    Is it possible to ad an Arduino?
    55 Posts 4 Posters 28.5k Views 4 Watching
      Shinji0912 @sdetweil
      @sdetweil U mean like this?
         Serial.println("pcPostfix)"
         "Serial.println(""[status:setup:starting]"")"
         "Serial.println(""[sensor:DHT11:11]"")"
         "Serial.println(""[status:setup:failed]"")"
      S 2 Replies Last reply
        sdetweil @Shinji0912
        @Shinji0912 see prior post
          @sdetweil alt text
          Edit : Im really sorry for my Stupidity normally im a really quick learner and i understand things pretty fast but i got kind off lost at this point… but im sooo thankful for your help in general without you i wouldn’t even been able to get the right SerialPort name…soo thank u soo much so far ^^ and sry for using your time , but i wouldn’t ask if i could do it myself :/
            @Shinji0912 you can only send the sensor values in the sketch loop() function,
            the rest is is used for getting connected to the matching code in the python script
            they do
            arduino, hey, are u there?
            python script, yes, ready for sensor values
            arduino, once a second, or whatever frequency
            hey, here is sensor:???:value
              @sdetweil Ok , so based on that i have rewritten my whole Script and added just a few comments so maybe you will understand my thoughts about it…
              #include <dht_nonblocking.h>
              #include <Wire.h>
              #define DHT_SENSOR_TYPE DHT_TYPE_11
              static const char DHT_SENSOR_PIN = 2;
              DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
              void setup() {
                Wire.begin();
                Serial.begin(9600);
              //Verbindung zum Raspberry aufbauen
              // Connect to the Raspberry start ArduPort connection
                Serial.println("[status:setup:starting]");
                Serial.println("[status:setup:started]");
              // Messungen Definieren
              //Define Measurment Names
                static bool messung_t( float *temperatur, float *feuchtigkeit)
                  static unsigned long messung_t = millis( );
                    if( millis( ) - messung_t > 3000ul )
                        if( dht_sensor.measure( temperatur, feuchtigkeit ) == true)
                          return( true );
                          return ( false );
              void loop() {
               //Übermitteln der Daten an ArduPorts
               //sending informations to ArduPorts
                float temperatur;
                float feuchtigkeit;
                  Serial.print( "[sensor:DHT11:" );
                  Serial.print(temperatur, 1 );
                  Serial.println("]");
                  delay(2000);
              I thought it is going to work this time but on the mirror it is still : “waiting for connection”
              but my Console log when starting the mirror shows me that the ArduPorts reads the Temperature (because a slightly mistake (but should still work) the Temperature is always 0.0)
              Console Log :
              [2020-09-22 16:24:17.982] [LOG]    Launching application.
              [2020-09-22 16:24:21.437] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
              [2020-09-22 16:24:21.624] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:21]: Load data for ID "18228265" and "0" days ...
              [2020-09-22 16:24:21.633] [INFO]   Checking git for module: MMM-ArduPort
              [2020-09-22 16:24:21.665] [INFO]   Checking git for module: MMM-TelegramBot
              [2020-09-22 16:24:21.700] [INFO]   Checking git for module: MMM-Online-State
              [2020-09-22 16:24:21.733] [INFO]   Checking git for module: MMM-RBB-Weather
              [2020-09-22 16:24:21.772] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
              [2020-09-22 16:24:21.810] [ERROR]  (node:1379) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              [2020-09-22 16:24:21.812] [ERROR]  (node:1379) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              [2020-09-22 16:24:21.956] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:21]: Fetch data for day "0" ...
              [2020-09-22 16:24:21.999] [LOG]    { debug: 'SerialPort shell started...' }
              [2020-09-22 16:24:22.014] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
              [2020-09-22 16:24:22.016] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
              [2020-09-22 16:24:22.018] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
              [2020-09-22 16:24:22.019] [LOG]    { status: { name: 'connect', data: 'connected' } }
              [2020-09-22 16:24:22.020] [LOG]    { name: 'connect', data: 'connected' }
              [2020-09-22 16:24:22.026] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:22.031] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:22.359] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:22.363] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:22.731] [LOG]    Refreshed access token because it has expired. Expired at: 16:24:21 now is: 16:24:22
              [2020-09-22 16:24:22.768] [LOG]    Refreshed access token because it has expired. Expired at: 17:24:22 now is: 16:24:22
              [2020-09-22 16:24:22.870] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:22]: Data received, send to module ...
              [2020-09-22 16:24:23.104] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              [2020-09-22 16:24:23.341] [LOG]    { status: { name: 'setup', data: 'starting' } }
              [2020-09-22 16:24:23.348] [LOG]    { name: 'setup', data: 'starting' }
              [2020-09-22 16:24:23.723] [LOG]    { status: { name: 'setup', data: 'started' } }
              [2020-09-22 16:24:23.727] [LOG]    { name: 'setup', data: 'started' }
              [2020-09-22 16:24:23.731] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:25.345] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:27.353] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:29.363] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:31.374] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              [2020-09-22 16:24:33.383] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
                @Shinji0912 ok, now we need to see the log from the browser
                ctrl-shift-i on the mirror keyboard, select the tab labeled console, and then put port in the filter field
                also set
                developerMode:true,
                in the config.js config section for the arduport module
                there are a lot of messages available from the modulename.js
                  @sdetweil alt text
                  and
                  alt text
                    @Shinji0912 not acm0 in filter,
                    module name part
                    ardu
                      @sdetweil Oh okay
                      alt text
                      alt text
                      alt text
                      alt text
                        @Shinji0912 others appear to have had the same problem, see the changes suggested here
                        https://github.com/Dentrax/MMM-ArduPort/issues/3
                          @sdetweil Ok, i will try when back @home
                            @sdetweil Just tried it but it’s not working … now the “waiting for connection” or starting arduports isn’t even displayed on the MagicMirror anymore
                            and the console log changed from :
                            pi@raspberrypi:~/MagicMirror $ npm run start
                            > magicmirror@2.12.0 start /home/pi/MagicMirror
                            [2020-09-24 15:48:02.396] [LOG]    Starting MagicMirror: v2.12.0
                            [2020-09-24 15:48:02.409] [LOG]    Loading config ...
                            [2020-09-24 15:48:02.421] [LOG]    Loading module helpers ...
                            [2020-09-24 15:48:02.444] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:02.445] [LOG]    Module helper loaded: MMM-ArduPort
                            node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                            In the future, you will have to enable it yourself.
                            See https://github.com/yagop/node-telegram-bot-api/issues/319. internal/modules/cjs/loader.js:786:30
                            [2020-09-24 15:48:04.024] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:04.025] [LOG]    Module helper loaded: MMM-TelegramBot
                            [2020-09-24 15:48:04.027] [LOG]    No helper found for module: MMM-Online-State.
                            [2020-09-24 15:48:04.097] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:04.098] [LOG]    Module helper loaded: updatenotification
                            [2020-09-24 15:48:04.100] [LOG]    No helper found for module: clock.
                            [2020-09-24 15:48:04.259] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:04.260] [LOG]    Module helper loaded: MMM-RBB-Weather
                            [2020-09-24 15:48:04.904] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:04.905] [LOG]    Module helper loaded: calendar
                            [2020-09-24 15:48:05.663] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:48:05.664] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:48:05.664] [LOG]    All module helpers loaded.
                            [2020-09-24 15:48:05.869] [LOG]    Starting server on port 8080 ...
                            [2020-09-24 15:48:05.894] [LOG]    Server started ...
                            [2020-09-24 15:48:05.895] [LOG]    Connecting socket for: MMM-ArduPort
                            [2020-09-24 15:48:05.897] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
                            [2020-09-24 15:48:05.898] [LOG]    Connecting socket for: MMM-TelegramBot
                            [2020-09-24 15:48:05.899] [LOG]    Connecting socket for: updatenotification
                            [2020-09-24 15:48:05.901] [LOG]    Connecting socket for: MMM-RBB-Weather
                            [2020-09-24 15:48:05.902] [LOG]    Starting module helper: MMM-RBB-Weather
                            [2020-09-24 15:48:05.902] [LOG]    Connecting socket for: calendar
                            [2020-09-24 15:48:05.903] [LOG]    Starting node helper for: calendar
                            [2020-09-24 15:48:05.904] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:48:05.905] [LOG]    Sockets connected & modules started ...
                            [2020-09-24 15:48:06.097] [LOG]    Launching application.
                            [2020-09-24 15:48:09.747] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
                            [2020-09-24 15:48:09.956] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:09]: Load data for ID "18228265" and "0" days ...
                            [2020-09-24 15:48:09.970] [INFO]   Checking git for module: MMM-ArduPort
                            [2020-09-24 15:48:10.014] [INFO]   Checking git for module: MMM-TelegramBot
                            [2020-09-24 15:48:10.057] [INFO]   Checking git for module: MMM-Online-State
                            [2020-09-24 15:48:10.104] [INFO]   Checking git for module: MMM-RBB-Weather
                            [2020-09-24 15:48:10.148] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:48:10.201] [ERROR]  (node:1251) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                            [2020-09-24 15:48:10.209] [ERROR]  (node:1251) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                            [2020-09-24 15:48:10.357] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:10]: Fetch data for day "0" ...
                            [2020-09-24 15:48:10.397] [LOG]    { debug: 'SerialPort shell started...' }
                            [2020-09-24 15:48:10.408] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
                            [2020-09-24 15:48:10.410] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
                            [2020-09-24 15:48:10.411] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
                            [2020-09-24 15:48:10.413] [LOG]    { status: { name: 'connect', data: 'connected' } }
                            [2020-09-24 15:48:10.416] [LOG]    { name: 'connect', data: 'connected' }
                            [2020-09-24 15:48:11.002] [LOG]    Refreshed access token because it has expired. Expired at: 15:48:09 now is: 15:48:11
                            [2020-09-24 15:48:11.093] [LOG]    Refreshed access token because it has expired. Expired at: 16:48:11 now is: 15:48:11
                            [2020-09-24 15:48:11.189] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:11]: Data received, send to module ...
                            [2020-09-24 15:48:11.328] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
                            [2020-09-24 15:48:12.086] [LOG]    { status: { name: 'setup', data: 'starting' } }
                            [2020-09-24 15:48:12.093] [LOG]    { name: 'setup', data: 'starting' }
                            [2020-09-24 15:48:12.187] [LOG]    { status: { name: 'setup', data: 'started' } }
                            [2020-09-24 15:48:12.189] [LOG]    { name: 'setup', data: 'started' }
                            [2020-09-24 15:48:12.258] [LOG]    { sensor: { name: 'DHT11', data: '0' } }
                            to this :
                            [2020-09-24 15:52:40.905] [LOG]    Starting MagicMirror: v2.12.0
                            [2020-09-24 15:52:40.918] [LOG]    Loading config ...
                            [2020-09-24 15:52:40.930] [LOG]    Loading module helpers ...
                            [2020-09-24 15:52:40.953] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:40.954] [LOG]    Module helper loaded: MMM-ArduPort
                            [2020-09-24 15:52:42.568] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:42.569] [LOG]    Module helper loaded: MMM-TelegramBot
                            [2020-09-24 15:52:42.571] [LOG]    No helper found for module: MMM-Online-State.
                            [2020-09-24 15:52:42.641] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:42.642] [LOG]    Module helper loaded: updatenotification
                            [2020-09-24 15:52:42.644] [LOG]    No helper found for module: clock.
                            [2020-09-24 15:52:42.801] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:42.802] [LOG]    Module helper loaded: MMM-RBB-Weather
                            [2020-09-24 15:52:43.439] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:43.440] [LOG]    Module helper loaded: calendar
                            [2020-09-24 15:52:44.199] [LOG]    Initializing new module helper ...
                            [2020-09-24 15:52:44.200] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:52:44.201] [LOG]    All module helpers loaded.
                            [2020-09-24 15:52:44.413] [LOG]    Starting server on port 8080 ...
                            [2020-09-24 15:52:44.436] [LOG]    Server started ...
                            [2020-09-24 15:52:44.438] [LOG]    Connecting socket for: MMM-ArduPort
                            [2020-09-24 15:52:44.439] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
                            [2020-09-24 15:52:44.440] [LOG]    Connecting socket for: MMM-TelegramBot
                            [2020-09-24 15:52:44.442] [LOG]    Connecting socket for: updatenotification
                            [2020-09-24 15:52:44.443] [LOG]    Connecting socket for: MMM-RBB-Weather
                            [2020-09-24 15:52:44.444] [LOG]    Starting module helper: MMM-RBB-Weather
                            [2020-09-24 15:52:44.445] [LOG]    Connecting socket for: calendar
                            [2020-09-24 15:52:44.446] [LOG]    Starting node helper for: calendar
                            [2020-09-24 15:52:44.447] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:52:44.448] [LOG]    Sockets connected & modules started ...
                            [2020-09-24 15:52:44.620] [LOG]    Launching application.
                            [2020-09-24 15:52:48.090] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
                            [2020-09-24 15:52:48.288] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:48]: Load data for ID "18228265" and "0" days ...
                            [2020-09-24 15:52:48.296] [INFO]   Checking git for module: MMM-TelegramBot
                            [2020-09-24 15:52:48.333] [INFO]   Checking git for module: MMM-Online-State
                            [2020-09-24 15:52:48.367] [INFO]   Checking git for module: MMM-RBB-Weather
                            [2020-09-24 15:52:48.398] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                            [2020-09-24 15:52:48.431] [ERROR]  (node:1440) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                            [2020-09-24 15:52:48.433] [ERROR]  (node:1440) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                            [2020-09-24 15:52:48.460] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:48]: Fetch data for day "0" ...
                            [2020-09-24 15:52:48.818] [LOG]    Refreshed access token because it has expired. Expired at: 15:52:48 now is: 15:52:48
                            [2020-09-24 15:52:49.005] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
                            [2020-09-24 15:52:49.077] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:49]: Data received, send to module ...
                            [2020-09-24 15:52:49.107] [LOG]    Refreshed access token because it has expired. Expired at: 16:52:48 now is: 15:52:49
                            [2020-09-24 15:53:56.041] [LOG]    Shutting down server...
                            [2020-09-24 15:53:56.043] [LOG]    Stopping module helper: MMM-ArduPort
                            [2020-09-24 15:53:56.045] [LOG]    Stopping module helper: MMM-TelegramBot
                            [2020-09-24 15:53:56.046] [LOG]    Stopping module helper: updatenotification
                            after doing what they told in the issue topic from the ArduPort Git
                              @Shinji0912 sorry, have no idea… not my module and cannot build matching system here
                                @sdetweil Sad, but thank you soo much for kind of wasting your time trying to help me ^^
                                C 1 Reply Last reply
                                  Crime @Shinji0912
                                  @Shinji0912 just got the “arduport” to show the data correctly! advice helped me @sdetweil
                                  I connect via VNC.
                                  have to set developerMode:true in the module config.js section
                                  call the developer window by clicking on the keyboard ctrl+shift+i
                                  I saw my mistake. function “formatValue” doesn’t work.
                                  the following solution helped
                                    Shinji0912 @Crime
                                    @Crime I already tried to fix it like that but sadly i didn’t worked… now i don’t know what to do and i don’t have the knowledge to fix it myself atm atleast .-.
                                    • 3 / 3
