    Dropbox-Uploader: how to synchronize a folder with cron job?
    11 Posts 3 Posters 4.3k Views 3 Watching
    • lavolp3L
      lavolp3 Module Developer @MajorC
      @MajorC why dont you regularly download the whole folder and select files from that to show as background.
      I assume with the Download Option of the script you might be able to kind of synchronise your folder.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      M 1 Reply Last reply
        MajorC Project Sponsor @lavolp3
        @lavolp3 I am able to download the folder. But I would like to have a script to do that every time the pi starts up automatically. That’s where I am having the problem at the moment.
          sdetweil @MajorC
          @MajorC which part of the ‘when the pi boots’ are u having trouble with
          if you use pm2, you can start your script with pm2
          pm2 start scriptpath
          pm2 save
            MajorC Project Sponsor @sdetweil
            @sdetweil can you give me a little bit more details? I am quite new to the MM-world and have no idea where I can find what you wrote?!?
            S 2 Replies Last reply
              sdetweil @MajorC
              @MajorC YOU have to enter those commands
              you said you have a script that will download files
              now, turn it into something that happens every hour, add a while loop around it…
              (I know you don’t know, so google searching will teach you a ton)
              then, once THAT works, you can use the pm2 process manager to launch it for you
                sdetweil @MajorC
                so, what commands would you issue to do that
                creating a script is as simple as writing a file with this commands
                making it executable (see chmod command)
                and then launching it.
                  @sdetweil the script is running fine if I start it manualy by hand.
                  I need a hint how to do it the same way, the MagicMirror starts.
                    sdetweil @MajorC
                    @MajorC i wrote the two commands u need to issue
                    pm2 start scriptpath (where is your script and what is its name, = scriptpath)
                    pm2 save
                    to set it up if you use pm2 to launch MM (which my install script does for you if you used it)
                      @sdetweil thank you. It seams to work. The script was way more easy than expected.
                      May I ask, if I roboot the MM with Strg+Q, will my script run again?
                        sdetweil @MajorC
                        @MajorC yes.pm2 reruns regardless how the system was rebooted
