    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      dave_ @sdetweil
      @sdetweil actually take a look at this
      https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
        sdetweil @dave_
        @dave_ something is using the port again
        do this again
        sudo netstat -a -p | grep 1900
        D S 2 Replies Last reply
          dave_ @sdetweil
          @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
          No response
            @sdetweil in config.js add
            disabled: true,
            to the MMM_AlexaControl module def
                  module: 'MMM-AlexaControl',
                  disabled: true,          /// add this line
                   position: whatever,
                  config:{
            and restart MM, then in another window to the netstat -a -p command again
              it is hard to help if you don’t respond
              D 1 Reply Last reply
                dave_ @sdetweil
                @sdetweil sorry so i just did what u said and still the same like last time
                  sdetweil @dave_
                  @dave_ no response?
                  show me MM messages
                    dave_ @sdetweil
                    @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                      sdetweil @dave_
                      @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                        dave_ @sdetweil
                        @sdetweil https://photos.app.goo.gl/33wVwMbpT135Ng8FA
                        There u go
                          sdetweil @dave_
                          @dave_ but you were supposed to have AlexaControl disabled… but do not
                          please post your config.js (in code block please)
                            dave_ @sdetweil
                            @sdetweil with that disabled it doesn’t seem to work
                              sdetweil @dave_
                              @dave_ it won’t work, we are debugging… trying to find what process has port 1900 , which alexacontrol needs, but was blocked from using…
                                dave_ @sdetweil
                                @sdetweil so the alexa module is disabled and again like before when i do that sudo netstat command nothing shows up
                                  sdetweil @dave_
                                  @dave_ so, something doesn’t make sense… please show me your config.js
                                    dave_ @sdetweil
                                      sdetweil @dave_
                                      @dave_ weird… ok, re-enable AlexaControl (change to disabled: false, ) then restart MM and show me the messages again
                                        dave_ @sdetweil
                                        @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
                                          sdetweil @dave_
                                          @dave_ and the MM messages? yes, electron should be using 1900 now for alexacontrol
                                            dave_ @sdetweil
                                            @sdetweil https://photos.app.goo.gl/SuvM64zPpyQCZjQT8
                                            • 4 / 5
