    Compliments module cannot load remoteFile
    4 Posts 2 Posters 714 Views 2 Watching
    • K
      kuqquk
      I have a compliments.json file on a remote server for the Compliments module loading that.
      It worked in the beginning but after changing the language of MM2 from en to zh-cn, compliments cannot load the remote file then.
      I have tried:
      • reboot
      • change back to en
      • reinstall MM2
      • update npm
      but they all didn’t solve the issue.
      I also found after that MM2 will be frozen (the clock is not running, the news feed won’t refresh), after launching MM2 for a while.
      If put all compliments in the config without using remoteFile, everything works fine.
      			module: "compliments",
      			position: "lower_third",
      				compliments: {
      					remoteFile: "http://remoteServerAddress/compliments.json"
      And my compliments.json:
          "anytime": ["Expelliarmus"]
      Need some help, thanks!
        sdetweil @kuqquk
        @kuqquk open the developers window, ctrl-shift-i on the mirror keyboard, select the tab labeled console, and scroll up to see any errors…
        that param is OUTSIDE the compliments:{} file values
        K 1 Reply Last reply
        • K
          kuqquk @sdetweil
          @sdetweil Thanks! I found the issue is that,
          access to XMLHttpRequest at remoteServerAddress from origin ‘http://localhost:8080’ has been blocked by cors policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
          Trying to figure this now…
            sdetweil @kuqquk
            @kuqquk try changing address to “0.0.0.0”, from “localhost”,
