    MMM-MyCommute not showing up.
    31 Posts 4 Posters 14.5k Views 4 Watching
      sdetweil @spoonek
      @spoonek no sync time. it’s immediate.
        spoonek @sdetweil
        @sdetweil said in MMM-MyCommute not showing up.:
        @spoonek use the menu to get the dev window open. or start with
        npm start dev
        if u normally use pm2, do pm2 stop 0
        before the npm start
        OK, that is awesome! Thanks for the tip! So maybe I need to generate a new api key and use that?
        [2020-08-20 09:07:14.680] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account
          sdetweil @spoonek
          @spoonek u didn’t list the maps api I the list of services above
            spoonek @sdetweil
            @sdetweil thanks. I don’t see it…
              sdetweil @spoonek
              @spoonek from the link on the module doc
              Maps JavaScript API
              from the image u posted,
              2nd row, second box from left
                spoonek @sdetweil
                @spoonek from the link on the moduledoc
                Maps JavaScript API
                Yep, got that one already. :(
                  sdetweil @spoonek
                  @spoonek so, then, passing the key is a problem,
                  so it might be the item name in config. u can specify both,
                  and u got the right string for the API key from Google.
                  which GitHub module are u using?
                  from the module folder do,
                  git remote -v
                    spoonek @sdetweil
                    OK, I’ll add apikey and apiKey. I just generated a new key as well. Billing acct is active too.
                    pi@raspberrypi:~/MagicMirror/modules/MMM-MyCommute $ git remote -v
                    origin https://github.com/jclarke0000/MMM-MyCommute.git (fetch)
                    origin https://github.com/jclarke0000/MMM-MyCommute.git (push)
                      sdetweil @spoonek
                      @spoonek from the module folder
                        spoonek @sdetweil
                          spoonek @spoonek
                          @sdetweil Looking good now after adding both apikey and apiKey. Most likely me generating a new key as well. Thanks for the dev tips! Will be useful for me down the road.
                            sdetweil @spoonek
                            @spoonek his code uses all lowercase apikey
                              sdetweil @spoonek
                              @spoonek also, if you turn on ssh server on pi, and use winscp or bitvise ssh client, you can double click edit with your favorite windows editor (I use notepad++ for code alignment and indentation)
                              and still issue commands thru the ssh window…
                              if u set
                              address:"0.0.0.0",
                              ipWhitelist:[],
                              in config.js, then you can connect to mm with your windows chrome browser and do all the dev work there too…
