Cant start after update 2.13
12 Posts 2 Posters 1.3k Views 2 Watching
    SuseGigabyte
    Hi
    After the update the following error message appears.
    I’m a beginner but had no update problems in the last 2 years. I do not know where to start.
    I thank you in advance for your support.
    sh: 1: ./node_modules/.bin/electron: not found
    npm ERR! code ELIFECYCLE
    npm ERR! syscall spawn
    npm ERR! file sh
    npm ERR! errno ENOENT
    npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.13.0 start script.
    npm ERR! /home/pi/.npm/_logs/2020-10-04T16_02_58_708Z-debug.log
    S 1 Reply Last reply Oct 4, 2020, 4:18 PM Reply Quote 0
      sdetweil @SuseGigabyte
      @SuseGigabyte please tell me more… how did u install, what pi is this?
        SuseGigabyte
        • Raspberry Pi 3 Model B Plus Rev 1.3
        • I updated with “git pull && npm install”
        I have to be honest. After that didn’t work I deleted the folder electron.
        That didn’t work either and in the meantime I don’t really know what to do anymore.
        I hope that I don’t have to do a complete new installation.
        Shame on me.
        S 1 Reply Last reply Oct 4, 2020, 4:35 PM Reply Quote 0
          @SuseGigabyte lets try to recover
          do
          npm install electron@6.1.7
          then try to restart mm… there may be other problems to solve
            SuseGigabyte
            after command: npm install electron@6.1.7
            the following message appears:
            npm ERR! Unexpected end of JSON input while parsing near '… “p-locate”: {
            npm ERR! ’
            npm ERR! /home/pi/.npm/_logs/2020-10-04T16_40_18_667Z-debug.log
            after restart mm
            magicmirror@2.13.0 start /home/pi/MagicMirror
            npm ERR! file sh
            npm ERR!
            npm WARN Local package.json exists, but node_modules missing, did you mean to install?
            npm ERR! /home/pi/.npm/_logs/2020-10-04T16_43_10_392Z-debug.log
            S 1 Reply Last reply Oct 4, 2020, 4:48 PM Reply Quote 0
              @SuseGigabyte what pi is this?
              also, show me the output of
              lsb_release -a
              uname -a
              node -v
              npm -v
                SuseGigabyte
                @sdetweil thank you for your patience.
                pi@raspberrypi:~/MagicMirror $ lsb_release -a
                No LSB modules are available.
                Distributor ID: Raspbian
                Description: Raspbian GNU/Linux 10 (buster)
                pi@raspberrypi:~/MagicMirror $ uname -a
                Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                pi@raspberrypi:~/MagicMirror $ node -v
                v10.22.1
                pi@raspberrypi:~/MagicMirror $ npm -v
                6.10.3
                S 1 Reply Last reply Oct 4, 2020, 4:55 PM Reply Quote 0
                  @SuseGigabyte hmmm… looks ok,
                  i ‘suspect’ a bad sd card, but lets try one more time using my upgrade script
                  from here
                  execute this
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  it will create a log file, MagicMirror/installers/upgrade.log
                    SuseGigabyte
                    @sdetweil You’re a genius. I can’t thank you enough.
                    After hours of blood, sweat and almost tears every thing went o.k.
                    Do I have to do an additional command because of:
                    added 394 packages from 287 contributors and audited 1163 packages in 412.313s
                    found 3 low severity vulnerabilities
                      run `npm audit fix` to fix them, or `npm audit` for details
                    npm install completed - So Okt  4 19:08:08 CEST 2020 on base
                    **upgrade.log**
                    Upgrade started - So Okt  4 19:00:18 CEST 2020
                    system is Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                    the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                    user requested to force apply changes
                    doing test run = false
                    saving custom.css
                    remote name = origin
                    upgrading from version 2.13.0 to 2.13.0
                    fetching latest revisions
                    git fetch rc=0
                    current branch = master
                    On branch master
                    Your branch is up to date with 'origin/master'.
                      (use "git add/rm <file>..." to update what will be committed)
                      (use "git checkout -- <file>..." to discard changes in working directory)
                    	deleted:    config/config.js.sample
                    	modified:   installers/mm.sh
                    	deleted:    modules/default/clock/README.md
                    	modified:   modules/default/clock/clock.js
                    	deleted:    modules/default/clock/clock_styles.css
                    	modified:   modules/default/compliments/compliments.js
                    	modified:   package-lock.json
                    	modified:   package.json
                    Untracked files:
                      (use "git add <file>..." to include in what will be committed)
                    	core
                    	css/custom.css_Back
                    	css/custom.css_Backup
                    	css/save_custom.css
                    	installers/pm2_MagicMirror.json
                    	js/socketclient.js_heute
                    	js/socketclient.js_mod
                    	js/socketclient.js_modified
                    	js/socketclient.js_org
                    	modules/default/back_clock/
                    	modules/default/compliments/compliments.js_org
                    	package-lock.json_back
                    	package-lock.json_back_1
                    	package.json_back
                    	package.json_back_1
                    no changes added to commit (use "git add" and/or "git commit -a")
                    there are 5 local files that are different than the master repo
                       installers/mm.sh
                       package-lock.json
                       package.json
                    save/restore files selection = y
                    Speicherte Arbeitsverzeichnis und Index-Status WIP on master: 3dbe8bf Merge pull request #2143 from MichMich/develop
                    test merge result rc='' , if empty, no conflicts
                    executing merge, apply specified
                    merge result rc= 0
                     Already up to date.
                    processor architecture is armv7l
                    > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
                    > node ./msg.js
                    Attention
                        Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                        For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                    > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
                    > node install.js
                    > magicmirror@2.13.0 install /home/pi/MagicMirror
                    " && cd vendor && npm install --loglevel=error
                    audited 24 packages in 2.478s
                    found 0 vulnerabilities
                    > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
                    > echo "Installing fonts ...
                    " && cd fonts && npm install --loglevel=error
                    audited 1 package in 2.715s
                    fixing sandbox permissions
                    downloading dumpactivemodules script
                    processing for module netatmo please wait
                    S 1 Reply Last reply Oct 4, 2020, 5:18 PM Reply Quote 0
                      @SuseGigabyte no additional commands required
                      in the future, please use code wrapper for posts with messages like this… (mark the text and hit the </> button)
