    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.5k Views 5 Watching
      sdetweil @dave_
      @dave_ show the MM messages again
        sdetweil @dave_
        @dave_ how are you doing discovery?
        using my real echo, I say
        Alexa, discover devices
          @dave_ MM has to be running before discovery, right?
            dave_ @sdetweil
            @sdetweil yeah the magic mirror is running and then a i discover i have used the app and the manual search for device as well as “discover my devices”
            alt text
              sdetweil @dave_
              @dave_ are the mirror and alexa device on the same network, wifi vs ethernet?
              if u go look at devices are they there already?
                dave_ @sdetweil
                @sdetweil yeah both devices are on same wireless network
                  sdetweil @dave_
                  @dave_ i deleted a device and then used the alexa app to discover ‘other’ type devices and it found the one i deleted and added it back
                    dave_ @sdetweil
                    @sdetweil i did the same thing just now with my smart plug and it worked through the alexa app so there’s something wrong with the module or my raspberry pi
                      sdetweil @dave_
                      @dave_ w a real plug?
                        dave_ @sdetweil
                        @sdetweil just a smart socket or plug
                        https://www.google.com/aclk?sa=L&ai=DChcSEwis7u_Au__qAhWMNSsKHXRyDQkYABAEGgJzZg&ae=1&sig=AOD64_3w4wfq49oIqhcvc-uCBklV29myoA&ctype=70&q=&ved=2ahUKEwj88OnAu__qAhUNxzgGHWn-Dc4Qwg96BAgQEBM&adurl=https://www.amazon.com.au/TP-Link-Required-Anywhere-Assistant-HS100/dp/B017X72J5Q/ref%3Dasc_df_B017X72J5Q/%3Ftag%3Dgoogleshopmob-22%26linkCode%3Ddf0%26hvadid%3D341745072405%26hvpos%3D%26hvnetw%3Dg%26hvrand%3D1304696691917917692%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dm%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9071477%26hvtargid%3Dpla-674246294363%26psc%3D1
                          sdetweil @dave_
                          @dave_ yeh, but not a belkin wemo plug, which is what the module emulates
                          S D 2 Replies Last reply Reply Quote 0
                            @dave_ try changing the startPort to like 13000 or 15000
                              dave_ @sdetweil
                              @sdetweil ohh na the mirror still isn’t working for some reason as in the module I’m on the verge of giving up now!
                                sdetweil @dave_
                                @dave_ hm. it has worked on 8 different systems now for me. pi 3 & 4, odroid, Jetson nano, gallium os on my Chromebook, Ubuntu on my desktop, and on my Mac.
                                  dave_ @sdetweil
                                  @sdetweil alright could you send me your config?
                                  D S 2 Replies Last reply Reply Quote 0
                                    dave_ @dave_
                                    @dave_ or idk if it’s too much to ask but if u have time u could maybe make a video of u setting up the whole module
                                      sdetweil @dave_
                                      @dave_ sure, its nothing
                                              module: 'MMM-AlexaControl',
                                              position: 'middle_center',
                                              config:{
                                                  image: true,
                                                  pm2ProcessName: "MagicMirror",
                                                  vcgencmd: "hide",
                                                  deviceName: 'chromebook'
                                        dave_ @sdetweil
                                        @sdetweil pm2processname is name of the folder we used to install pm2 and all correct?
                                          sdetweil @dave_
                                          @dave_ setup?
                                          cd ~/MagicMirror/modules
                                          git clone https://github.com/JoChef2/MMM-AlexaControl.git
                                          cd MMM-AlexaControl
                                          npm install
                                          edited MMM-AlexControl/translations/en.json to be cause I want command to be ‘turn off xx mirror’
                                              "PAGE": "page ",
                                              "REFRESH": "refresh mirror",
                                              "RESTART": "restart mirror",
                                              "STOP": "stop mirror",
                                              "REBOOT": "reboot mirror",
                                              "SHUTDOWN": "shutdown mirror",
                                              "MONITOR": "mirror",
                                                  "USB": "USB"
                                          copy paste sample config.js section from his doc and add my info
                                          restart mm…
                                          alexa discover devices
                                          devices found
                                          alexa turn off chromebook mirror
                                            sdetweil @dave_
                                            @dave_ no. its the name that shows in the pm2 status command
                                            pm2 start MagicMirror
                                            • 2 / 5
