    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      dave_ @sdetweil
      @sdetweil just a smart socket or plug
      https://www.google.com/aclk?sa=L&ai=DChcSEwis7u_Au__qAhWMNSsKHXRyDQkYABAEGgJzZg&ae=1&sig=AOD64_3w4wfq49oIqhcvc-uCBklV29myoA&ctype=70&q=&ved=2ahUKEwj88OnAu__qAhUNxzgGHWn-Dc4Qwg96BAgQEBM&adurl=https://www.amazon.com.au/TP-Link-Required-Anywhere-Assistant-HS100/dp/B017X72J5Q/ref%3Dasc_df_B017X72J5Q/%3Ftag%3Dgoogleshopmob-22%26linkCode%3Ddf0%26hvadid%3D341745072405%26hvpos%3D%26hvnetw%3Dg%26hvrand%3D1304696691917917692%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dm%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9071477%26hvtargid%3Dpla-674246294363%26psc%3D1
        sdetweil @dave_
        @dave_ yeh, but not a belkin wemo plug, which is what the module emulates
        S D 2 Replies Last reply
          @dave_ try changing the startPort to like 13000 or 15000
            dave_ @sdetweil
            @sdetweil ohh na the mirror still isn’t working for some reason as in the module I’m on the verge of giving up now!
              sdetweil @dave_
              @dave_ hm. it has worked on 8 different systems now for me. pi 3 & 4, odroid, Jetson nano, gallium os on my Chromebook, Ubuntu on my desktop, and on my Mac.
              D 1 Reply Last reply
                dave_ @sdetweil
                @sdetweil alright could you send me your config?
                D S 2 Replies Last reply
                  dave_ @dave_
                  @dave_ or idk if it’s too much to ask but if u have time u could maybe make a video of u setting up the whole module
                    sdetweil @dave_
                    @dave_ sure, its nothing
                            module: 'MMM-AlexaControl',
                            position: 'middle_center',
                            config:{
                                image: true,
                                pm2ProcessName: "MagicMirror",
                                vcgencmd: "hide",
                                deviceName: 'chromebook'
                      dave_ @sdetweil
                      @sdetweil pm2processname is name of the folder we used to install pm2 and all correct?
                        sdetweil @dave_
                        @dave_ setup?
                        cd ~/MagicMirror/modules
                        git clone https://github.com/JoChef2/MMM-AlexaControl.git
                        cd MMM-AlexaControl
                        npm install
                        edited MMM-AlexControl/translations/en.json to be cause I want command to be ‘turn off xx mirror’
                            "PAGE": "page ",
                            "REFRESH": "refresh mirror",
                            "RESTART": "restart mirror",
                            "STOP": "stop mirror",
                            "REBOOT": "reboot mirror",
                            "SHUTDOWN": "shutdown mirror",
                            "MONITOR": "mirror",
                                "USB": "USB"
                        copy paste sample config.js section from his doc and add my info
                        restart mm…
                        alexa discover devices
                        devices found
                        alexa turn off chromebook mirror
                          sdetweil @dave_
                          @dave_ no. its the name that shows in the pm2 status command
                          pm2 start MagicMirror
                            dave_ @sdetweil
                            @sdetweil in my case i type in pm2 start mm so for me it’ll be mm!
                              sdetweil @dave_
                              @dave_ correct… if you had used my scripted install I setup pm2 as MagicMirror
                              see https://github.com/sdetweil/MagicMirror_scripts
                                sdetweil @dave_
                                @dave_ cause one of the devices is restart MM (using pm2)
                                  can u disable other modules and try discovery something is blocking it from working…
                                  do you have vpn on, or firewall, or is this on magicmirror OS under docker?
                                    dave_ @sdetweil
                                    @sdetweil nope nothing like that
                                      sdetweil @dave_
                                      @dave_ did u try disabling other modules
                                        dave_ @sdetweil
                                        @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
                                        Thanks for your help appreciate it
                                          dave_ @sdetweil
                                          @sdetweil actually take a look at this
                                          https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
                                            sdetweil @dave_
                                            @dave_ something is using the port again
                                            do this again
                                            sudo netstat -a -p | grep 1900
                                            • 3 / 5
