    Help with font size please.
    8 Posts 3 Posters 7.6k Views 3 Watching
      soqueen
      Hi there! I am building a triple monitor/pi MM system that will go on my living room wall as a family command center. I have it almost entirely up and running (just building the frame now) but when I put it up on the wall, the font is small and this causes us not to be able to read it. Is there a way to set a universally larger font (perhaps in the config.js file) so that everything is larger and we can see it from the middle of the room?
      1 Reply Last reply Reply Quote -1
        soqueen
        I have tried adding a custom font size into the magicmirror custom.css - nothing changed.
        I then went into each css file for each module that I wanted to be larger and if it had a font status, i changed it to be 100% (just to see if it worked) and nothing… and -yes, i rebooted the MM after each change. nothing… :( (also - I am running these on 21" monitors)
          soqueen
          Ah! Ok - sorry for a whole thread… I fixed my own problem by modifying the main.css file instead. :)
            ALombardi
            So which aspects did you change? I plan on doing a monitor at the top of a full-body length mirror.
            I want the text to be smaller than it currently is. Which values should I change?
              soqueen
              :) I changed the main.css file. I can tell you what I did to make the font way bigger…
              I changed font size (currently says 2em)
              and line-height (currently 1.5em)
              and then under the .xsmall .small, etc I upped each value by 5
              If you want to go smaller - then try making each of those values smaller…
                ALombardi
                Were you able to remove the gaps along the border?
                I disabled overscan so it fits to the entire screen, but I still seem to have margins along the side and cannot figure out where to change that. I’ve modified (what I thought) was the proper values but it doesn’t seem to resolve it.
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @ALombardi
                  @ALombardi custom.css
                  body {
                      margin: 0px;
                      width: 100%;
                      height: 100%;
                    ALombardi @strawberry 3.141
