    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      sdetweil @dave_
      @dave_ did u see the startup messages from the module like i posted?
      D 1 Reply Last reply
        dave_ @sdetweil
        @sdetweil alt text
        I am not quite sure which line to look at but check the image
        Just out of curiosity does it have to be alexa echo device like can’t a i use for a soundbar or speaker with built in alexa or maybe even the mobile app?
          sdetweil @dave_
          @dave_ u got the eaddressinuse error. something is using port 1900, this the the port we stopped Spotify to get access to
          stop mm, then do
          sudo netstat -a | grep 1900
          in there is a response then something is still using the port.
          I havent tried discovery from my Alexa app in a long time. since they made it possible via voice command
            dave_ @sdetweil
            @sdetweil alt text that’s what it says
              sdetweil @dave_
              @dave_
              ok do this
              sudo netstat -a -p | grep 1900
              mine shows this when MM is running
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           11153/electron.js
                dave_ @sdetweil
                @sdetweil ohh shit i had installed jellyfin media server ages ago and that’s what it’s saying how do i uninstall that 😂
                  sdetweil @dave_
                  @dave_ sorry, no idea… google might help
                  D 2 Replies Last reply
                    dave_ @sdetweil
                    @sdetweil lemme see and I’ll let u know
                      dave_ @sdetweil
                      @sdetweil can i just Change the ports? And then make ot work if yes what should i change it to
                      S 2 Replies Last reply
                        sdetweil @dave_
                        @dave_ no ssdp discovery only supports port 1900
                          dave_ @sdetweil
                          @sdetweil makes sense
                            sdetweil @dave_
                            @dave_ come on man, google says
                            https://www.electromaker.io/tutorial/blog/how-to-install-jellyfin-on-the-raspberry-pi
                            and shows how to start/stop
                              dave_ @sdetweil
                              @sdetweil i got it alright so now u know the 2 codes u gave I’m putting them and nothing is showing up
                              I tried to discover the devices still no luck :/
                                sdetweil @dave_
                                @dave_ show the MM messages again
                                  sdetweil @dave_
                                  @dave_ how are you doing discovery?
                                  using my real echo, I say
                                  Alexa, discover devices
                                    @dave_ MM has to be running before discovery, right?
                                      dave_ @sdetweil
                                      @sdetweil yeah the magic mirror is running and then a i discover i have used the app and the manual search for device as well as “discover my devices”
                                      alt text
                                        sdetweil @dave_
                                        @dave_ are the mirror and alexa device on the same network, wifi vs ethernet?
                                        if u go look at devices are they there already?
                                          dave_ @sdetweil
                                          @sdetweil yeah both devices are on same wireless network
                                            sdetweil @dave_
                                            @dave_ i deleted a device and then used the alexa app to discover ‘other’ type devices and it found the one i deleted and added it back
                                            • 2 / 5
