    difference between MMM-awesome-alexa and MMM-Alexa
    8 Posts 5 Posters 1.4k Views 5 Watching
      RIKKO14
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @RIKKO14
        @RIKKO14 Hey there is a another module that should work with amazon echo and google device
        MMM-AlexaControl
        that works much more easyer than the others…
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe but, you must have a real echo device for alexaControl
          @RIKKO14 you must sign up and create a device for the other Alexa modules.
          they are two different implementations of the same idea. all the voice modules take a bit of work to get going
            radioman
            Hello
            Ihave installd the modul mmm-Alexa and MMM-OnScreenModul.
            I Have entering the Code into the Config like this
                        module: 'MMM-OnScreenMenu',
                        position: 'bottom_right',
                        module: 'MMM-AlexaOnOff',
                           devices: [{
                              on: {
                              notification: "ONSCREENMENU_PROCESS_ACTION",
                               payload: { actionName:'monitorOn' }
                              off: {
                              payload: { actionName:'monitorOff' }
            Then i Have seach for new Devices in the Alexa App on my Smartphone.
            But Alexa find nothing.
            Can Anyone help me?
              sdetweil @radioman
              @radioman I do not know. alexaOnOff says it is no longer under active development.
              I use MMM-AlexaControl to do the same as both those modules.
              while it works for me (I have a v1 echo), others have not had success.
                pvancald
                I just installed MMM-AlexaControl with success (with Echo 5)
                It was really easy.
                Followed the instructions from the first page on git and put the basic configuration in config.js…
                Then went to alexa.amazon.com in order to scan for new devices, it found directly the devicename I put in the basic config.
                My aim was to jump to a specific slide on MMM-Carousel by talking to Alexa.
                This slide is the first one and containing an MMM-CalendarExt2.
                Here is the configuration I used if it can help someone :
                    module: 'MMM-AlexaControl',
                    position: 'middle_center',
                    config:{
                      deviceName: "Miroir",
                      image: false,
                      pm2ProcessName: "mm",
                      monitorToggle: false,
                      vcgencmd: true,
                      notifications: [
                           port: 11100,
                           OnOff: false,
                           notification: ["CAROUSEL_GOTO", 1]
                Now, I can just say to Alexa (in french sorry…)
                Alexa allume miroir menu
                and it jumps to the correct slide rather than having to wait the cycle between all slides of the carousel.
                S 2 Replies Last reply Reply Quote 1
                  sdetweil @pvancald
                  @pvancald very nice
                    sdetweil @pvancald
                    @pvancald you can scan for devices directly w your Alexa device.
                    alexa scan for devices
                    or
                    alexa discover devices
