    How to change icon and payload by notification?
    7 Posts 2 Posters 1.5k Views 2 Watching
      sdetweil @MrCoffee
      @MrCoffee so the home automation code should send some ID with the notice, on or off…
      and u have some table where u look up the ID (you could set the ID on the button in html)
      what you are SUPPOSED to do, is save the info and then call updateDom(), which will regenerate the content by calling getDom().
      lots of other modules change the dom directly, by using appropriate apis
      so, the ID gets you the button object, and u can change its img tag src= value (or change its class which does all that)
      var button=document.getElementById(id)
      and of course u can examine the current class, or src= to use that as the ‘state’ you are toggling
      MrCoffeeM 1 Reply Last reply Reply Quote 0
      • MrCoffeeM Offline
        MrCoffee @sdetweil
        @sdetweil Thank you. That helped me unterstanding a bit more.
        But it still seems a little bit far away for me for the moment:-)
        Maybe I just found an alternative method. I played around with MMM-Touch a little.
        The module has a possiblity to change the notification to send, the next time the button is pressed.
        So if the button is pressed an light is turned on, than the notification send next time when the button is pressed can change to “turn off”.
        MMM-Touch - on notification
        Unfortunately it seems like the module only works with one button.
        What is your opinion on this module?
        Could you please have a look if I am right with one button only?
        Will it be possible to install multiple instances like MMM-Touch1, 2, 3 … or even add some buttons customizing the code?
        Thanks again.
          sdetweil @MrCoffee
          @MrCoffee sorry, no info on that module, never used it. no idea if multiple instances can be used at once.
          • MrCoffeeM Offline
            MrCoffee @sdetweil
            @sdetweil Never mind. I will ask the developer.
            I´ve just seen that you helped this guy out: image-on-notification. Things get clearer. Guess I have to try and play around a little.
            Probably the best way is to set up a new module. Never tried it. Probably it will take some time:-)
              sdetweil @MrCoffee
              @MrCoffee my sample module is here
              https://github.com/sdetweil/SampleModule
              based on what u wanted I assumed u were writing your own module to put multiple images over the floor layout
              • MrCoffeeM Offline
                MrCoffee @sdetweil
                @sdetweil Guess you are right.
                I just cloned your sample module.
                Thanks for helping me out.
