    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 39.6k Views 2 Watching
    • E Offline
      ember1205
      So, the extra “stress” isn’t actually stress on the Pi at all?
        sdetweil @ember1205
        @ember1205 well, the file system loading of the images will be thru the pi, but nothing else…all the display side is done in the browser (which is where it ran out of memory)
        • E Offline
          ember1205
          Well, it isn’t a LOT of progress, but it’s progress.
          It’s still crashing. But I managed to get a core dump. And it says that it’s Electron that’s crashing. The initial output from bt has me a little confused as I can’t tell if it didn’t load the symbol file correctly, or if the info just “unknown”. Here’s what I get from a bt command:
          Core was generated by `/home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --auto'.
          Program terminated with signal SIGTRAP, Trace/breakpoint trap.
          #0  0x02760514 in ?? ()
          [Current thread is 1 (LWP 6298)]
          (gdb) bt
          #1  0x027603d8 in ?? ()
          Backtrace stopped: previous frame identical to this frame (corrupt stack?)
          Not really sure if there’s anywhere to go from here. :/
            sdetweil @ember1205
            @ember1205 but the other browsers kept going?
            i don’t think the symbols are available,certainly not for modules, if that is where the problem is
            I would add MMM-Logging (my version) which merges the logs from browser and node_helpers into one log
            https://github.com/sdetweil/MMM-Logging
            • E Offline
              ember1205
              Hmmm. Not sure about other browsers since I had shut those down. I’ll wait until it crashes again and see if a secondary browser will keep running.
              • E Offline
                ember1205
                I have confirmed that only Electron crashes on the Pi itself. The MM server does not experience any hiccups and remote browser connections remain functional.
                I at least now understand WHAT is crashing. Next steps might be to figure out WHY it’s crashing and potentially remedy it.
                  sdetweil @ember1205
                  @ember1205 note that we are trailing release of electron quite significantly (we are on 6.1.7 and latest is 9.x.x) … you might try moving up to a different version, no guaranty that MM will run tho… or what the other impacts are…
                  as i said back a few, with a minor startup change, you can get chromium to be the viewer on the pi.
                  • E Offline
                    ember1205
                    I’ve made the change to Chromium - we’ll see how that does going forward.
                    I do recall reading plenty about the severe lag of Electron in terms of the version that’s part of MM, so that part wasn’t “news” really. What I genuinely don’t understand is why this specific, basic configuration continues to have issues for me while Electron mostly does what it needs to do for so many others without creating this sort of problem.
                      sdetweil @ember1205
                      @ember1205 electron is a ‘single’ threaded app… but events happen that cause it to need to act like mutltiple threads.
                      there are lots of edge cases where the timing is problematic…
                      its not out of memory, its lost its way…
                      i wrote a plugin/module to display pics matches with cal entries, floating above the mirror screen… (pong like moving boxes)
                      electron does NOT like two windows being manipulated at the same time… took a long time to find that, always an out of memory error or hang… but not
                      • E Offline
                        ember1205
                        Good info.
                        I’m interested to see how for the MM will make it now using Chromium instead of Electron. Since I have two with the same setup, I’ll set both to use Chromium for an additional level of testing it out.
                        Why was Electron chosen as the browser up to this point? And, what potential downsides are there to Chromium?
                          sdetweil @ember1205
                          @ember1205 >Why was Electron chosen as the browser up to this point? And, what potential downsides are there to Chromium?
                          i don’t know and i don’t know… was way before my time.
                          • E Offline
                            ember1205
                            Welp…
                            No change. System still crashes on the Pi using Chromium.
                            In looking at the most recent core file, it’s still showing that electron is what’s faulting.
                            There are no running processes of chromium and electron is still being started. Something is amiss with the configuration to where your run-start.sh script is either not being called or is not launching the correct browser for some reason.
                            I’ve made no changes to run-start.sh, I’ve edited package.json so that this line is gone:
                            And has been replaced with this one:
                            "start": "./run-start.sh",
                            config/config.js has the following setting:
                            var config = {
                            	address: "0.0.0.0", 	// Address to listen on, can be:
                            							// - "localhost", "127.0.0.1", "::1" to listen on loopback interfac
                            e
                            							// Default, when address config is left out or empty, is "localhost
                            	port: 8080,
                            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                            	ipWhitelist: ["127.0.0.1", "192.168.192.0/24", "::1"], 	// Set [] to allow all IP addresses
                            or add a specific IPv4 of 192.168.1.5 :
                            ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
                            or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
                            ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
                            	language: "en",
                            	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                            	timeFormat: 24,
                            	units: "metric",
                            	serverOnly:"local",
                            • E Offline
                              ember1205
                              One tweak to the run-start.sh script seems to have fixed it. I changed this line:
                              serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\'\\r)
                              To this:
                              serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($1)}' | tr -d ,\"\'\\r)
                              The awk command seems to have been looking for a variable that wasn’t being passed and by changing the variable number that it was looking for, it no longer starts electron and now starts chromium.
                                sdetweil @ember1205
                                @ember1205 hm… do this
                                ./run-start.sh
                                you should see something like this
                                 ./run-start.sh
                                [2020-09-22 13:13:51.584] [LOG] Starting MagicMirror: v2.13.0-develop
                                [2020-09-22 13:13:51.588] [LOG] Loading config ...
                                [2020-09-22 13:13:51.590] [LOG] Loading module helpers ...
                                [2020-09-22 13:13:51.590] [LOG] No helper found for module: alert.
                                [2020-09-22 13:13:51.602] [LOG] Initializing new module helper ...
                                [2020-09-22 13:13:51.602] [LOG] Module helper loaded: updatenotification
                                [2020-09-22 13:13:51.603] [LOG] No helper found for module: clock.
                                [2020-09-22 13:13:51.840] [LOG] Initializing new module helper ...
                                [2020-09-22 13:13:51.840] [LOG] Module helper loaded: calendar
                                [2020-09-22 13:13:51.841] [LOG] No helper found for module: compliments.
                                [2020-09-22 13:13:51.841] [LOG] No helper found for module: currentweather.
                                [2020-09-22 13:13:51.841] [LOG] No helper found for module: weatherforecast.
                                [2020-09-22 13:13:52.147] [LOG] Initializing new module helper ...
                                [2020-09-22 13:13:52.147] [LOG] Check MagicMirror version for node helper 'MMM-Ring' - Minimum version: 2.11.0 - Current version: 2.13.0-develop
                                [2020-09-22 13:13:52.147] [LOG] Version is ok!
                                [2020-09-22 13:13:52.148] [LOG] Module helper loaded: MMM-Ring
                                [2020-09-22 13:13:52.148] [LOG] All module helpers loaded.
                                [2020-09-22 13:13:52.186] [LOG] Starting server on port 8090 ...
                                [2020-09-22 13:13:52.187] [INFO] You're using a full whitelist configuration to allow for all IPs
                                [2020-09-22 13:13:52.190] [LOG] Server started ...
                                [2020-09-22 13:13:52.190] [LOG] Connecting socket for: updatenotification
                                [2020-09-22 13:13:52.190] [LOG] Connecting socket for: calendar
                                [2020-09-22 13:13:52.190] [LOG] Starting node helper for: calendar
                                [2020-09-22 13:13:52.191] [LOG] Connecting socket for: MMM-Ring
                                [2020-09-22 13:13:52.196] [LOG] MMM-Ring at (9/22/2020, 1:13:52 PM): Starting module: MMM-Ring
                                [2020-09-22 13:13:52.196] [LOG] Sockets connected & modules started ...
                                Ready to go! Please point your browser to: http://0.0.0.0:8090
                                Starting chromium browser now, have patience, it takes a minute
                                that last line is the key to running in split mode, server with chromium over the top…
                                to run it multiple times, you will have to kill the server process
                                 ps -ef | grep server
                                sam 3267 3266 1 13:13 pts/0 00:00:01 node serveronly
                                kill -9 3267
                                thx for the hint, the space after the serverOnly:
                                  @ember1205 I just updated the script to handle with/without the space…
                                  • E Offline
                                    ember1205
                                    Cool. I download the latest one and try it out.
                                    Glad I can help you keep improving your code! lol
                                      sdetweil @ember1205
                                      @ember1205 said in "Out of memory" issues - where do I begin?:
                                      me too… thought I had handled that… guess not
                                      • E Offline
                                        ember1205
                                        Based on the directions you gave in this thread, the run-start.sh script won’t work. I didn’t take the time to look through the github content to see if this is covered there, but you have to do
                                        chmod +x run-start.sh
                                        Or the script won’t actually execute. Based on old habits, I was executing the chmod statement without even thinking about it. But, after downloading the newest script, I purposefully left it untouched and it wouldn’t run.
                                          sdetweil @ember1205
                                          @ember1205 hm, thought it was uploaded with exec. will check this evening. have doctor appt shortly
                                          thanks for the info
                                          • E Offline
                                            ember1205
                                            I simply opened the github page, copied the link, and used wget to download it to the mirror. So, it’s entirely possible that the way I downloaded it was partly to blame. Figured I would mention it because I’m likely not the only one that might run into this, and at a minimum it could become a troubleshooting step if others run into issues.
                                            • 2 / 4
