    MMM-sort wont load help needed
    9 Posts 2 Posters 1.6k Views 2 Watching
    • G Offline
      gauka12345
      ![alt text](image url)Hi every one…
      i have got an issue with MMM-SORT - the module wont load,
      is stuck on ( first the tide rushes in… )
      does anyone know why this is happened. i have valid key and also bough a credits so it should work correctly.
        sdetweil @gauka12345
        @gauka12345 what might be shown on the console where u started mm, npm start, or the pm2 console, shown w pm2 logs --lines=???
        ??? is a number, defaults to 15
        also may find info in the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
        u can also filter by module, by placing a part of the module name in the filter field, sort, for example
        • G Offline
          gauka12345
          Hi Sam, please see below :
          i@raspberrypi:~/MagicMirror $ npm start
          magicmirror@2.12.0 start /home/pi/MagicMirror
          [2020-09-06 18:45:02.435] [LOG] Starting MagicMirror: v2.12.0
          [2020-09-06 18:45:04.939] [LOG] Loading config …
          [2020-09-06 18:45:05.050] [LOG] Loading module helpers …
          [2020-09-06 18:45:05.115] [LOG] No helper found for module: alert.
          [2020-09-06 18:45:05.127] [LOG] No helper found for module: clock.
          [2020-09-06 18:45:29.773] [LOG] Initializing new module helper …
          [2020-09-06 18:45:29.931] [LOG] Module helper loaded: MMM-DarkSkyForecast
          [2020-09-06 18:46:00.633] [LOG] Initializing new module helper …
          [2020-09-06 18:46:00.802] [LOG] Module helper loaded: MMM-SORT
          [2020-09-06 18:46:01.052] [LOG] No helper found for module: MMM-xiaomi.
          [2020-09-06 18:46:01.058] [LOG] No helper found for module: MMM-Remote-Control.
          [2020-09-06 18:46:01.062] [LOG] No helper found for module: MMM-NetworkConnection.
          [2020-09-06 18:46:01.281] [LOG] No helper found for module: MMM-WorldTides.
          [2020-09-06 18:46:01.296] [LOG] No helper found for module: MMM-Lunartic.
          [2020-09-06 18:46:01.301] [LOG] No helper found for module: calendar_monthly.
          [2020-09-06 18:46:06.074] [LOG] Initializing new module helper …
          [2020-09-06 18:46:06.076] [LOG] Module helper loaded: calendar
          [2020-09-06 18:46:06.157] [LOG] No helper found for module: MMM-AirQuality.
          [2020-09-06 18:46:07.196] [LOG] Initializing new module helper …
          [2020-09-06 18:46:07.201] [LOG] Module helper loaded: newsfeed
          [2020-09-06 18:46:07.204] [LOG] All module helpers loaded.
          [2020-09-06 18:46:14.610] [LOG] Starting server on port 8080 …
          [2020-09-06 18:46:15.474] [LOG] Server started …
          [2020-09-06 18:46:15.477] [LOG] Connecting socket for: MMM-DarkSkyForecast
          [2020-09-06 18:46:15.480] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
          [2020-09-06 18:46:15.481] [LOG] Connecting socket for: MMM-SORT
          [2020-09-06 18:46:15.483] [LOG] Starting node_helper for: MMM-SORT
          [2020-09-06 18:46:15.484] [LOG] Connecting socket for: calendar
          [2020-09-06 18:46:15.488] [LOG] Starting node helper for: calendar
          [2020-09-06 18:46:15.495] [LOG] Connecting socket for: newsfeed
          [2020-09-06 18:46:15.498] [LOG] Starting node helper for: newsfeed
          [2020-09-06 18:46:15.504] [LOG] Sockets connected & modules started …
          [2020-09-06 18:46:28.584] [ERROR] Whoops! There was an uncaught exception…
          [2020-09-06 18:46:28.598] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
          code: ‘EADDRINUSE’,
          errno: ‘EADDRINUSE’,
          syscall: ‘listen’,
          address: ‘127.0.0.1’,
          port: 8080
          [2020-09-06 18:46:28.810] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-09-06 18:46:28.819] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-09-06 18:46:28.911] [LOG] Launching application.
            @gauka12345 sounds like u are using pm2, and it started at boot. do
            pm2 status
            pm2 stop 0
            • G Offline
              gauka12345
              Hi Sam,
              pi@raspberrypi:~ $ pm2 status
              bash: pm2: command not found
              pi@raspberrypi:~ $ sudo pm2 status
              sudo: pm2: command not found
              pi@raspberrypi:~ $ pm2 stop 0
              pi@raspberrypi:~ $
                @gauka12345 hm
                something else is using port 8080
                sudo netstat -a | grep 8080
                • G Offline
                  gauka12345
                  thank you Sam ,
                  hmm, i have got a XRPD running on this pi , so i could access it from my main PC
                  also i have got another pi connected as the retro PI
                  with the script nothing is happening
                  pi@raspberrypi:~ $ sudo netstat -a | grep 8080
                  pi@raspberrypi:~ $
                    @gauka12345 well something is using port 8080
                    try moving mm to 8090
                    edit the port in config.js
                    • G Offline
                      gauka12345
                      Sam, you are totally right by changing the port number it fixed the issue ;-)
                      thanks you are genius!
                      Kind regards
                      Lukas
