    SD memory card is slowly filling up
    12 Posts 2 Posters 3.8k Views 2 Watching
      drx1984
      it looks like this
        sdetweil @drx1984
        @drx1984 clear the logs. pm2 flush
        altho I might want to find out what all that is.
        u can dump a little
        pm2 logs --lines=???
        ???= some number, default is 15
        u can also.look at them in the ~/.pm2/logs
        folder
          drx1984
          how do I do that? (I’m a beginner sry)
          can I turn off the log?
          how do i get to the pm2 folder? that should be in the “root” folder right? somehow I have no notice.
            drx1984 @sdetweil
            I was able to do something and I found this post:
            https://forum.magicmirror.builders/topic/917/pm2-logs/7
            I then entered the command “pm2 flush” and I already have 21GB of free space again, that looks very good.
            could I automate something like that? or deactivate the pm2 log?
              sdetweil @drx1984
              @drx1984 I gave u the pm2 flush command
              if u install winscp on your pc box, and enable ssh on your pi, you can get a file manager.over the pi files from your pc
              then just double click to edit like u do on the pc. right click to rename/delete
              I would have looked at the log to find out what modules are generating all that content.
              far as I know there is no way to turn off the log.
              maybe
              pm2 help
              would some some options
                @drx1984
                also file location
                means users home folder
                so when logged on as pi, that means
                /home/pi
                so from my post
                ~/.pm2/logs means
                /home/pi/.pm2/logs
                u can get there over ssh, or using a terminal window on the pi, or a file manager on the pi, just like u do on widows
                  drx1984 @sdetweil
                  yes I had already installed the program WinSCP, but I don’t see this folder pm2 ??? ( see image)
                  Yes that would be interesting which modules cause these logs. next time I won’t just delete it.
                    drx1984 @drx1984
                    @drx1984 said in SD memory card is slowly filling up:
                    ah it was hidden all clear, thank you
                      drx1984 @drx1984
                      I saw that there is a tool for deleting the pm2 log, do you know it: https://github.com/keymetrics/pm2-logrotate
                        sdetweil @drx1984
                        @drx1984 no. but looks interesting
                        as for hidden, for others, see
                        https://winscp.net/forum/viewtopic.php?t=24963
