MMM-sort wont load help needed
Hi every one…
i have got an issue with MMM-SORT - the module wont load,
is stuck on ( first the tide rushes in… )
does anyone know why this is happened. i have valid key and also bough a credits so it should work correctly.
@gauka12345 what might be shown on the console where u started mm, npm start, or the pm2 console, shown w pm2 logs --lines=???
??? is a number, defaults to 15
also may find info in the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
u can also filter by module, by placing a part of the module name in the filter field, sort, for example
Hi Sam, please see below :
i@raspberrypi:~/MagicMirror $ npm start
magicmirror@2.12.0 start /home/pi/MagicMirror
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[2020-09-06 18:45:02.435] [LOG] Starting MagicMirror: v2.12.0
[2020-09-06 18:45:04.939] [LOG] Loading config …
[2020-09-06 18:45:05.050] [LOG] Loading module helpers …
[2020-09-06 18:45:05.115] [LOG] No helper found for module: alert.
[2020-09-06 18:45:05.127] [LOG] No helper found for module: clock.
[2020-09-06 18:45:29.773] [LOG] Initializing new module helper …
[2020-09-06 18:45:29.931] [LOG] Module helper loaded: MMM-DarkSkyForecast
[2020-09-06 18:46:00.633] [LOG] Initializing new module helper …
[2020-09-06 18:46:00.802] [LOG] Module helper loaded: MMM-SORT
[2020-09-06 18:46:01.052] [LOG] No helper found for module: MMM-xiaomi.
[2020-09-06 18:46:01.058] [LOG] No helper found for module: MMM-Remote-Control.
[2020-09-06 18:46:01.062] [LOG] No helper found for module: MMM-NetworkConnection.
[2020-09-06 18:46:01.281] [LOG] No helper found for module: MMM-WorldTides.
[2020-09-06 18:46:01.296] [LOG] No helper found for module: MMM-Lunartic.
[2020-09-06 18:46:01.301] [LOG] No helper found for module: calendar_monthly.
[2020-09-06 18:46:06.074] [LOG] Initializing new module helper …
[2020-09-06 18:46:06.076] [LOG] Module helper loaded: calendar
[2020-09-06 18:46:06.157] [LOG] No helper found for module: MMM-AirQuality.
[2020-09-06 18:46:07.196] [LOG] Initializing new module helper …
[2020-09-06 18:46:07.201] [LOG] Module helper loaded: newsfeed
[2020-09-06 18:46:07.204] [LOG] All module helpers loaded.
[2020-09-06 18:46:14.610] [LOG] Starting server on port 8080 …
[2020-09-06 18:46:15.474] [LOG] Server started …
[2020-09-06 18:46:15.477] [LOG] Connecting socket for: MMM-DarkSkyForecast
[2020-09-06 18:46:15.480] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
[2020-09-06 18:46:15.481] [LOG] Connecting socket for: MMM-SORT
[2020-09-06 18:46:15.483] [LOG] Starting node_helper for: MMM-SORT
[2020-09-06 18:46:15.484] [LOG] Connecting socket for: calendar
[2020-09-06 18:46:15.488] [LOG] Starting node helper for: calendar
[2020-09-06 18:46:15.495] [LOG] Connecting socket for: newsfeed
[2020-09-06 18:46:15.498] [LOG] Starting node helper for: newsfeed
[2020-09-06 18:46:15.504] [LOG] Sockets connected & modules started …
[2020-09-06 18:46:28.584] [ERROR] Whoops! There was an uncaught exception…
[2020-09-06 18:46:28.598] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
at Server.setupListenHandle [as _listen2] (net.js:1226:14)
at listenInCluster (net.js:1274:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
code: ‘EADDRINUSE’,
errno: ‘EADDRINUSE’,
syscall: ‘listen’,
address: ‘127.0.0.1’,
port: 8080
[2020-09-06 18:46:28.810] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-09-06 18:46:28.819] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[2020-09-06 18:46:28.911] [LOG] Launching application. -
@gauka12345 sounds like u are using pm2, and it started at boot. do
pm2 status
pm2 stop 0 -
Hi Sam,
pi@raspberrypi:~ $ pm2 status
bash: pm2: command not found
pi@raspberrypi:~ $ sudo pm2 status
sudo: pm2: command not found
pi@raspberrypi:~ $ pm2 stop 0
pi@raspberrypi:~ $ -
thank you Sam ,
hmm, i have got a XRPD running on this pi , so i could access it from my main PC
also i have got another pi connected as the retro PI
with the script nothing is happening
pi@raspberrypi:~ $ sudo netstat -a | grep 8080
Sam, you are totally right by changing the port number it fixed the issue ;-)
thanks you are genius!Kind regards
Lukas
