    Config file missing but no syntax errors?
    8 Posts 3 Posters 988 Views 3 Watching
    • W Offline
      Wenike
      Its the standard image or text when launching MagicMirror of no config file being installed. I don’t know how to take a screenshot on the Pi, so camera picture it is!
      No config file error
        raymondjspigot
        Hi @Wenike in your MMM-Carousel config it looks like you have
        mode: global,
        which might need to be quoted? i.e.
        mode: 'global',
        S W 2 Replies Last reply Reply Quote 1
          sdetweil @Wenike
          @Wenike on the console where u did npm start.
            sdetweil @raymondjspigot
            @raymondjspigot good catch!
            I copied the config and this is the cause
            i also noted that the checker didn’t find this,
            not sure why…
              sdetweil @Wenike
              @Wenike the general rules for config.js
              for the value to the right of :
              numbers and true/false are not quoted,
              everything else is, doesn’t matter which type, single or double, as long as they match
              for the trailing comma on a line,
              if the next line starts with a word, then this line needs a trailing comma (more coming)
              • W Offline
                Wenike @raymondjspigot
                @raymondjspigot Thanks! That fixed it!
