    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.5k Views 5 Watching
      sdetweil @dave_
      @dave_ look at the console where u started mm.
      pm2 logs --lines=100
      or
      in the window where u did npm start.
      black screen usually means missing library
      u did npm install in the AlexaControl folder, right?
        dave_ @sdetweil
        @sdetweil it’s finally showing on screen like the mm is working but still had no luck with discovery and Spotify is off
          sdetweil @dave_
          @dave_ did u see the startup messages from the module like i posted?
            dave_ @sdetweil
            @sdetweil alt text
            I am not quite sure which line to look at but check the image
            Just out of curiosity does it have to be alexa echo device like can’t a i use for a soundbar or speaker with built in alexa or maybe even the mobile app?
              sdetweil @dave_
              @dave_ u got the eaddressinuse error. something is using port 1900, this the the port we stopped Spotify to get access to
              stop mm, then do
              sudo netstat -a | grep 1900
              in there is a response then something is still using the port.
              I havent tried discovery from my Alexa app in a long time. since they made it possible via voice command
                dave_ @sdetweil
                @sdetweil alt text that’s what it says
                  sdetweil @dave_
                  @dave_
                  ok do this
                  sudo netstat -a -p | grep 1900
                  mine shows this when MM is running
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           11153/electron.js
                    dave_ @sdetweil
                    @sdetweil ohh shit i had installed jellyfin media server ages ago and that’s what it’s saying how do i uninstall that 😂
                      sdetweil @dave_
                      @dave_ sorry, no idea… google might help
                        dave_ @sdetweil
                        @sdetweil lemme see and I’ll let u know
                          dave_ @sdetweil
                          @sdetweil can i just Change the ports? And then make ot work if yes what should i change it to
                            sdetweil @dave_
                            @dave_ no ssdp discovery only supports port 1900
                              dave_ @sdetweil
                              @sdetweil makes sense
                                sdetweil @dave_
                                @dave_ come on man, google says
                                https://www.electromaker.io/tutorial/blog/how-to-install-jellyfin-on-the-raspberry-pi
                                and shows how to start/stop
                                  dave_ @sdetweil
                                  @sdetweil i got it alright so now u know the 2 codes u gave I’m putting them and nothing is showing up
                                  I tried to discover the devices still no luck :/
                                    sdetweil @dave_
                                    @dave_ show the MM messages again
                                      sdetweil @dave_
                                      @dave_ how are you doing discovery?
                                      using my real echo, I say
                                      Alexa, discover devices
                                        @dave_ MM has to be running before discovery, right?
                                          dave_ @sdetweil
                                          @sdetweil yeah the magic mirror is running and then a i discover i have used the app and the manual search for device as well as “discover my devices”
                                          alt text
                                            sdetweil @dave_
                                            @dave_ are the mirror and alexa device on the same network, wifi vs ethernet?
                                            if u go look at devices are they there already?
                                            • 1 / 5
