    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.1k Views 5 Watching
      dave_ @sdetweil
      @sdetweil ohh na the mirror still isn’t working for some reason as in the module I’m on the verge of giving up now!
        sdetweil @dave_
        @dave_ hm. it has worked on 8 different systems now for me. pi 3 & 4, odroid, Jetson nano, gallium os on my Chromebook, Ubuntu on my desktop, and on my Mac.
          dave_ @sdetweil
          @sdetweil alright could you send me your config?
          D S 2 Replies Last reply Reply Quote 0
            dave_ @dave_
            @dave_ or idk if it’s too much to ask but if u have time u could maybe make a video of u setting up the whole module
              sdetweil @dave_
              @dave_ sure, its nothing
                      module: 'MMM-AlexaControl',
                      position: 'middle_center',
                      config:{
                          image: true,
                          pm2ProcessName: "MagicMirror",
                          vcgencmd: "hide",
                          deviceName: 'chromebook'
                dave_ @sdetweil
                @sdetweil pm2processname is name of the folder we used to install pm2 and all correct?
                  sdetweil @dave_
                  @dave_ setup?
                  cd ~/MagicMirror/modules
                  git clone https://github.com/JoChef2/MMM-AlexaControl.git
                  cd MMM-AlexaControl
                  npm install
                  edited MMM-AlexControl/translations/en.json to be cause I want command to be ‘turn off xx mirror’
                      "PAGE": "page ",
                      "REFRESH": "refresh mirror",
                      "RESTART": "restart mirror",
                      "STOP": "stop mirror",
                      "REBOOT": "reboot mirror",
                      "SHUTDOWN": "shutdown mirror",
                      "MONITOR": "mirror",
                          "USB": "USB"
                  copy paste sample config.js section from his doc and add my info
                  restart mm…
                  alexa discover devices
                  devices found
                  alexa turn off chromebook mirror
                    sdetweil @dave_
                    @dave_ no. its the name that shows in the pm2 status command
                    pm2 start MagicMirror
                      dave_ @sdetweil
                      @sdetweil in my case i type in pm2 start mm so for me it’ll be mm!
                        sdetweil @dave_
                        @dave_ correct… if you had used my scripted install I setup pm2 as MagicMirror
                        see https://github.com/sdetweil/MagicMirror_scripts
                          sdetweil @dave_
                          @dave_ cause one of the devices is restart MM (using pm2)
                            can u disable other modules and try discovery something is blocking it from working…
                            do you have vpn on, or firewall, or is this on magicmirror OS under docker?
                              dave_ @sdetweil
                              @sdetweil nope nothing like that
                                sdetweil @dave_
                                @dave_ did u try disabling other modules
                                  dave_ @sdetweil
                                  @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
                                  Thanks for your help appreciate it
                                    dave_ @sdetweil
                                    @sdetweil actually take a look at this
                                    https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
                                      sdetweil @dave_
                                      @dave_ something is using the port again
                                      do this again
                                      sudo netstat -a -p | grep 1900
                                        dave_ @sdetweil
                                        @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
                                        No response
                                          @sdetweil in config.js add
                                          disabled: true,
                                          to the MMM_AlexaControl module def
                                                disabled: true,          /// add this line
                                                 position: whatever,
                                                config:{
                                          and restart MM, then in another window to the netstat -a -p command again
                                            it is hard to help if you don’t respond
                                            • 3 / 5
