How to write and test CSS without going crazy..
Hey everyone,
first post here so apologies if I’ve got some etiquite wrong or not been able to find a previous post that covers this.
I’d like to get into customising the font, size etc. of my mirror and modules, but don’t know how to get a live ‘preview’ of the Mirror as I’m writing the code? I’ve recently learned CSS on Codepen, so I’m used to having the instant feedback…
Can i run a windowed version of MagicMirror and change the CSS file? Is this an awful idea?
Open to all suggestions!
@cluelesscarter not windowed, but you can minimize. alt, spacebar, n. same as on windows.
but, if u open the developers window ctrl-shift-i on the keyboard, and select the elements tab, u can edit the styles directly. and then you know what to.put in css/custom.css. then u can reload with ctrl-r or refresh in the developers pane
@sdetweil said in How to write and test CSS without going crazy..:
but, if u open the developers window ctrl-shift-i on the keyboard, and select the elements tab, u can edit the styles directly. and then you know what to.put in css/custom.css. then u can reload with ctrl-r or refresh in the developer’s paneThanks man! I actually found creating a ‘clone’ mirror on my desktop and editing it using localhost within chrome was a lot quicker, if anyone wants to find out how see this guide https://forum.magicmirror.builders/topic/548/building-mirror-without-programing/2
@cluelesscarter can u describe that again.
clone mirror on your desktop?
if u have the config set to
address:"0.0.0.0", ipWhitelist:[],then u can open your PC browser on the pi mm site http://pi_ip:8080
if u install winscp or bitvise ssh client on your PC, then u can double click edit files on your pi, just like u do on windows.
so u can run mm on pi, view and edit styles on chrome/Firefox on PC, edit pi custom.css directly from PC, over ssh ( I use notepad++ as my PC editor), save custom.css, then refresh browser page to see new styles applied via custom.css
all with only one copy of MagicMirror installed.
all with only one copy of MagicMirror installed.Nice! I hadn’t figured out how to edit the rpi files directly from PC without using VNC, which effectively means you are still using the pi… Thanks!
By ‘clone’, i meant there were effectively two completely seperate versions of the MM running…
If anyone is looking at this issue in the future and trying to do this on Mac see here: https://www.raspberrypi.org/documentation/remote-access/ssh/sshfs.md
