    Shairport-sync help needed
    5 Posts 2 Posters 1.8k Views 2 Watching
      monkeyjb123
      Hello everyone! I’m on my first attempt at making a MM as well as my first attempt with coding using a rpi so forgive me if I sound uninformed! I’m attempting to install shairport to allow for airplay and have been following the directions up until I have to configure Shairport sync. Anytime I put in:
      /etc/shairport-sync.conf
      It says permission denied. I even tried sudo beforehand and it then says no such file or directory. Any help would be appreciated.
      This is the instruction guide I’ve been following. Thanks!
      https://github.com/mikebrady/shairport-sync/blob/master/INSTALL.md
        sdetweil @monkeyjb123
        @monkeyjb123
        sudo nano /etc/shairport-sync.conf
        change the text move around w arrow keys
        ctrl-o to save
        ctrl-c to exit
          monkeyjb123 @sdetweil
          @sdetweil thanks so much! Got it to work, now to get the metadata to appear. Appreciate it
            @sdetweil so I tried getting on again after turning the pi off and now airplay doesn’t seem to work anymore? even tried deleting and redoing the git clone. Any suggestions? thanks in advance
              @monkeyjb123 no idea. are you using MagicMirror OS which runs MM under docker?
