    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 167.6k Views 20 Watching
    • H
      Henrik
      When “hiding” a module, does that also stop it from executing? I’m looking for a way to reduce the number of API calls made, by disabling a module at night.
      If not, any other suggestion on how to achieve this?
      Thanks in advance.
      I 1 Reply Last reply Reply Quote 1
      • I
        ianperrin @Henrik
        @Henrik
        It’s not possible for MMM-ModuleScheduler to affect the behaviour of the modules it hides/shows.
        However, it is possible for a modules to ‘react’ to being shown/hidden.
        To reduce the API calls the developer of the modules you use could implement/subclass the suspend and resume methods.
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        B 1 Reply Last reply Reply Quote 2
          bachoo786 @ianperrin
          @ianperrin hi thanks for this module.
          I used it to turn my uknationalrail module on and off at certain times. However what I noticed was that your module disables my uknationalrail module I.e. it turns it on but then it doesn’t update. If I remove your module and the settings of your module on my module it works fine.
          Is this a bug?
          • FoziF
            Fozi Project Sponsor @bachoo786
            @bachoo786 I had the same issue with MMM-googlemaps-route. The module was switched on at the defined time, but the map was not updated, only the travel times. Unfortunately, I had to find turn off the scheduler, but found a workaround for the route module to reduce the number of API calls.
              bachoo786 @Fozi
              @Fozi ah right well i would like to turn it on and off I have used remote control module as well but I face the same issue. I can adjust to reduce the number of API calls but thats least of my worries as I would like to have a clean MM interface hence turning off the module would be awesome provided it worked.
              • I
                ianperrin @bachoo786
                @bachoo786 MMM-ModuleScheduler (and MMM-RemoteControl) are only sending hide/show requests via the MagicMirror API, so have no control over the target modules upstream API calls.
                However, it may be possible something is amiss. Can you post your config and I’ll see if I can spot anything?
                  @ianperrin thanks for the reply.
                  here is my config:
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	address: "0.0.0.0", // Address to listen on, can be:
                  	port: 8181,
                  	ipWhitelist: [], // Set [] to allow all IP addresses
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  //        customCss: 'css/custom.css',
                  //			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			position: "top_left"
                         module: 'MMM-ModuleScheduler',
                  		module: 'MMM-SystemStats',
                  		position: 'bottom_bar', // This can be any of the regions.
                  		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
                  		// header: 'System Stats', // Set the header text OPTIONAL
                  			updateInterval: 10000, // every 10 seconds
                  			align: 'right', // align labels
                                          units: 'metric',
                  			view: 'textAndIcon',
                              module: "currentweather",
                                  locationID: "xx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                  appid: "xx"
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                  locationID: "xx",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  appid: "xx"
                                  module: 'random_quotes',
                                  position: 'lower_third',
                                                  updateInterval: '8',
                                                  fadeSpeed: '4'
                                          module: 'MMM-homeassistant-sensors',
                                          position: 'top_left',
                                          host: "xx",
                                          port: "xx",
                                          https: true,
                                          token: "xx",
                                          prettyName: false,
                  //                        updateInterval: "1000",
                                          title: "Shower",
                                          stripName: false,
                                          values: [{
                                            sensor: "sensor.shower",
                                            icons: [{
                                            "default": "shower"
                                            sensor: "timer.water",
                                            icons: [{
                                            "default": "water-pump"
                                          host: "xx",
                                          port: "xx",
                                          https: true,
                                          token: "xx",
                                          prettyName: false,
                                          title: "Namaaz Time",
                                          stripName: false,
                                          values: [{
                                            sensor: "sensor.fajr",
                                            icons: [{
                                            "default": "clock-outline"
                                            sensor: "sensor.zohr",
                                            icons: [{
                                            sensor: "sensor.maghrib",
                                            icons: [{
                          module:         'MMM-UKNationalRail',
                          position:       'bottom_left',
                          header:         'Wealdstone Departures',
                          classes: 'scheduler',
                              module_schedule: {from: '0 9 * * 3', to: '0 18 * * 3' },
                              stationCode:        'HRW',      // CRS code for station
                              app_id:             'xx',         // TransportAPI App ID
                              app_key:            'xx',         // TransportAPI App Key
                              updateInterval: 1 * 60 * 1000,
                              maxResults:         5,          //Optional - Maximum results to display.
                              showOrigin:         false,      //Optional - Show the origin of the train in the table
                                          destination:            'EUS',
                                          to_offset:              'PT02:00:00',
                                          operator:               'LM'
                        module: 'MMM-TFL',
                          updateTime: 600000,
                          modes: ['tube'],
                          lines: 'metropolitan'
                  //  module: "MMM-AssistantMk2",
                  //  position: "bottom_right",
                  //  config: {
                  //   assistantConfig: {
                  //     latitude: 51.508530,
                  //     longitude: -0.076132,
                  //    micConfig: { // put there configuration generated by auto-installer
                  //      sampleRate    : 16000,      // audio sample rate
                  //      threshold     : 0.1,        // silence threshold (rec only)
                  //      thresholdStart: null,       // silence threshold to start recording, overrides threshold (rec only)
                  //      thresholdEnd  : null,       // silence threshold to end recording, overrides threshold (rec only)
                  //      verbose       : false,      // log info to the console. Use this when you want to check mic working or not.
                  //      silence       : 0,
                  //      recorder: "arecord",
                  //      device: "plughw:AK5371",
                  //    responseConfig: {
                  //      useHTML5: true,
                  //      useScreenOutput: true,
                  //      useAudioOutput: true,
                  //      useChime: true,
                  //      timer: 2000,
                  //      myMagicWord: false,
                  //      delay: 0.5
                  ////      playProgram: "mpg321"
                  ////      recorder: "arecord",
                  // //     device: "plughw:AK5371",
                  //    recipes: [ "with-MMM-Hotword.js"],
                  //   module: "MMM-Hotword",
                  //    config: {
                  //      useDisplay: false,
                  //      chimeOnFinish: null,
                  //      recipes: ["with-AMk2v3_smart-mirror.js"],
                  //      mic: {
                  //        recordProgram: "arecord",
                      module: 'newsfeed',
                          feeds: [
                                  title: "BBC News UK",
                                  url: "http://feeds.bbci.co.uk/news/england/rss.xml"
                                  title: "Sky News",
                                  url: "http://feeds.skynews.com/feeds/rss/world.xml"
                          showSourceTitle: true,
                          showPublishDate: true,
                          ignoreOldItems: true,
                          ignoreOlderThan: 50400000,
                  1 Reply Last reply Reply Quote -1
                    @ianperrin hi
                    Did you have a chance to look at my configuration?
                    • N
                      nagaculun
                      Can I configure to display a module dimmed from x to y; but turn off from y to x ?
                        BigDanT
                        Bit of a random question!
                        Is there anyways to use your module to turn off another module if the Raspberrypi PIR detects motion ?
                        What im thinking is using an image module to turn the mirror into a digital picture frame.
                        But when the pir sees someone step up to the mirror, it turns off the image module so the no images are displayed and its a simple mirror.
                        Someone walks away and the image module is restarted turning the mirror back into a digital picuture frame ?
                        Cheers
                        D
                        • 5 / 5
