    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.1k Views 5 Watching
      dave_ @sdetweil
      @sdetweil in my case i type in pm2 start mm so for me it’ll be mm!
        sdetweil @dave_
        @dave_ correct… if you had used my scripted install I setup pm2 as MagicMirror
        see https://github.com/sdetweil/MagicMirror_scripts
          sdetweil @dave_
          @dave_ cause one of the devices is restart MM (using pm2)
            can u disable other modules and try discovery something is blocking it from working…
            do you have vpn on, or firewall, or is this on magicmirror OS under docker?
              dave_ @sdetweil
              @sdetweil nope nothing like that
                sdetweil @dave_
                @dave_ did u try disabling other modules
                  dave_ @sdetweil
                  @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
                  Thanks for your help appreciate it
                    dave_ @sdetweil
                    @sdetweil actually take a look at this
                    https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
                      sdetweil @dave_
                      @dave_ something is using the port again
                      do this again
                      sudo netstat -a -p | grep 1900
                      D S 2 Replies Last reply Reply Quote 0
                        dave_ @sdetweil
                        @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
                        No response
                          @sdetweil in config.js add
                          disabled: true,
                          to the MMM_AlexaControl module def
                                module: 'MMM-AlexaControl',
                                disabled: true,          /// add this line
                                 position: whatever,
                                config:{
                          and restart MM, then in another window to the netstat -a -p command again
                            it is hard to help if you don’t respond
                              dave_ @sdetweil
                              @sdetweil sorry so i just did what u said and still the same like last time
                                sdetweil @dave_
                                @dave_ no response?
                                show me MM messages
                                  dave_ @sdetweil
                                  @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                                    sdetweil @dave_
                                    @dave_ and while MM was running you were supposed to do the netstat -a -p commands to see if the process blocking port 1900 is inside MM…
                                      dave_ @sdetweil
                                      @sdetweil https://photos.app.goo.gl/33wVwMbpT135Ng8FA
                                      There u go
                                        sdetweil @dave_
                                        @dave_ but you were supposed to have AlexaControl disabled… but do not
                                        please post your config.js (in code block please)
                                          dave_ @sdetweil
                                          @sdetweil with that disabled it doesn’t seem to work
                                            sdetweil @dave_
                                            @dave_ it won’t work, we are debugging… trying to find what process has port 1900 , which alexacontrol needs, but was blocked from using…
                                            • 3 / 5
