    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      sdetweil @dave_
      @dave_ did u try disabling other modules
      D 2 Replies Last reply
        dave_ @sdetweil
        @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
        Thanks for your help appreciate it
          dave_ @sdetweil
          @sdetweil actually take a look at this
          https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
            sdetweil @dave_
            @dave_ something is using the port again
            do this again
            sudo netstat -a -p | grep 1900
            D S 2 Replies Last reply
              dave_ @sdetweil
              @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
              No response
                @sdetweil in config.js add
                disabled: true,
                to the MMM_AlexaControl module def
                      module: 'MMM-AlexaControl',
                      disabled: true,          /// add this line
                       position: whatever,
                      config:{
                and restart MM, then in another window to the netstat -a -p command again
                  it is hard to help if you don’t respond
                  D 1 Reply Last reply
                    dave_ @sdetweil
                    @sdetweil sorry so i just did what u said and still the same like last time
                      sdetweil @dave_
                      @dave_ no response?
                      show me MM messages
                        dave_ @sdetweil
                        @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                          sdetweil @dave_
                          @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                            dave_ @sdetweil
                            @sdetweil https://photos.app.goo.gl/33wVwMbpT135Ng8FA
                            There u go
                              sdetweil @dave_
                              @dave_ but you were supposed to have AlexaControl disabled… but do not
                              please post your config.js (in code block please)
                                dave_ @sdetweil
                                @sdetweil with that disabled it doesn’t seem to work
                                  sdetweil @dave_
                                  @dave_ it won’t work, we are debugging… trying to find what process has port 1900 , which alexacontrol needs, but was blocked from using…
                                    dave_ @sdetweil
                                    @sdetweil so the alexa module is disabled and again like before when i do that sudo netstat command nothing shows up
                                      sdetweil @dave_
                                      @dave_ so, something doesn’t make sense… please show me your config.js
                                        dave_ @sdetweil
                                          sdetweil @dave_
                                          @dave_ weird… ok, re-enable AlexaControl (change to disabled: false, ) then restart MM and show me the messages again
                                            dave_ @sdetweil
                                            @sdetweil https://photos.app.goo.gl/Eqxwv27mVDBbowBH8
                                            • 3 / 5
