    Weather just won't show up...
    13 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @Stef
      @Stef what is the appid value?, you signed up for one, right,?
        Stef
        Sure
        I just don’t wanted to paste it here
          sdetweil @Stef
          @Stef ok, usually we use xxx so us trying to help know
          anyhow, if u look in the console where u start mm, npm start, or the logs if u use pm2
          pm2 logs --lines=???
          ??? is some number, default 15
          and also the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up see any errors.
            Stef @sdetweil
            @sdetweil yeah I know, but it was hard to copy the text from the juice ssh (android app) shell and posting it here… Total formatting screw up 😂
            I did a
            Pm2 flush
            Killed the magic mirror “app” and the log shows me:
            Linux mirrorpi2 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Thu Sep 10 07:42:22 2020 from 192.168.0.199
            pi@mirrorpi2:~ $ pm2 logs --lines=15
            /home/pi/.pm2/pm2.log last 15 lines:
            PM2        | 2020-09-10T08:26:30: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
            PM2        | 2020-09-10T08:26:30: PM2 log: Stopping app:MagicMirror id:1
            PM2        | 2020-09-10T08:26:31: PM2 log: pid=920 msg=failed to kill - retrying in 100ms
            PM2        | 2020-09-10T08:26:31: PM2 log: App [MagicMirror:1] exited with code [0] via signal [SIGINT]
            PM2        | 2020-09-10T08:26:31: PM2 log: pid=920 msg=process killed
            PM2        | 2020-09-10T08:26:31: PM2 log: App [MagicMirror:1] starting in -fork mode-
            PM2        | 2020-09-10T08:26:31: PM2 log: App [MagicMirror:1] online
            /home/pi/.pm2/logs/pm2-logrotate-out.log last 15 lines:
            /home/pi/.pm2/logs/pm2-logrotate-error.log last 15 lines:
            /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
            1|MagicMir | [2020-09-10 08:26:40.320] [ERROR]  ERROR! Could not find main module js file for MagicMirror-Display-Controller
            /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
            1|MagicMir | [2020-09-10 08:26:44.046] [LOG]    Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
            1|MagicMir | [2020-09-10 08:26:44.144] [LOG]    Create new news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen - Interval: 300000
            1|MagicMir | [2020-09-10 08:26:44.148] [LOG]    Use existing news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen
            1|MagicMir | [2020-09-10 08:26:44.149] [INFO]   Newsfeed-Fetcher: No items to broadcast yet.
            1|MagicMir | [2020-09-10 08:26:44.395] [LOG]    MMM-MyCommute: The provided API key is invalid.
            1|MagicMir | [2020-09-10 08:26:44.404] [LOG]    MMM-MyCommute: The provided API key is invalid.
            1|MagicMir | [2020-09-10 08:26:45.177] [INFO]   Newsfeed-Fetcher: Broadcasting 15 items.
            1|MagicMir | [2020-09-10 08:26:45.451] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2020-09-10 08:26:45.720] [INFO]   Newsfeed-Fetcher: Broadcasting 30 items.
            1|MagicMir | [2020-09-10 08:26:46.169] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
            1|MagicMir | [2020-09-10 08:31:43.420] [LOG]    Use existing calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
            1|MagicMir | [2020-09-10 08:31:43.434] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
            1|MagicMir | [2020-09-10 08:31:44.663] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
            1|MagicMir | [2020-09-10 08:31:46.041] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
            1|MagicMir | [2020-09-10 08:31:46.356] [INFO]   Newsfeed-Fetcher: Broadcasting 15 items.
            You can ignore the error - I tested a different module for the pir sensor and went back to using an “old” one (one I know)
              sdetweil @Stef
              @Stef what about the developers window log?
                Stef @sdetweil
                That one is not showing up…
                Guess while I’m only on ssh and vnc
                BTW I got a new bug…
                Current weather is still not showing, but the forecast is… Well, kind of…
                What strange is, that it still says new York instead of “Rosbach”…
                  sdetweil @Stef
                  @Stef >
                  what does that mean? ctrl-shift-i on the mirror keyboard , select the tab labeled ‘console’ and scroll up to see any errors,
                  usually red text
                  you can also filter on messages from specific modules by putting some unique part of the module name in the ‘filter’ field
                  the wrong config means you didn’t put the right stuff in config.js
                    Stef @sdetweil
                    Hi, sorry for getting back to you so late…
                    @sdetweil said in Weather just won't show up...:
                    @Stef >
                    what dies that mean? ctrl-shift-i on the mirror keyboard , select the tab labeled ‘console’ and scroll up to see any errors,
                    usually red text
                    Alright, i does not work on mobile… i am on my computer right now, in a vnc sessions on my pi and it worked!
                    Sadly, i got a bunch of errors… all stating the same thing
                    GET https://api.openweathermap.org/data/2.5/weather?id=2485160&units=metric&lang=en&APPID=%myappid% 404 (Not Found)
                    updateWeather @ currentweather.js:347
                    (anonymous) @ currentweather.js:515
                    setTimeout (async)
                    scheduleUpdate @ currentweather.js:514
                    weatherRequest.onreadystatechange @ currentweather.js:343
                    XMLHttpRequest.send (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    currentweather.js:339 currentweather: Could not load weather.
                    weatherRequest.onreadystatechange @ currentweather.js:339
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    setTimeout (async)
                    If i try to resolve the url on my browser i get:
                    {"cod":"404","message":"city not found"}
                    Which is odd…
                    What do you mean by that? i did replaced “new york” with “rosbach”…
                      Stef
                      Ok… now i am confused as sh**…
                      I don’t get it…
                      First of all, it is working! The current weather is showing and the forecast (only for 2 days sadly).
                      I went to the openweathermap site and searched for “Rosbach”.
                      I found it and copied the number from the url (2845162) and used it in both moudles.
                      So far so good.
                      What i don’t understand is the value “location” in the module… I entered Rosbach and it was still displaying New York - i get it now, that i was still using the wrong location id (i am so sorry about that! i did not see that mistake!!) - but if the “location name” is coming from the website, why is there a value called “location”??
                        sdetweil @Stef
                        @Stef the doc https://docs.magicmirror.builders/modules/currentweather.html#configuration-options
                        says location or location id
                        location, city name is not enough
                          sdetweil @Stef
                          @Stef weather for 2 days, see the post pinned to the top of the troubleshooting section about fixes available for version 2.12
                            Stef
                            I feel like fool…
                            I misred that… sorry…
