    Black screen (only with cursor visible) when waking mirror with MMM-PIR-Sensor after long sleep periods
    17 Posts 3 Posters 4.1k Views 3 Watching
      Matthew
      I noticed that after long sleep cycles (mostly overnight), the monitor turns on with detected movement (PIR sensor), but MagicMirror itself is just a black screen with my mouse cursor. I have to restart MagicMirror with alt + f4 to load properly after the long sleep. Has anyone had a problem like this? The mirror detects the motion just fine, but I lose everything on the screen when it awakes. Thanks!
      https://i.imgur.com/pRrLsnw.jpg
        sdetweil @Matthew
        @Matthew open the developers window ctrl-shift-i and select the console tab and scroll up to see any errors.
        black screen usually means some code running in the browser died
        M 2 Replies Last reply Reply Quote 1
          Matthew @sdetweil
          @sdetweil next time I get the black screen I’ll take a look!
            Matthew @sdetweil
            @sdetweil It says that devTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect
              sdetweil @Matthew
              @Matthew hmm. let me think about another debug approach.
                [[global:former-user]] @sdetweil
                @sdetweil I remember that I have some problem with an npm library with it (before I start to code)
                I don’t remember how I solve it
                After you can try my pir module if you want
                  sdetweil @Guest
                  @Matthew install this module
                  https://github.com/sdetweil/MMM-Logging
                  note that this is a modified version of this module, written by someone else… but I needed to do similar debugging a while back
                  make its module entry in config.js the top of the list, like this
                              module: 'MMM-Logging',
                                         echoRemote:false,
                  // other modules
                  let everything else default
                  this will collect all the browser logging and console logging together with timestamps…
                  then start mm like this
                  npm start >somefile 2>&1
                  or use pm2
                  (all the logging info will be saved in the pm2 logs)
                    Matthew @sdetweil
                    @sdetweil Thank you! I got the error again today, and this is what the logs said.
                    magicmirror@2.12.0 start /home/pi/MagicMirror
                    [2020-08-15 17:22:12.919] [LOG] Starting MagicMirror: v2.12.0
                    [2020-08-15 17:22:12.936] [LOG] Loading config …
                    [2020-08-15 17:22:12.946] [LOG] Loading module helpers …
                    [2020-08-15 17:22:13.105] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:13.108] [LOG] Module helper loaded: MMM-Logging
                    [2020-08-15 17:22:13.110] [LOG] No helper found for module: alert.
                    [2020-08-15 17:22:13.112] [LOG] No helper found for module: clock.
                    [2020-08-15 17:22:13.113] [LOG] No helper found for module: currentweather.
                    [2020-08-15 17:22:13.113] [LOG] No helper found for module: weatherforecast.
                    [2020-08-15 17:22:13.918] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:13.919] [LOG] Module helper loaded: newsfeed
                    [2020-08-15 17:22:13.925] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:13.926] [LOG] Module helper loaded: MMM-Wallpaper
                    [2020-08-15 17:22:13.975] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:13.976] [LOG] Module helper loaded: MMM-MyWastePickup
                    [2020-08-15 17:22:13.976] [LOG] No helper found for module: calendar_monthly.
                    [2020-08-15 17:22:14.046] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:14.047] [LOG] Module helper loaded: MMM-MyCalendar
                    [2020-08-15 17:22:14.098] [LOG] Initializing new module helper …
                    [2020-08-15 17:22:14.099] [LOG] Module helper loaded: MMM-PIR-Sensor
                    [2020-08-15 17:22:14.100] [LOG] All module helpers loaded.
                    [2020-08-15 17:22:14.394] [LOG] Starting server on port 8080 …
                    [2020-08-15 17:22:14.420] [LOG] Server started …
                    [2020-08-15 17:22:14.422] [LOG] Connecting socket for: MMM-Logging
                    [2020-08-15 17:22:14.433] [LOG] 2020-08-15T17:22:14 Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
                    [2020-08-15 17:22:14.435] [LOG] Connecting socket for: newsfeed
                    [2020-08-15 17:22:14.436] [LOG] Starting node helper for: newsfeed
                    [2020-08-15 17:22:14.438] [LOG] Connecting socket for: MMM-Wallpaper
                    [2020-08-15 17:22:14.441] [LOG] 2020-08-15T17:22:14 Starting node helper for: MMM-Wallpaper (/home/pi/MagicMirror/modules/MMM-Wallpaper/node_helper.js:33 Class.start)
                    [2020-08-15 17:22:14.447] [LOG] Connecting socket for: MMM-MyWastePickup
                    [2020-08-15 17:22:14.449] [LOG] 2020-08-15T17:22:14 Starting node_helper for module: MMM-MyWastePickup (/home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:10 Class.start)
                    [2020-08-15 17:22:14.450] [LOG] Connecting socket for: MMM-MyCalendar
                    [2020-08-15 17:22:14.452] [LOG] 2020-08-15T17:22:14 Starting node helper for: MMM-MyCalendar (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:19 Class.start)
                    [2020-08-15 17:22:14.453] [LOG] Connecting socket for: MMM-PIR-Sensor
                    [2020-08-15 17:22:14.453] [LOG] Sockets connected & modules started …
                    Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
                    [2020-08-15 17:22:14.665] [ERROR] Whoops! There was an uncaught exception…
                    [2020-08-15 17:22:14.668] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                    at listenInCluster (net.js:1274:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                    code: ‘EADDRINUSE’,
                    errno: ‘EADDRINUSE’,
                    syscall: ‘listen’,
                    address: ‘127.0.0.1’,
                    port: 8080
                    [2020-08-15 17:22:14.682] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-08-15 17:22:14.683] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-08-15 17:22:14.717] [LOG] Launching application.
                    ATTENTION: default value of option force_s3tc_enable overridden by environment.
                    [2020-08-15 17:22:43.588] [LOG] Shutting down server…
                      sdetweil @Matthew
                      @Matthew >[2020-08-15 17:22:14.668] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                      that happened on the 15th within 2 seconds of starting…
                      is that the right log?
                      that says something is already running … do you normally use pm2 to launch MM?
                      do pm2 status
                        Matthew @sdetweil
                          Matthew @sdetweil
                          @sdetweil its been a while since I set all of this up, but pm2 is the auto launch right? If so then yeah it always launches automatically
                            sdetweil @Matthew
                            @Matthew so, you can’t use it with the npm start…
                            as I said in the prior post, if you use pm2, then restart mm after adding the logging module (pm2 restart 0) and then see the logs with pm2 logs
                            pm2 logs --lines=100
                            or u can direct edit the logs in ~/.pm2/logs
                              Matthew @sdetweil
                              Im trying to reply with the logs, but it’s getting flagged as spam
                                sdetweil @Matthew
                                @Matthew u can mail them to me. same user ID on gmail
                                  Matthew @sdetweil
                                  sent! Thanks again!
                                    sdetweil @Matthew
                                    @Matthew replied
                                      Matthew @sdetweil
                                      Thanks! I must have lost that file somewhere. Ill get that added and see if I still have that problem.
