    MM Shows a plain Black Screen on iOS 9.3.5 device
    29 Posts 12 Posters 15.4k Views 11 Watching
      StevenSeagal
      Force close the app. Then upgrade your app may solve iPad screen black problem.
      Reply Quote -1
        spoonek
        This is still an issue.
        I have MM 2.12.0 and an iPad2 running 9.3.6 (the highest it will update to). The iPad2 gets the black screen when I go to MM http://ip-address:8080. My iphone 7 renders the page perfectly as do all of my Mac and PC laptops. I had an issue on an older laptop but updated the browser and that fixed it. I can’t update the browser on the iPad as the newer versions need iOS 10+. Any suggestions? Thanks!!
          sdetweil @spoonek
          @spoonek did u try chrome browser on the iPad?
            spoonek @sdetweil
            @sdetweil Yes, that is my default browser. I tried Safari as well, no luck. I then tried to install Firefox and got the same issue, needs version 10+. Thanks!! :clinking_beer_mugs:
              sdetweil @spoonek
              @spoonek if u have the black screen using chrome, open the dev window (see the menu) and select the console tab and scroll up to see any errors
                cony
                I guess this is the problem of iOS.
                Have you tried to update the iOS and the app? May be these will help:
                1.Update the iOS and the app to the latest version
                2. Force Restart iPhone to Fix iPhone
                3. Use iOS System Recovery to [fix iOS system free for mac](link url=“https://www.tuneskit.com/ios-system-recovery-for-mac.html”)
                4. Using iTunes to Fix
                  A Former User
                    magicx
                    Any news here for a workaround? Tried it with my iPad 2 (9.3.6) and different browsers… also installed the developer branch on my server.
                      sdetweil @magicx
                      @magicx no, and it will be harder in 2.15, as more code has been converted to es6 notation which the early ios browsers don’t support
