    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.7k Views 5 Watching
      dave_
      I have been trying to setup any of the 2 modules the installation and config goes well but when i reach the stage where i to discover devices on my alexa app it just doesn’t work!
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @dave_
        @dave_ MMM-AlexaControl works well and MMM-AlexaOnOff does not work.
        Can you post the config of the module, maybe somebody can help you?
          dave_ @Stoffbeuteluwe
          @Stoffbeuteluwe sure
            @Stoffbeuteluwe
            // module: ‘MMM-AlexaControl’,
            // position: ‘middle_center’,
            // config:{
            // image: true,
            // pm2ProcessName: “PM2”,
            // vcgencmd: “vcgencmd”,
            ignore the // brackets.
              sdetweil @dave_
              @dave_ what port range did u specify? you need to set a unique port range for each mirror on your network.
              I see it defaults. never mind.
              if u are running a Spotify player on this machine, the two things fight over the discovery port, 1900. so u have to stop the Spotify client while Alexa does Discovery
              S D 2 Replies Last reply Reply Quote 0
                @dave_ you should see messages like this on MM startup for alexacontrol
                [2020-08-02 16:47:29.642] [INFO] Checking git for module: MMM-AlexaControl
                [2020-08-02 16:47:29.675] [LOG] Adding multicast membership for 127.0.0.1
                [2020-08-02 16:47:29.676] [LOG] Adding multicast membership for 192.168.2.11
                [2020-08-02 16:47:29.677] [LOG] server is listening on 11000
                [2020-08-02 16:47:29.679] [LOG] server is listening on 11001
                [2020-08-02 16:47:29.679] [LOG] server is listening on 11002
                [2020-08-02 16:47:29.680] [LOG] server is listening on 11005
                  dave_ @sdetweil
                  @sdetweil hmm so should i stop the Spotify and try again? Or what port range Should i specify it to?
                    sdetweil @dave_
                    @dave_ you MUST stop the spotify thing , then restart MM, see those messages and then do alexa discover devices (using real echo device)…
                    once the devices are added, you can turn on the spotify tool …
                      dave_ @sdetweil
                      @sdetweil so i did turn of the Spotify and when i launched the magic mirror it is not showing up anything it’s blank screen Like usually when there’s something with config it says a message but in this case it’s blank
                        sdetweil @dave_
                        @dave_ look at the console where u started mm.
                        pm2 logs --lines=100
                        or
                        in the window where u did npm start.
                        black screen usually means missing library
                        u did npm install in the AlexaControl folder, right?
                        • 10
                        • 1 / 10
