    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 59.2k Views 5 Watching
      sdetweil @dave_
      @dave_ sure, its nothing
              module: 'MMM-AlexaControl',
              position: 'middle_center',
              config:{
                  image: true,
                  pm2ProcessName: "MagicMirror",
                  vcgencmd: "hide",
                  deviceName: 'chromebook'
        dave_ @sdetweil
        @sdetweil pm2processname is name of the folder we used to install pm2 and all correct?
          sdetweil @dave_
          @dave_ setup?
          cd ~/MagicMirror/modules
          git clone https://github.com/JoChef2/MMM-AlexaControl.git
          cd MMM-AlexaControl
          npm install
          edited MMM-AlexControl/translations/en.json to be cause I want command to be ‘turn off xx mirror’
              "PAGE": "page ",
              "REFRESH": "refresh mirror",
              "RESTART": "restart mirror",
              "STOP": "stop mirror",
              "REBOOT": "reboot mirror",
              "SHUTDOWN": "shutdown mirror",
              "MONITOR": "mirror",
                  "USB": "USB"
          copy paste sample config.js section from his doc and add my info
          restart mm…
          alexa discover devices
          devices found
          alexa turn off chromebook mirror
            sdetweil @dave_
            @dave_ no. its the name that shows in the pm2 status command
            pm2 start MagicMirror
              dave_ @sdetweil
              @sdetweil in my case i type in pm2 start mm so for me it’ll be mm!
                sdetweil @dave_
                @dave_ correct… if you had used my scripted install I setup pm2 as MagicMirror
                see https://github.com/sdetweil/MagicMirror_scripts
                  sdetweil @dave_
                  @dave_ cause one of the devices is restart MM (using pm2)
                    can u disable other modules and try discovery something is blocking it from working…
                    do you have vpn on, or firewall, or is this on magicmirror OS under docker?
                      dave_ @sdetweil
                      @sdetweil nope nothing like that
                        sdetweil @dave_
                        @dave_ did u try disabling other modules
                          dave_ @sdetweil
                          @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
                          Thanks for your help appreciate it
                            dave_ @sdetweil
                            @sdetweil actually take a look at this
                            https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
                              sdetweil @dave_
                              @dave_ something is using the port again
                              do this again
                              sudo netstat -a -p | grep 1900
                              D S 2 Replies Last reply Reply Quote 0
                                dave_ @sdetweil
                                @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
                                No response
                                  @sdetweil in config.js add
                                  disabled: true,
                                  to the MMM_AlexaControl module def
                                        disabled: true,          /// add this line
                                         position: whatever,
                                        config:{
                                  and restart MM, then in another window to the netstat -a -p command again
                                    it is hard to help if you don’t respond
                                      dave_ @sdetweil
                                      @sdetweil sorry so i just did what u said and still the same like last time
                                        sdetweil @dave_
                                        @dave_ no response?
                                        show me MM messages
                                          dave_ @sdetweil
                                          @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                                            sdetweil @dave_
                                            @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                                            • 3 / 5
