    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 68.7k Views 5 Watching
      sdetweil @dave_
      @dave_ sorry, no idea… google might help
      D 2 Replies Last reply
        dave_ @sdetweil
        @sdetweil lemme see and I’ll let u know
          dave_ @sdetweil
          @sdetweil can i just Change the ports? And then make ot work if yes what should i change it to
          S 2 Replies Last reply
            sdetweil @dave_
            @dave_ no ssdp discovery only supports port 1900
            D 1 Reply Last reply
              dave_ @sdetweil
              @sdetweil makes sense
                sdetweil @dave_
                @dave_ come on man, google says
                https://www.electromaker.io/tutorial/blog/how-to-install-jellyfin-on-the-raspberry-pi
                and shows how to start/stop
                  dave_ @sdetweil
                  @sdetweil i got it alright so now u know the 2 codes u gave I’m putting them and nothing is showing up
                  I tried to discover the devices still no luck :/
                    sdetweil @dave_
                    @dave_ show the MM messages again
                      sdetweil @dave_
                      @dave_ how are you doing discovery?
                      using my real echo, I say
                      Alexa, discover devices
                        @dave_ MM has to be running before discovery, right?
                          dave_ @sdetweil
                          @sdetweil yeah the magic mirror is running and then a i discover i have used the app and the manual search for device as well as “discover my devices”
                          alt text
                            sdetweil @dave_
                            @dave_ are the mirror and alexa device on the same network, wifi vs ethernet?
                            if u go look at devices are they there already?
                              dave_ @sdetweil
                              @sdetweil yeah both devices are on same wireless network
                                sdetweil @dave_
                                @dave_ i deleted a device and then used the alexa app to discover ‘other’ type devices and it found the one i deleted and added it back
                                  dave_ @sdetweil
                                  @sdetweil i did the same thing just now with my smart plug and it worked through the alexa app so there’s something wrong with the module or my raspberry pi
                                    sdetweil @dave_
                                    @dave_ w a real plug?
                                      dave_ @sdetweil
                                      @sdetweil just a smart socket or plug
                                      https://www.google.com/aclk?sa=L&ai=DChcSEwis7u_Au__qAhWMNSsKHXRyDQkYABAEGgJzZg&ae=1&sig=AOD64_3w4wfq49oIqhcvc-uCBklV29myoA&ctype=70&q=&ved=2ahUKEwj88OnAu__qAhUNxzgGHWn-Dc4Qwg96BAgQEBM&adurl=https://www.amazon.com.au/TP-Link-Required-Anywhere-Assistant-HS100/dp/B017X72J5Q/ref%3Dasc_df_B017X72J5Q/%3Ftag%3Dgoogleshopmob-22%26linkCode%3Ddf0%26hvadid%3D341745072405%26hvpos%3D%26hvnetw%3Dg%26hvrand%3D1304696691917917692%26hvpone%3D%26hvptwo%3D%26hvqmt%3D%26hvdev%3Dm%26hvdvcmdl%3D%26hvlocint%3D%26hvlocphy%3D9071477%26hvtargid%3Dpla-674246294363%26psc%3D1
                                        sdetweil @dave_
                                        @dave_ yeh, but not a belkin wemo plug, which is what the module emulates
                                        S D 2 Replies Last reply
                                          @dave_ try changing the startPort to like 13000 or 15000
                                            dave_ @sdetweil
                                            @sdetweil ohh na the mirror still isn’t working for some reason as in the module I’m on the verge of giving up now!
                                            • 2 / 5
