    Hide Rain-Modul with MMM-Alexa-Control and MMM-Remote-Control
    8 Posts 2 Posters 1.5k Views 3 Watching
      sdetweil @radioman
      @radioman you would have to make a custom device with your action
        radioman
        I don’t know what you mean by costum device
        Can you give me a code example or can I do it like that
        notifications: [
                port: 11101,
                OnOff: true,
                notification: [["NOTIFICATION ON", "PAYLOAD ON"],["NOTIFICATION OFF", "PAYLOAD OFF"]]
        Then the question what does a notification and a payload look like in my case
        I got this example from the Githup Homepage with the MMM-Alexa control module
          sdetweil @radioman
          @radioman you didn’t read the rest
          Notification devices
          Notification devices allows you to send notifications to other modules.
          You can send the same notification when you turn the device on and off like this:
          Note: You have to put the notifications array you chose inside the config part.
          notifications: [
                  port: 11100,
                  OnOff: false,
                  notification: ["NOTIFICATION", "PAYLOAD"]
          You can send different notifications when you turn a device on or off like this:
          notifications: [
                  port: 11101,
                  OnOff: true,
          Note: NOTIFICATION ON and NOTIFICATION OFF stay for the different notifications you can send when you turn on or off the device. The same thing applies to PAYLOAD ON and PAYLOAD OFF.
          These are the configuration options for a notification device:  / < ===================================
          Note: They are all necessary.
          Option	Description
          name	Here you can name your device. Make sure you didn't used the name before. Delete first the old device.
          port	Here you can give the device a static Port. I suggest that to you because then there aren't overlaps. Preferably start with the port 11100.
          OnOff	If you want to send the same notification when you turn a device on and off chose true. Otherwise if you want to send different notifications chose false.
          Possible values: true and false
          notification	If OnOff is true:
          notification: [["NOTIFICATION ON","PAYLOAD"],["NOTIFICATION OFF", "PAYLOAD"]]
          Replace the notifications and the payloads.
          If OnOff is false:
          Replace the notification and payload.
          further down there is a Command Device
          and beyond that is Custom Device
            @radioman
            and he provided a sample for a notification device in the config section of the module def
            notifications: [
                    port: 11101,
                    OnOff: true,
            so a sample config with this
            			module: "MMM-AlexaControl",
            			disabled: false,
            			position: "bottom_left",
            				deviceName: "desk",
            				image: false,
            				pm2ProcessName: "MagicMirror",
            				vcgencmd: "hide",
            				monitorToggle: true,
            				startPort: 16000,
            				reboot: true,
            				shutdown: true,
            				stop: true,
                                            notifications: [
                                                               port: 11101,
                                                               OnOff: true,
            and u have
            if (notification === 'HIDE_RADAR') {
            this.hide (1000);
            } else if (notification === 'SHOW_RADAR') {
            this.show (1000);
            remember this is a dumb electric outlet, on or off, what do you want to send when?
            so I assume as u have no payload check
            on = HIDE_RADAR, and off means SHOW_RADAR
             notification: [["HIDE_RADAR", null],["SHOW_RADAR", null]]
              radioman
              Ok, I have now entered that
                          module: 'MMM-AlexaControl',
                          position: 'bottom_left',
                          config:{
                              image: false,
                              pm2ProcessName: "mm",
                              refresh: true,
                              restart: true,
                              reboot: false,
                              vcgencmd: 'vcgencmd',
                              deviceName: "Spiegel",
                              startPort: 12000,
                                 notifications: [
                      port: 12101,
                      OnOff: true,
                      notification: [["NOTIFICATION ON", "SHOW_RADAR"],["NOTIFICATION OFF", "HIDE_RADAR"]]
              Alexa also finds a device but I can’t control it
              What would I have to enter with notificaton and with Payload
              Or am I not allowed to change the payload
                sdetweil @radioman
                @radioman I gave u the sample above w your notification!?
                and you say Alexa turn off Radar, or Alexa turn on Radar
                it’s an outlet device on or off
                  radioman
                  OK
                  I read your post again carefully and have now understood it
                  and it works.
                  Many thanks
