    MMM-MyCommute not showing up.
    31 Posts 4 Posters 15.1k Views 4 Watching
      sdetweil @spoonek
      @spoonek u didn’t list the maps api I the list of services above
       Google Maps Platform APIs
        spoonek @sdetweil
        @sdetweil thanks. I don’t see it…
          sdetweil @spoonek
          @spoonek from the link on the module doc
          Maps JavaScript API
          from the image u posted,
          2nd row, second box from left
            spoonek @sdetweil
            @sdetweil said in MMM-MyCommute not showing up.:
            @spoonek from the link on the moduledoc
            Maps JavaScript API
            Yep, got that one already. :(
              sdetweil @spoonek
              @spoonek so, then, passing the key is a problem,
              so it might be the item name in config. u can specify both,
              and u got the right string for the API key from Google.
              which GitHub module are u using?
              from the module folder do,
              git remote -v
                spoonek @sdetweil
                OK, I’ll add apikey and apiKey. I just generated a new key as well. Billing acct is active too.
                pi@raspberrypi:~/MagicMirror/modules/MMM-MyCommute $ git remote -v
                origin https://github.com/jclarke0000/MMM-MyCommute.git (fetch)
                origin https://github.com/jclarke0000/MMM-MyCommute.git (push)
                  sdetweil @spoonek
                  @spoonek from the module folder
                    spoonek @sdetweil
                      spoonek @spoonek
                      @sdetweil Looking good now after adding both apikey and apiKey. Most likely me generating a new key as well. Thanks for the dev tips! Will be useful for me down the road.
                        sdetweil @spoonek
                        @spoonek his code uses all lowercase apikey
                          sdetweil @spoonek
                          @spoonek also, if you turn on ssh server on pi, and use winscp or bitvise ssh client, you can double click edit with your favorite windows editor (I use notepad++ for code alignment and indentation)
                          and still issue commands thru the ssh window…
                          if u set
                          address:"0.0.0.0",
                          ipWhitelist:[],
                          in config.js, then you can connect to mm with your windows chrome browser and do all the dev work there too…
