    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      dave_ @sdetweil
      @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
        sdetweil @dave_
        @dave_ and the MM messages? yes, electron should be using 1900 now for alexacontrol
        D 1 Reply Last reply
          dave_ @sdetweil
          @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
            sdetweil @dave_
            @dave_ ok, as expected… the extra image u posted this morning was from some other time
            now, if you do alexa discover devices (phone app is more (bottom right), other, discover devices)
              dave_ @sdetweil
              @sdetweil tried that still no luck
                sdetweil @dave_
                @dave_ ok, need to edit a file to turn on some debugging
                nano ~/MagicMirror/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js
                change lines 92-94, the console.log lines below
                change from
                	udpServer.on('message', (msg, rinfo) => {
                		//debug(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                		//console.log('Search request from ' + util.inspect(rinfo));
                		//console.log(getMask(rinfo.address, '255.255.255.0'));
                to
                		console.log(`<< server got: ${msg} from ${rinfo.address}:${rinfo.port}`);
                  dave_ @sdetweil
                  @sdetweil my internet went of for a bit I’ll do this asap and let you know!
                    sdetweil @dave_
                    @dave_ I also added another line of debug
                    let response = function(ipaddr) {
                    	let deviceresp = [];
                    	let responses = [];
                    	for(let i = 0; i < = devices.length - 1; i++) {
                    		console.log('responding for port='+devices[i].port)   // this line
                    and I see this output from the MM console , from alexa discover devices
                    [2020-08-05 11:31:33.543] [LOG]    << server got: M-SEARCH * HTTP/1.1
                    HOST: 239.255.255.250:1900
                    MAN: "ssdp:discover"
                    MX: 1
                    ST: urn:dial-multiscreen-org:service:dial:1
                    USER-AGENT: Chromium/78.0.3904.108 Linux
                     from 192.168.2.126:57706 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:93 Socket.<anonymous>)
                    [2020-08-05 11:31:33.545] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                    [2020-08-05 11:31:33.548] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                    [2020-08-05 11:31:33.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:33.552] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:33.553] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:33.553] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:33.553] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:33.553] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    (electron:23027): GLib-GIO-CRITICAL **: 11:31:34.172: g_dbus_proxy_new: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                    [2020-08-05 11:31:34.549] [LOG]    << server got: M-SEARCH * HTTP/1.1
                    MX: 1
                    [2020-08-05 11:31:34.549] [LOG]    Search request from { address: '192.168.2.126', family: 'IPv4', port: 57706, size: 167 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                    [2020-08-05 11:31:34.549] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                    [2020-08-05 11:31:34.550] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:34.551] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:34.551] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:34.551] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:34.551] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                    [2020-08-05 11:31:34.552] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                      Michael Schw.
                      Hey…
                      I have the same Issue and i will do every step i found here tomorrow.
                      I tried everything i found on the Internet but i still couldnt make it work.
                      You have any new knowledge here? I even heard somewhere that the fauxmo code wont work anymore because Alexa cant find the emulated Wemo Devices anymore. Btw Alexa Controll starts at port 11000 but when i set it to 1900 it still doesnt work.
                      I am currently at the step with disabling Spotify which didnt solve my Problem. So tomorrow i will try to make my Config.js file readable (because it looks terrible at the moment) and then i will post it here.
                      All i wanna do is to toggle my Display with Alexa…i dont need to switch Pages or hide modules. I just wanna turn it on and off. I found every Solution for every Problem i had myself except for this Problem.
                        sdetweil @Michael Schw.
                        @Michael-Schw I just added another system the other day without any issue.
                        I do have an original echo, a number of echo dots and one echo show.
                        but did the discovery from the Alexa app on my phone.
                        M 1 Reply Last reply
                          Michael Schw. @sdetweil
                          @sdetweil i tried it with the app on my fire tablet, the echo plus 2nd gen and the echo dot 3rd gen. The first gen echos are still working but the newer ones dont wanna work. So maybe we can figure something out or plan b would be a sonoff switch for the tv display . But maybe there is a way without the switch. Witch gen are your echos?
                            @Michael-Schw my echo is a gen 1, and dots are gen 2.
                            do u see the messages like I listed at mm startup? (from 5th post to this topic) also, would be startPort:19000 not 1900.
                            port 1900 is hard coded to the ssdp discovery port, used by Alexa to find devices
                            if u see the messages, and add the debugging from above, do u see the discovery request?
                            show me the mm startup.messages
                              Michael Schw.
                                Michael Schw.
                                Spotify is disabled, starting port at default and the MM startup messenges are:
                                magicmirror@2.12.0 start /home/pi/MagicMirror
                                [2020-08-10 10:06:51.201] [LOG] Starting MagicMirror: v2.12.0
                                [2020-08-10 10:06:51.214] [LOG] Loading config …
                                [2020-08-10 10:06:51.228] [LOG] Loading module helpers …
                                [2020-08-10 10:06:51.232] [LOG] No helper found for module: clock.
                                [2020-08-10 10:06:51.360] [LOG] Initializing new module helper …
                                [2020-08-10 10:06:51.361] [LOG] Module helper loaded: updatenotification
                                [2020-08-10 10:06:51.362] [LOG] No helper found for module: currentweather.
                                [2020-08-10 10:06:51.363] [LOG] No helper found for module: weatherforecast.
                                [2020-08-10 10:06:52.187] [LOG] Initializing new module helper …
                                [2020-08-10 10:06:52.188] [LOG] Module helper loaded: MMM-AlexaControl
                                [2020-08-10 10:06:52.194] [LOG] Initializing new module helper …
                                [2020-08-10 10:06:52.195] [LOG] Module helper loaded: MMM-OnScreenMenu
                                [2020-08-10 10:06:52.196] [LOG] All module helpers loaded.
                                [2020-08-10 10:06:52.535] [LOG] Starting server on port 8080 …
                                [2020-08-10 10:06:52.544] [INFO] You’re using a full whitelist configuration to allow for all IPs
                                [2020-08-10 10:06:52.556] [LOG] Server started …
                                [2020-08-10 10:06:52.557] [LOG] Connecting socket for: updatenotification
                                [2020-08-10 10:06:52.559] [LOG] Connecting socket for: MMM-AlexaControl
                                [2020-08-10 10:06:52.560] [LOG] MMM-AlexaControl helper, started…
                                [2020-08-10 10:06:52.561] [LOG] Connecting socket for: MMM-OnScreenMenu
                                [2020-08-10 10:06:52.562] [LOG] Sockets connected & modules started …
                                [2020-08-10 10:06:52.751] [LOG] Launching application.
                                [2020-08-10 10:06:55.681] [LOG] monitorToggle requested
                                [2020-08-10 10:06:55.694] [LOG] Adding multicast membership for 127.0.0.1
                                [2020-08-10 10:06:55.695] [LOG] Adding multicast membership for 10.0.0.2
                                [2020-08-10 10:06:55.697] [LOG] server is listening on 11000
                                [2020-08-10 10:06:55.700] [LOG] server is listening on 11001
                                [2020-08-10 10:06:55.701] [LOG] server is listening on 11002
                                [2020-08-10 10:06:55.702] [LOG] server is listening on 11005
                                [2020-08-10 10:06:55.741] [INFO] Checking git for module: MMM-AlexaControl
                                [2020-08-10 10:06:55.816] [INFO] Checking git for module: MMM-OnScreenMenu
                                [2020-08-10 10:07:02.910] [LOG] Shutting down server…
                                [2020-08-10 10:07:02.911] [LOG] Stopping module helper: updatenotification
                                [2020-08-10 10:07:02.912] [LOG] Stopping module helper: MMM-AlexaControl
                                [2020-08-10 10:07:02.913] [LOG] Stopping module helper: MMM-OnScreenMenu
                                Here is the config.js :
                                	module: "clock",
                                			displaySeconds: false
                                	module: "updatenotification",
                                	position: "top_bar"
                                	module: "compliments",
                                	position: "lower_third"
                                	module: "currentweather",
                                		locationID: "xxxxxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                		appid: "xxxxxxxxxxxxxxxxxxxxxx",
                                		showWindDirectionAsArrow: true,
                                		showHumidity: true,
                                		useKMPHwind: true
                                	module: "weatherforecast",
                                	header: "Weather Forecast",
                                		locationID: "xxxxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                		appid: "xxxxxxxxxxxxxxxxxxxxxxxxx",
                                		showRainAmount: true
                                	module: 'MMM-AlexaControl',
                                	position: 'middle_center',
                                	config:{
                                		image: true,
                                		pm2ProcessName: "mm",
                                		vcgencmd: true,
                                		height: "100",
                                		width: "100",
                                		deviceName: "Spiegel"
                                            module: "MMM-Spotify",
                                              disabled: true,
                                              position: "bottom_left", // "bottom_bar" or "top_bar" for miniBar
                                                debug: false, // debug mode
                                                style: "default", // "default" or "mini" available (inactive for miniBar)
                                                control: "default",
                                                accountDefault: 0, // default account number, attention : 0 is the first account
                                                updateInterval: 1000, // update interval when playing
                                                idleInterval: 2000, // update interval on idle
                                                onStart: null, // disable onStart feature with `null`
                                                deviceDisplay: "Listening on", // text to display in the device block (default style only)
                                                allowDevices: [], //If you want to limit devices to display info, use this.
                                                // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
        miniBarConfig: {
                                                  album: true, // display Album name in miniBar style
                                                  scroll: true, // scroll title / artist / album in miniBar style
                                                  logo: true, // display Spotify logo in miniBar style
                                    module: 'MMM-OnScreenMenu',
                                    position: 'bottom_right',
                                    /* Valid positions: 'top_right', 'top_left', 'bottom_right', 'bottom_left' */
                                        touchMode: true,
                                        enableKeyboard: true,
                                        // ... see more options below
                                how can you enter commands while the mirror is running?
                                they are all in the same wifi because i disabled 5Ghz.
                                the sudo netstat -a -p | grep 1900 shows nothing while the mirror isnt running.
                                i allowed all ipś and tried it with that page indicator and page module.
                                does it normal work as standalone or do i need more modules?
                                  Michael Schw.
                                  maybe i have to update something?
                                  but how do i update magicmirror, the modules, etc.??
                                  should the extra line of debug code end with nothing or a , or a ; ?
                                  i added the debugging now (with nothing at the end of that extra line) and it shows this:
                                  [2020-08-10 10:56:52.494] [LOG] Starting MagicMirror: v2.12.0
                                  [2020-08-10 10:56:52.507] [LOG] Loading config …
                                  [2020-08-10 10:56:52.517] [LOG] Loading module helpers …
                                  [2020-08-10 10:56:52.521] [LOG] No helper found for module: clock.
                                  [2020-08-10 10:56:52.619] [LOG] Initializing new module helper …
                                  [2020-08-10 10:56:52.620] [LOG] Module helper loaded: updatenotification
                                  [2020-08-10 10:56:52.621] [LOG] No helper found for module: currentweather.
                                  [2020-08-10 10:56:52.622] [LOG] No helper found for module: weatherforecast.
                                  [2020-08-10 10:56:53.215] [LOG] Initializing new module helper …
                                  [2020-08-10 10:56:53.216] [LOG] Module helper loaded: MMM-AlexaControl
                                  [2020-08-10 10:56:53.219] [LOG] Initializing new module helper …
                                  [2020-08-10 10:56:53.220] [LOG] Module helper loaded: MMM-OnScreenMenu
                                  [2020-08-10 10:56:53.221] [LOG] All module helpers loaded.
                                  [2020-08-10 10:56:53.455] [LOG] Starting server on port 8080 …
                                  [2020-08-10 10:56:53.467] [INFO] You’re using a full whitelist configuration to allow for all IPs
                                  [2020-08-10 10:56:53.481] [LOG] Server started …
                                  [2020-08-10 10:56:53.483] [LOG] Connecting socket for: updatenotification
                                  [2020-08-10 10:56:53.485] [LOG] Connecting socket for: MMM-AlexaControl
                                  [2020-08-10 10:56:53.487] [LOG] MMM-AlexaControl helper, started…
                                  [2020-08-10 10:56:53.489] [LOG] Connecting socket for: MMM-OnScreenMenu
                                  [2020-08-10 10:56:53.490] [LOG] Sockets connected & modules started …
                                  [2020-08-10 10:56:53.677] [LOG] Launching application.
                                  [2020-08-10 10:56:56.641] [LOG] monitorToggle requested
                                  [2020-08-10 10:56:56.662] [LOG] Adding multicast membership for 127.0.0.1
                                  [2020-08-10 10:56:56.673] [LOG] Adding multicast membership for 10.0.0.2
                                  [2020-08-10 10:56:56.677] [LOG] server is listening on 11000
                                  [2020-08-10 10:56:56.681] [LOG] server is listening on 11001
                                  [2020-08-10 10:56:56.684] [LOG] server is listening on 11002
                                  [2020-08-10 10:56:56.687] [LOG] server is listening on 11005
                                  [2020-08-10 10:56:56.794] [INFO] Checking git for module: MMM-AlexaControl
                                  [2020-08-10 10:56:56.842] [INFO] Checking git for module: MMM-OnScreenMenu
                                  [2020-08-10 10:57:17.037] [ERROR] fatal: unable to access ‘https://github.com/shbatm/MMM-OnScreenMenu/’: Could not resolve host: github.com
                                  [2020-08-10 10:57:17.062] [ERROR] fatal: unable to access ‘https://github.com/JoChef2/MMM-AlexaControl.git/’: Could not resolve host: github.com
                                  [2020-08-10 10:57:17.088] [ERROR] fatal: unable to access ‘https://github.com/MichMich/MagicMirror/’: Could not resolve host: github.com
                                  [2020-08-10 10:57:24.385] [LOG] << server got: M-SEARCH * HTTP/1.1
                                  MAN: “ssdp:discover”
                                  MX: 1
                                  from 10.0.0.2:48010
                                  [2020-08-10 10:57:24.401] [LOG] Search request from { address: ‘10.0.0.2’, family: ‘IPv4’, port: 48010, size: 167 }
                                  [2020-08-10 10:57:24.444] [LOG] 10.0.0.0
                                  [2020-08-10 10:57:24.460] [LOG] responding for port=11000
                                  [2020-08-10 10:57:24.473] [LOG] responding for port=11001
                                  [2020-08-10 10:57:24.476] [LOG] responding for port=11002
                                  [2020-08-10 10:57:24.478] [LOG] responding for port=11005
                                  [2020-08-10 10:57:25.389] [LOG] << server got: M-SEARCH * HTTP/1.1
                                  MX: 1
                                  from 10.0.0.2:48010
                                  [2020-08-10 10:57:25.393] [LOG] Search request from { address: ‘10.0.0.2’, family: ‘IPv4’, port: 48010, size: 167 }
                                  [2020-08-10 10:57:25.396] [LOG] 10.0.0.0
                                  [2020-08-10 10:57:25.405] [LOG] responding for port=11000
                                  [2020-08-10 10:57:25.409] [LOG] responding for port=11001
                                  [2020-08-10 10:57:25.412] [LOG] responding for port=11002
                                  [2020-08-10 10:57:25.414] [LOG] responding for port=11005
                                  [2020-08-10 10:57:26.390] [LOG] << server got: M-SEARCH * HTTP/1.1
                                  MX: 1
                                  from 10.0.0.2:48010
                                  [2020-08-10 10:57:26.391] [LOG] Search request from { address: ‘10.0.0.2’, family: ‘IPv4’, port: 48010, size: 167 }
                                  [2020-08-10 10:57:26.394] [LOG] 10.0.0.0
                                  [2020-08-10 10:57:26.400] [LOG] responding for port=11000
                                  [2020-08-10 10:57:26.402] [LOG] responding for port=11001
                                  [2020-08-10 10:57:26.404] [LOG] responding for port=11002
                                  [2020-08-10 10:57:26.407] [LOG] responding for port=11005
                                  [2020-08-10 10:57:27.391] [LOG] << server got: M-SEARCH * HTTP/1.1
                                  MX: 1
                                  from 10.0.0.2:48010
                                  [2020-08-10 10:57:27.392] [LOG] Search request from { address: ‘10.0.0.2’, family: ‘IPv4’, port: 48010, size: 167 }
                                  [2020-08-10 10:57:27.394] [LOG] 10.0.0.0
                                  [2020-08-10 10:57:27.400] [LOG] responding for port=11000
                                  [2020-08-10 10:57:27.403] [LOG] responding for port=11001
                                  [2020-08-10 10:57:27.405] [LOG] responding for port=11002
                                  [2020-08-10 10:57:27.407] [LOG] responding for port=11005
                                  [2020-08-10 10:59:06.529] [LOG] Shutting down server…
                                  [2020-08-10 10:59:06.531] [LOG] Stopping module helper: updatenotification
                                  [2020-08-10 10:59:06.533] [LOG] Stopping module helper: MMM-AlexaControl
                                  [2020-08-10 10:59:06.535] [LOG] Stopping module helper: MMM-OnScreenMenu
                                    Do you need anything else from the config.js file?
                                      @Michael-Schw one of those discovery cycles should have returned new devices found
                                      if you use Alexa phone app to look at devices, are they there? monitor, shutdown, restart?
                                      Alexa echo devices only connect at 2.4ghz, so I don’t know what happens if a device I 5ghz only. will it get the ssdp query?
                                        i redid my discovery and notice this
                                        [2020-08-10 10:25:05.522] [LOG]    << server got: M-SEARCH * HTTP/1.1
                                        MX: 15
                                        ST: urn:Belkin:device:**
                                         from 192.168.2.244:50000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:93 Socket.<anonymous>)
                                        [2020-08-10 10:25:05.523] [LOG]    Search request from { address: '192.168.2.244', family: 'IPv4', port: 50000, size: 107 } (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:94 Socket.<anonymous>)
                                        [2020-08-10 10:25:05.524] [LOG]    192.168.2.0 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:95 Socket.<anonymous>)
                                        [2020-08-10 10:25:05.525] [LOG]    responding for port=16000 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                        [2020-08-10 10:25:05.526] [LOG]    responding for port=16001 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                        [2020-08-10 10:25:05.527] [LOG]    responding for port=16002 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                        [2020-08-10 10:25:05.528] [LOG]    responding for port=16003 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                        [2020-08-10 10:25:05.528] [LOG]    responding for port=16004 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                        [2020-08-10 10:25:05.529] [LOG]    responding for port=16005 (/home/sam/MagicMirror.2.11/modules/MMM-AlexaControl/node_modules/node-fauxmo/src/SSDPService.js:18 response)
                                          @sdetweil i did try to find it on my phone…and it worked but it cant do a thing.
                                          i found : restart Spiegel pm2
                                          spiegel refresh
                                          Spiegel Monitor
                                          stop Spiegel pm2
                                          which one does what?
                                          and can i speak german to alexa and can rename these names?
                                          everytime i tried Spiegel Monitor, what i believe is the toggle function it says:please configure the option vcgencmd.
                                          so do i have to put in this option vcgencmd instead of true?
                                          this is all i got:
                                          [2020-08-10 17:26:01.656] [LOG] Starting MagicMirror: v2.12.0
                                          [2020-08-10 17:26:01.702] [LOG] Loading config …
                                          [2020-08-10 17:26:01.725] [LOG] Loading module helpers …
                                          [2020-08-10 17:26:01.729] [LOG] No helper found for module: clock.
                                          [2020-08-10 17:26:01.859] [LOG] Initializing new module helper …
                                          [2020-08-10 17:26:01.861] [LOG] Module helper loaded: updatenotification
                                          [2020-08-10 17:26:01.863] [LOG] No helper found for module: currentweather.
                                          [2020-08-10 17:26:01.865] [LOG] No helper found for module: weatherforecast.
                                          [2020-08-10 17:26:02.802] [LOG] Initializing new module helper …
                                          [2020-08-10 17:26:02.803] [LOG] Module helper loaded: MMM-AlexaControl
                                          [2020-08-10 17:26:02.810] [LOG] Initializing new module helper …
                                          [2020-08-10 17:26:02.811] [LOG] Module helper loaded: MMM-OnScreenMenu
                                          [2020-08-10 17:26:02.812] [LOG] All module helpers loaded.
                                          [2020-08-10 17:26:03.178] [LOG] Starting server on port 8080 …
                                          [2020-08-10 17:26:03.207] [INFO] You’re using a full whitelist configuration to allow for all IPs
                                          [2020-08-10 17:26:03.222] [LOG] Server started …
                                          [2020-08-10 17:26:03.224] [LOG] Connecting socket for: updatenotification
                                          [2020-08-10 17:26:03.226] [LOG] Connecting socket for: MMM-AlexaControl
                                          [2020-08-10 17:26:03.227] [LOG] MMM-AlexaControl helper, started…
                                          [2020-08-10 17:26:03.229] [LOG] Connecting socket for: MMM-OnScreenMenu
                                          [2020-08-10 17:26:03.230] [LOG] Sockets connected & modules started …
                                          [2020-08-10 17:26:03.806] [LOG] Launching application.
                                          [2020-08-10 17:26:07.569] [LOG] monitorToggle requested
                                          [2020-08-10 17:26:07.593] [LOG] Adding multicast membership for 127.0.0.1
                                          [2020-08-10 17:26:07.595] [LOG] Adding multicast membership for 10.0.0.2
                                          [2020-08-10 17:26:07.598] [LOG] server is listening on 11000
                                          [2020-08-10 17:26:07.600] [LOG] server is listening on 11001
                                          [2020-08-10 17:26:07.602] [LOG] server is listening on 11002
                                          [2020-08-10 17:26:07.603] [LOG] server is listening on 11005
                                          [2020-08-10 17:26:07.738] [INFO] Checking git for module: MMM-AlexaControl
                                          [2020-08-10 17:26:07.787] [INFO] Checking git for module: MMM-OnScreenMenu
                                          [2020-08-10 17:26:50.497] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.513] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.563] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.572] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.586] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.589] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.591] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.597] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.599] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.600] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.605] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.607] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.608] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.610] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.614] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.615] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.618] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.624] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.627] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.628] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.631] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.634] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.636] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.638] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.644] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.646] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.647] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.649] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.652] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.653] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.654] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.657] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.659] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.660] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.661] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.663] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.7:50000
                                          [2020-08-10 17:26:50.664] [LOG] Search request from { address: ‘10.0.0.7’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.665] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.668] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.670] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.672] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.674] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.680] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.682] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.683] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.686] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.688] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.689] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.690] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.692] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.693] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.694] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.697] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.699] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.700] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.701] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.704] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.705] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.708] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.713] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.715] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.716] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.717] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.719] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.720] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.721] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.724] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.726] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.727] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.728] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.730] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: ssdp:all
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.731] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.732] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.735] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.737] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.738] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.740] [LOG] responding for port=11005
                                          [2020-08-10 17:26:50.744] [LOG] << server got: M-SEARCH * HTTP/1.1
                                          ST: upnp:rootdevice
                                          MX: 3
                                          from 10.0.0.5:50000
                                          [2020-08-10 17:26:50.745] [LOG] Search request from { address: ‘10.0.0.5’, family: ‘IPv4’, port: 50000, size: 1024 }
                                          [2020-08-10 17:26:50.747] [LOG] 10.0.0.0
                                          [2020-08-10 17:26:50.751] [LOG] responding for port=11000
                                          [2020-08-10 17:26:50.753] [LOG] responding for port=11001
                                          [2020-08-10 17:26:50.754] [LOG] responding for port=11002
                                          [2020-08-10 17:26:50.755] [LOG] responding for port=11005
                                          [2020-08-10 17:29:59.025] [LOG] Please configure the option vcgencmd
                                          [2020-08-10 17:31:37.427] [LOG] Please configure the option vcgencmd
                                          [2020-08-10 17:31:42.434] [LOG] Please configure the option vcgencmd
                                          [2020-08-10 17:32:02.023] [LOG] Stopping PM2 process: mm
                                          [2020-08-10 17:32:02.080] [LOG] Error: process or namespace not found
                                          at /home/pi/MagicMirror/modules/MMM-AlexaControl/node_modules/pm2/lib/API.js:1538:28
                                          at /home/pi/MagicMirror/modules/MMM-AlexaControl/node_modules/pm2/lib/Client.js:734:12
                                          at /home/pi/MagicMirror/modules/MMM-AlexaControl/node_modules/pm2-axon-rpc/lib/client.js:45:10
                                          at Parser. (/home/pi/MagicMirror/modules/MMM-AlexaControl/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                          at Parser.emit (events.js:200:13)
                                          at Parser._write (/home/pi/MagicMirror/modules/MMM-AlexaControl/node_modules/amp/lib/stream.js:91:16)
                                          at doWrite (_stream_writable.js:417:12)
                                          at writeOrBuffer (_stream_writable.js:401:5)
                                          at Parser.Writable.write (_stream_writable.js:301:11)
                                          at Socket.ondata (_stream_readable.js:713:22)
                                          [2020-08-10 17:32:11.797] [LOG] Stopping PM2 process: mm
                                          [2020-08-10 17:32:11.831] [LOG] Error: process or namespace not found
                                          [2020-08-10 17:32:31.117] [LOG] Shutting down server…
                                          [2020-08-10 17:32:31.119] [LOG] Stopping module helper: updatenotification
                                          [2020-08-10 17:32:31.120] [LOG] Stopping module helper: MMM-AlexaControl
                                          [2020-08-10 17:32:31.121] [LOG] Stopping module helper: MMM-OnScreenMenu
                                          S 2 Replies Last reply
                                            @Michael-Schw said in MMM-AlexaControl or MMM-AlexaOn/Off setup:
                                            restart Spiegel pm2
                                            spiegel refresh
                                            Spiegel Monitor
                                            stop Spiegel pm2
                                            these names are device names.
                                            remember these are plugs, so the command is alex turn on (device name) , or alexa turn off (device name)
                                            there is a file in the translations directory for changing the device names… and language
                                            mine looks like
                                                "PAGE": "page ",
                                                "REFRESH": "refresh mirror",
                                                "RESTART": "restart mirror",
                                                "STOP": "stop mirror",
                                                "REBOOT": "reboot mirror",
                                                "SHUTDOWN": "shutdown mirror",
                                                "MONITOR": "mirror"
                                            my extension to this was to put the name between any 2 words
                                            reboot mirror = reboot [name] mirror
                                            my mirrors are named,
                                            office, hall, desk, desktop, catalina, nano
                                            I changed Monitor to Mirror
                                            (and also provided deviceName:??? in config)
                                            so I can say
                                            alexa turn off hall mirror
                                            U would say (unless u change the translations file, and redo disocvery, I think u have to delete the devices to get new name used)
                                            alexa turn off spiegel monitor
                                            alexa turn on spiegel refresh
                                            some of the verbiage is hard, but best u can do with on/off switches
                                            • 4 / 5
