    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.1k Views 5 Watching
      sdetweil @dave_
      @dave_ but you were supposed to have AlexaControl disabled… but do not
      please post your config.js (in code block please)
        dave_ @sdetweil
        @sdetweil with that disabled it doesn’t seem to work
          sdetweil @dave_
          @dave_ it won’t work, we are debugging… trying to find what process has port 1900 , which alexacontrol needs, but was blocked from using…
            dave_ @sdetweil
            @sdetweil so the alexa module is disabled and again like before when i do that sudo netstat command nothing shows up
              sdetweil @dave_
              @dave_ so, something doesn’t make sense… please show me your config.js
                dave_ @sdetweil
                  sdetweil @dave_
                  @dave_ weird… ok, re-enable AlexaControl (change to disabled: false, ) then restart MM and show me the messages again
                    dave_ @sdetweil
                    @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
                      sdetweil @dave_
                      @dave_ and the MM messages? yes, electron should be using 1900 now for alexacontrol
                        dave_ @sdetweil
                        @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
                          sdetweil @dave_
                          @dave_ ok, as expected… the extra image u posted this morning was from some other time
                          now, if you do alexa discover devices (phone app is more (bottom right), other, discover devices)
                            dave_ @sdetweil
                            @sdetweil tried that still no luck
                              sdetweil @dave_
                              @dave_ ok, need to edit a file to turn on some debugging
                              nano ~/MagicMirror/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js
                              change lines 92-94, the console.log lines below
                              change from
                              	udpServer.on('message', (msg, rinfo) => {
                              		//debug(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                              		//console.log('Search request from ' + util.inspect(rinfo));
                              		//console.log(getMask(rinfo.address, '255.255.255.0'));
                              to
                              		console.log(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                                dave_ @sdetweil
                                @sdetweil my internet went of for a bit I’ll do this asap and let you know!
                                  sdetweil @dave_
                                  @dave_ I also added another line of debug
                                  let response = function(ipaddr) {
                                  	let deviceresp = [];
                                  	let responses = [];
                                  	for(let i = 0; i < = devices.length - 1; i++) {
                                  		console.log('responding for port='+devices[i].port)   // this line
                                  and I see this output from the MM console , from alexa discover devices
                                  [2020-08-05 11:31:33.543] [LOG]    << server got: M-SEARCH * HTTP/1.1
                                  HOST: 239.255.255.250:1900
                                  MAN: "ssdp:discover"
                                  MX: 1
                                  ST: urn:dial-multiscreen-org:service:dial:1
                                  USER-AGENT: Chromium/78.0.3904.108 Linux
                                   from 192.168.2.126:57706 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:93 Socket.<anonymous>)
                                  [2020-08-05 11:31:33.545] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                                  [2020-08-05 11:31:33.548] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                                  [2020-08-05 11:31:33.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:33.552] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:33.553] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:33.553] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:33.553] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:33.553] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  (electron:23027): GLib-GIO-CRITICAL **: 11:31:34.172: g_dbus_proxy_new: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                                  [2020-08-05 11:31:34.549] [LOG]    << server got: M-SEARCH * HTTP/1.1
                                  MX: 1
                                  [2020-08-05 11:31:34.549] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                                  [2020-08-05 11:31:34.549] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                                  [2020-08-05 11:31:34.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:34.551] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:34.551] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:34.551] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:34.551] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                  [2020-08-05 11:31:34.552] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                    Michael Schw.
                                    Hey…
                                    I have the same Issue and i will do every step i found here tomorrow.
                                    I tried everything i found on the Internet but i still couldnt make it work.
                                    You have any new knowledge here? I even heard somewhere that the fauxmo code wont work anymore because Alexa cant find the emulated Wemo Devices anymore. Btw Alexa Controll starts at port 11000 but when i set it to 1900 it still doesnt work.
                                    I am currently at the step with disabling Spotify which didnt solve my Problem. So tomorrow i will try to make my Config.js file readable (because it looks terrible at the moment) and then i will post it here.
                                    All i wanna do is to toggle my Display with Alexa…i dont need to switch Pages or hide modules. I just wanna turn it on and off. I found every Solution for every Problem i had myself except for this Problem.
                                      sdetweil @Michael Schw.
                                      @Michael-Schw I just added another system the other day without any issue.
                                      I do have an original echo, a number of echo dots and one echo show.
                                      but did the discovery from the Alexa app on my phone.
                                        Michael Schw. @sdetweil
                                        @sdetweil i tried it with the app on my fire tablet, the echo plus 2nd gen and the echo dot 3rd gen. The first gen echos are still working but the newer ones dont wanna work. So maybe we can figure something out or plan b would be a sonoff switch for the tv display . But maybe there is a way without the switch. Witch gen are your echos?
                                          @Michael-Schw my echo is a gen 1, and dots are gen 2.
                                          do u see the messages like I listed at mm startup? (from 5th post to this topic) also, would be startPort:19000 not 1900.
                                          port 1900 is hard coded to the ssdp discovery port, used by Alexa to find devices
                                          if u see the messages, and add the debugging from above, do u see the discovery request?
                                          show me the mm startup.messages
                                            Michael Schw.
                                            • 4 / 5
