MMM-Remote-Control Help
Hi Guys,
i have installed the module and updated my config.js file and i am able to connect to the remote.
However i am getting the below message when i run npm run start on MagicMirror
[2020-08-06 21:40:58.178] [ERROR] MODULE LIST ERROR: modules.json updating fail :EACCES: permission denied, open '/home/pi/MagicMirror/modules/MMM-Remote-Control/modules.json' [2020-08-06 21:40:58.179] [ERROR] ERROR_UPDATING [2020-08-06 21:40:59.566] [INFO] Checking git for module: MMM-Remote-Control [2020-08-06 21:40:59.645] [ERROR] error: cannot open .git/FETCH_HEAD: Permission deniedAlso whenever i make any changes with the remote i get the below error also:
[2020-08-06 21:48:57.332] [ERROR] Whoops! There was an uncaught exception... [2020-08-06 21:48:57.333] [ERROR] [Error: EACCES: permission denied, open '/home/pi/MagicMirror/modules/MMM-Remote-Control/settings.json'] { errno: -13, code: 'EACCES', syscall: 'open', path: '/home/pi/MagicMirror/modules/MMM-Remote-Control/settings.json' } [2020-08-06 21:48:57.341] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [2020-08-06 21:48:57.342] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issuesI’m quite new to all this so any help would be greatly appreciated.
Kind Regards
Michael -
@mmcghee did u you use sudo git clone to install module??? or sudo unzip?
i used sudo git clone to install
Michael
i also tried the automatic install and manual install too
@mmcghee said in MMM-Remote-Control Help:
NEVER EVER use sudo , unless for specific command…
SO, now have to fix it…
here use sudo
cd ~ sudo chown -R pi MagicMirrorthis will change ownership of all files and folders from MagicMirror on down to pi from root (sudo sets user as root, but be root to take files away from root)
what does that mean?
only one MM install should be enough, again do NOT use sudo
Sorry in the MM-Remote-Control git page you have the option of doing either an auto installation or a manual installation. I dont know if the issue i have is something to do with PM2?
