dave_ @sdetweil
              @sdetweil sorry so i just did what u said and still the same like last time
                sdetweil @dave_
                @dave_ no response?
                show me MM messages
                  dave_ @sdetweil
                  @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                    sdetweil @dave_
                    @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                      dave_ @sdetweil
                      @sdetweil https://photos.app.goo.gl/33wVwMbpT135Ng8FA
                      There u go
                        sdetweil @dave_
                        @dave_ but you were supposed to have AlexaControl disabled… but do not
                        please post your config.js (in code block please)
                          dave_ @sdetweil
                          @sdetweil with that disabled it doesn’t seem to work
                            sdetweil @dave_
                            @dave_ it won’t work, we are debugging… trying to find what process has port 1900 , which alexacontrol needs, but was blocked from using…
                              dave_ @sdetweil
                              @sdetweil so the alexa module is disabled and again like before when i do that sudo netstat command nothing shows up
                                sdetweil @dave_
                                @dave_ so, something doesn’t make sense… please show me your config.js
                                  dave_ @sdetweil
                                    sdetweil @dave_
                                    @dave_ weird… ok, re-enable AlexaControl (change to disabled: false, ) then restart MM and show me the messages again
                                      dave_ @sdetweil
                                      @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
                                        sdetweil @dave_
                                        @dave_ and the MM messages? yes, electron should be using 1900 now for alexacontrol
                                          dave_ @sdetweil
                                          @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
                                            sdetweil @dave_
                                            @dave_ ok, as expected… the extra image u posted this morning was from some other time
                                            now, if you do alexa discover devices (phone app is more (bottom right), other, discover devices)
                                            • 4 / 5
