    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 19.4k Views 4 Watching
      sdetweil @Ameyalgudkar
      @Ameyalgudkar these steps, right?
      https://awesome-alexa.js.org/#/installation,
      Step 2. Install Module
      A 1 Reply Last reply
      • A
        Ameyalgudkar @sdetweil
        @sdetweil yes those steps.
        The one I am referring to is 4th to last.
          @Ameyalgudkar said in MMM Awesome Alexa installing snowboy.:
          5.4.51-v7l+
          are u trying to install on 64bit RaspiOS?
          my PI’s are running kernel 4.19 on 32bit raspiOS
          A 2 Replies Last reply
          • A
            @sdetweil I believe I’m on 5.4.51 kernel but not sure if that’s the one. and don’t know if 32/64 bit.
              @Ameyalgudkar no idea if it will work
              • A
                there.
                and if there’s a way to run it on 4.19 then how do I downgrade?
                  @Ameyalgudkar no idea… i see the latest images are all at kernel 5.4
                  https://www.raspberrypi.org/downloads/raspberry-pi-os/
                  • A
                    @sdetweil If you could make a copy of your image file or if you have it saved on your disk maybe?
                    could you upload it to google cloud or something?
                      @Ameyalgudkar see the chat messages I sent you
                        A Former User
                        @sdetweil :
                        I confirm new update of RPI are now in 5.4.x kernel
                        bugs@debian:~/MagicMirror/modules$ ssh pi@192.168.X.XX
                        pi@192.168.X.XX's password:
                        Linux Raspberry 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l
                        I have not see :)
                        my npm library can make the build of @bugsounet/snowboy
                        pi@Raspberry:~/MagicMirror/modules/MMM-Spotify $ npm install @bugsounet/snowboy
                        > @bugsounet/snowboy@1.6.2 install /home/pi/MagicMirror/modules/MMM-Spotify/node_modules/@bugsounet/snowboy
                        > bash scripts/installer.sh
                        make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
                          CXX(target) Release/obj.target/snowboy/lib/snowboy.o
                          SOLINK_MODULE(target) Release/obj.target/snowboy.node
                          COPY Release/snowboy.node
                          COPY /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node
                          TOUCH Release/obj.target/action_after_build.stamp
                        make : on quitte le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
                        [@bugsounet/snowboy] Do you want to execute electron rebuild ? [Y/n]
                        Your choice: y
                        ✔ Rebuild Complete
                        > @bugsounet/snowboy@1.6.2 postinstall /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy
                        > tsc -p tsconfig.json
                        + @bugsounet/snowboy@1.6.2
                        added 187 packages from 137 contributors and audited 190 packages in 107.058s
                        4 packages are looking for funding
                          run `npm fund` for details
                        found 0 vulnerabilities
                        after official version, i don’t know…
                        it’s always been a bit boring to do a build correctly…
                        @Ameyalgudkar:
                        I see in the error log it’s an x64 build…
                        In MagicMirror requirement it’s specified to download the lasted version of raspbian with desktop
                        The official website is https://www.raspberrypi.org/ and on the download page there no x64 version
                        So you use a beta version with … beta bugs and Complex Module of MagicMirror don’t support x64 version.
                        Best way ?
                        Like windows and others OS you can’t transform x64 to 32bits (and 32bits to x64 too)
                        so best way is reinstall OS with 32bits version
                        @bugsounet
                        S A 2 Replies Last reply
                          sdetweil @Guest
                          @Bugsounet he is doing on pi, System Linux 5.4.51-v7l+ < — v7l
                          i am going to test ubuntu pi 64 bit tomorrow.
                          couldn’t wait…
                          fix
                          need to install libcblas
                          sudo apt-get install libatlas-base-dev
                          then both my installations using snowboy correctly rebuilt… on ubuntu 64 on pi4.
                            A Former User
                            ah… that’s why my library have no problem for installing :)
                            I force it to install with installer lol :)
                            nedeed dependencies
                            • A
                              Ameyalgudkar @Guest
                              @Bugsounet said in MMM Awesome Alexa installing snowboy.:
                              @Ameyalgudkar:
                              I am indeed running the 32bit Raspberry Pi OS latest from the official downloads, and not any beta versions.
                              I don’t know why the installer is running it in x64.
                              • A
                                Ameyalgudkar
                                Also now I am facing this problem where, no matter what I do, RPI4 does not take any other sd card boot image and boot that particular system.
                                For instance, My 32gb with working MM and RPI OS 32bit, boot up without any problem.
                                But then, I tried booting with a older build of RPI OS, Ubuntu(https://ubuntu.com/download/raspberry-pi) 32bit for Pi4.
                                Both tried on different sd cards with 8gb/32gb and also reformatting it several times and everything.
                                I feel just so exhausted doing all this and thinking of returning my RPI4 if it has so may issues.
                                  A Former User
                                  internal firmware :) (eeprom)
                                    sdetweil @Guest
                                    @Bugsounet doesn’t the newer system apply the firmware update automatically?
                                    see here for the firmware test and update procedure
                                    https://www.raspberrypi.org/documentation/hardware/raspberrypi/booteeprom.md
                                    • A
                                      @sdetweil I tried the boot recovery mentioned in the link, but no luck with that. Still gets stuck in boot and with a red light. no green light. should I try to get a replacement for my device?
                                      S 2 Replies Last reply
                                        @Ameyalgudkar I would guess yes
                                          A Former User
                                          and Recovery ?
                                            @Ameyalgudkar this procedure to verify and then fix
                                            Is the bootloader working correctly?
                                            To check that the bootloader is working correctly, turn off the power, unplug everything from the Raspberry Pi 4, including the SD card, and then turn the power back on. If the green LED blinks with a repeating pattern then the bootloader is running correctly, and indicating that start*.elf has not been found. Any other actions imply that the bootloader is not working correctly and should be reinstalled using recovery.bin.
                                            Recovery image
                                            If the Raspberry Pi is not booting it's possible that the bootloader EEPROM is corrupted. This can easily be reprogrammed using the Raspberry Pi Imager tool which is available via the raspberrypi.org downloads page.
                                            Using the recovery image will erase any custom configuration options, resetting the bootloader back to factory defaults.
                                            Updating the bootloader
                                            Bootloader updates are instigated during a normal apt update, apt full-upgrade cycle, this means you will get new features and bug fixes during your normal updates.
                                            Bootloader updates are performed by the rpi-eeprom package, which installs a service that runs at boot-time to check for critical updates.
                                            To update your system, including the bootloader:
                                            sudo apt update
                                            sudo apt full-upgrade
                                            sudo reboot
                                            and the bootloader recovery process is documented on the imager page, right?
