    MMM-MyCommute not showing up.
    31 Posts 4 Posters 15.5k Views 4 Watching
      spoonek @sdetweil
      @sdetweil said in MMM-MyCommute not showing up.:
      @spoonek use the menu to get the dev window open. or start with
      npm start dev
      if u normally use pm2, do pm2 stop 0
      before the npm start
      OK, that is awesome! Thanks for the tip! So maybe I need to generate a new api key and use that?
      [2020-08-20 09:07:14.680] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account
        sdetweil @spoonek
        @spoonek u didn’t list the maps api I the list of services above
          spoonek @sdetweil
          @sdetweil thanks. I don’t see it…
            sdetweil @spoonek
            @spoonek from the link on the module doc
            Maps JavaScript API
            from the image u posted,
            2nd row, second box from left
              spoonek @sdetweil
              @spoonek from the link on the moduledoc
              Maps JavaScript API
              Yep, got that one already. :(
                sdetweil @spoonek
                @spoonek so, then, passing the key is a problem,
                so it might be the item name in config. u can specify both,
                and u got the right string for the API key from Google.
                which GitHub module are u using?
                from the module folder do,
                git remote -v
                  spoonek @sdetweil
                  OK, I’ll add apikey and apiKey. I just generated a new key as well. Billing acct is active too.
                  pi@raspberrypi:~/MagicMirror/modules/MMM-MyCommute $ git remote -v
                  origin https://github.com/jclarke0000/MMM-MyCommute.git (fetch)
                  origin https://github.com/jclarke0000/MMM-MyCommute.git (push)
                    sdetweil @spoonek
                    @spoonek from the module folder
                      spoonek @sdetweil
                        spoonek @spoonek
                        @sdetweil Looking good now after adding both apikey and apiKey. Most likely me generating a new key as well. Thanks for the dev tips! Will be useful for me down the road.
                        S 2 Replies Last reply
                          sdetweil @spoonek
                          @spoonek his code uses all lowercase apikey
                            sdetweil @spoonek
                            @spoonek also, if you turn on ssh server on pi, and use winscp or bitvise ssh client, you can double click edit with your favorite windows editor (I use notepad++ for code alignment and indentation)
                            and still issue commands thru the ssh window…
                            if u set
                            address:"0.0.0.0",
                            ipWhitelist:[],
                            in config.js, then you can connect to mm with your windows chrome browser and do all the dev work there too…
