    Default clock is not displayed correctly after MM update
    7 Posts 3 Posters 1.0k Views 2 Watching
      drx1984
      Hello everybody,
      just did a MM update.
      Unfortunately the clock module is no longer displayed correctly.
      My default clock has a “face-007”, no other “faces” work
      Where would the problem be ???
      thanks
        A Former User
          drx1984 @Guest
          @hango this solution does not solve my problem.
            A Former User
              drx1984 @Guest
              @hango It worked great, I replaced the old “clock” folder.
              now I see the faces, thank you very much
                sdetweil @drx1984
                @drx1984 I fixed the instructions to remove the package-lock.json file
                  drx1984 @sdetweil
                  @sdetweil said in Default clock is not displayed correctly after MM update:
                  OK thank you
