    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 15.1k Views 4 Watching
      Ameyalgudkar @sdetweil
      @sdetweil yes those steps.
      The one I am referring to is 4th to last.
        @Ameyalgudkar said in MMM Awesome Alexa installing snowboy.:
        5.4.51-v7l+
        are u trying to install on 64bit RaspiOS?
        my PI’s are running kernel 4.19 on 32bit raspiOS
        A 2 Replies Last reply Reply Quote 0
          @sdetweil I believe I’m on 5.4.51 kernel but not sure if that’s the one. and don’t know if 32/64 bit.
            sdetweil @Ameyalgudkar
            @Ameyalgudkar no idea if it will work
              there.
              and if there’s a way to run it on 4.19 then how do I downgrade?
                @Ameyalgudkar no idea… i see the latest images are all at kernel 5.4
                https://www.raspberrypi.org/downloads/raspberry-pi-os/
                  @sdetweil If you could make a copy of your image file or if you have it saved on your disk maybe?
                  could you upload it to google cloud or something?
                    @Ameyalgudkar see the chat messages I sent you
                      A Former User
                      @sdetweil :
                      I confirm new update of RPI are now in 5.4.x kernel
                      bugs@debian:~/MagicMirror/modules$ ssh pi@192.168.X.XX
                      pi@192.168.X.XX's password:
                      Linux Raspberry 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l
                      I have not see :)
                      my npm library can make the build of @bugsounet/snowboy
                      pi@Raspberry:~/MagicMirror/modules/MMM-Spotify $ npm install @bugsounet/snowboy
                      > @bugsounet/snowboy@1.6.2 install /home/pi/MagicMirror/modules/MMM-Spotify/node_modules/@bugsounet/snowboy
                      > bash scripts/installer.sh
                      make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
                        CXX(target) Release/obj.target/snowboy/lib/snowboy.o
                        SOLINK_MODULE(target) Release/obj.target/snowboy.node
                        COPY Release/snowboy.node
                        COPY /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node
                        TOUCH Release/obj.target/action_after_build.stamp
                      make : on quitte le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
                      [@bugsounet/snowboy] Do you want to execute electron rebuild ? [Y/n]
                      Your choice: y
                      ✔ Rebuild Complete
                      > @bugsounet/snowboy@1.6.2 postinstall /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy
                      > tsc -p tsconfig.json
                      + @bugsounet/snowboy@1.6.2
                      added 187 packages from 137 contributors and audited 190 packages in 107.058s
                      4 packages are looking for funding
                        run `npm fund` for details
                      found 0 vulnerabilities
                      after official version, i don’t know…
                      it’s always been a bit boring to do a build correctly…
                      @Ameyalgudkar:
                      I see in the error log it’s an x64 build…
                      In MagicMirror requirement it’s specified to download the lasted version of raspbian with desktop
                      The official website is https://www.raspberrypi.org/ and on the download page there no x64 version
                      So you use a beta version with … beta bugs and Complex Module of MagicMirror don’t support x64 version.
                      Best way ?
                      Like windows and others OS you can’t transform x64 to 32bits (and 32bits to x64 too)
                      so best way is reinstall OS with 32bits version
                      @bugsounet
                      S A 2 Replies Last reply Reply Quote 0
                        sdetweil @Guest
                        @Bugsounet he is doing on pi, System Linux 5.4.51-v7l+ < — v7l
                        i am going to test ubuntu pi 64 bit tomorrow.
                        couldn’t wait…
                        fix
                        need to install libcblas
                        sudo apt-get install libatlas-base-dev
                        then both my installations using snowboy correctly rebuilt… on ubuntu 64 on pi4.
                        • 1 / 5
