    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 67.7k Views 5 Watching
      dave_ @dave_
      @dave_ or idk if it’s too much to ask but if u have time u could maybe make a video of u setting up the whole module
        sdetweil @dave_
        @dave_ sure, its nothing
                module: 'MMM-AlexaControl',
                position: 'middle_center',
                config:{
                    image: true,
                    pm2ProcessName: "MagicMirror",
                    vcgencmd: "hide",
                    deviceName: 'chromebook'
          dave_ @sdetweil
          @sdetweil pm2processname is name of the folder we used to install pm2 and all correct?
            sdetweil @dave_
            @dave_ setup?
            cd ~/MagicMirror/modules
            git clone https://github.com/JoChef2/MMM-AlexaControl.git
            cd MMM-AlexaControl
            npm install
            edited MMM-AlexControl/translations/en.json to be cause I want command to be ‘turn off xx mirror’
                "PAGE": "page ",
                "REFRESH": "refresh mirror",
                "RESTART": "restart mirror",
                "STOP": "stop mirror",
                "REBOOT": "reboot mirror",
                "SHUTDOWN": "shutdown mirror",
                "MONITOR": "mirror",
                    "USB": "USB"
            copy paste sample config.js section from his doc and add my info
            restart mm…
            alexa discover devices
            devices found
            alexa turn off chromebook mirror
              sdetweil @dave_
              @dave_ no. its the name that shows in the pm2 status command
              pm2 start MagicMirror
                dave_ @sdetweil
                @sdetweil in my case i type in pm2 start mm so for me it’ll be mm!
                  sdetweil @dave_
                  @dave_ correct… if you had used my scripted install I setup pm2 as MagicMirror
                  see https://github.com/sdetweil/MagicMirror_scripts
                    sdetweil @dave_
                    @dave_ cause one of the devices is restart MM (using pm2)
                      can u disable other modules and try discovery something is blocking it from working…
                      do you have vpn on, or firewall, or is this on magicmirror OS under docker?
                        dave_ @sdetweil
                        @sdetweil nope nothing like that
                          sdetweil @dave_
                          @dave_ did u try disabling other modules
                            dave_ @sdetweil
                            @sdetweil yes i did still no luck i think I’ll just wait for a new module like this to come out and hopefully that’ll work
                            Thanks for your help appreciate it
                              dave_ @sdetweil
                              @sdetweil actually take a look at this
                              https://photos.app.goo.gl/KkEKBJgnawn3sLNQ8
                                sdetweil @dave_
                                @dave_ something is using the port again
                                do this again
                                sudo netstat -a -p | grep 1900
                                D S 2 Replies Last reply Reply Quote 0
                                  dave_ @sdetweil
                                  @sdetweil https://photos.app.goo.gl/2SPuHaHJaL2EidVn7
                                  No response
                                    @sdetweil in config.js add
                                    disabled: true,
                                    to the MMM_AlexaControl module def
                                          disabled: true,          /// add this line
                                           position: whatever,
                                          config:{
                                    and restart MM, then in another window to the netstat -a -p command again
                                      it is hard to help if you don’t respond
                                        dave_ @sdetweil
                                        @sdetweil sorry so i just did what u said and still the same like last time
                                          sdetweil @dave_
                                          @dave_ no response?
                                          show me MM messages
                                            dave_ @sdetweil
                                            @sdetweil https://photos.app.goo.gl/QonL4x1TWAwagqnC6
                                            • 3 / 5
