    Read only config.js
    9 Posts 3 Posters 2.0k Views 3 Watching
    • H Offline
      hyboi
      Hi all,
      I did do a bit of a search but didn’t see anything.
      I’ve installed MM into a docker with portainer.
      I’ve done to enable my first module but the config.js file is read only.
      Any thoughts? I did stop MM running in portainer.
        sdetweil @hyboi
        @hyboi is it read only, or owned by nother user?
        • H Offline
          hyboi
          I wasn’t in root (facepalm).
            Plainbroke 0
            Sam,
            How would I check if it is read only? Or owned by another user?
              sdetweil @Plainbroke 0
              @Plainbroke-0 ls -laF filename
              shows user and permissions
                sdetweil @hyboi
                @hyboi should never be in root
                  Plainbroke 0 @sdetweil
                  Thank you.
                    @Plainbroke-0
                    sam@sams_laptop:~/MagicMirror/config$ ls -laF
                    total 24
                    drwxrwxr-x  2 sam sam 4096 Aug  4 19:08 ./
                    drwxrwxr-x 17 sam sam 4096 Sep  1 01:25 ../
                    -rw-rw-r--  1 sam sam 5965 Sep  1 19:28 config.js
                    -rw-rw-r--  1 sam sam 3258 Jul  5 21:20 config.js.sample
                    -rw-rw-r--  1 sam sam   20 Mar 13 18:24 .gitignore
                    there is the d bit, means directory
                    then three groups of permissions
                    user
                    group
                    other
                    r readable
                    w writable
                    x executable
                    (don’t know number)
                    user and then group
                    size
                    last modified
                    filename
                      @sdetweil Here is mine and it looks like it is read write enabled.
                      pi@pi:~/MagicMirror/css $ ls -laF
                      total 36
                      drwxr-xr-x 2 pi pi 4096 Sep 1 19:13 ./
                      drwxr-xr-x 17 pi pi 4096 Aug 25 15:48 …/
                      -rw-r–r-- 1 pi pi 12232 Sep 1 19:13 custom.css
                      -rw-r–r-- 1 pi pi 9032 Jul 14 01:01 custom.css.save
                      -rw-r–r-- 1 pi pi 2957 Jul 13 11:53 main.css
                      pi@pi:~/MagicMirror/css $ cd …
                      pi@pi:~/MagicMirror $ cd config
                      pi@pi:~/MagicMirror/config $ ls -laF
                      total 32
                      drwxr-xr-x 2 pi pi 4096 Sep 1 19:14 ./
                      -rw-r–r-- 1 pi pi 8196 Sep 1 15:57 config.js
                      -rw-r–r-- 1 pi pi 3258 Jul 13 11:53 config.js.sample
                      -rw-r–r-- 1 pi pi 3305 Jun 15 16:17 configOriginal.js
                      -rw-r–r-- 1 pi pi 20 Jun 15 16:17 .gitignore
