    NPM start, starts but with blank screen
    21 Posts 2 Posters 9.4k Views 2 Watching
      sdetweil @natebrown
      @natebrown
      looks like there are two problems
      [2020-10-18 12:12:30.530] [ERROR] ERROR! Could not find main module js file for MMM-GoogleAssistant
      MMM-GooogleAssistant.js is not in MagicMirror/modules/MMM-GoogleAssistant folder
      [2020-10-18 12:12:44.270] [LOG] Refreshed access token because it has expired. Expired at: 12:12:42 now is: 12:12:44
      [2020-10-18 12:12:44.455] [LOG] Email notifier error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      something wrong with your email module
      N 1 Reply Last reply
      • N
        natebrown @sdetweil
        What about this part:
        [2020-10-18 12:12:44.535] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-10-18 12:12:44.538] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-10-18 12:12:44.564] [LOG] Email notifier error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        at doWrite (_stream_writable.js:413:19)
        at clearBuffer (_stream_writable.js:543:7)
        at Socket.Writable.uncork (_stream_writable.js:321:7)
        at JSStreamSocket.doWrite (internal/js_stream_socket.js:162:17)
        at JSStream.onwrite (internal/js_stream_socket.js:20:57)
        at Socket.ondata (internal/js_stream_socket.js:64:22)
        at Socket.emit (events.js:200:13)
        at addChunk (_stream_readable.js:294:12)
        at readableAddChunk (_stream_readable.js:275:11)
        at Socket.Readable.push (_stream_readable.js:210:10) {
        source: ‘socket’
        • N
          natebrown @natebrown
          @natebrown and this one:
          [2020-10-18 12:12:43.003] [ERROR] (node:25630) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            sdetweil @natebrown
            @natebrown said in NPM start, starts but with blank screen:
            DeprecationWarning:
            just a warning that some code (not ours) is using a library call that is going away sometime in the future
            • N
              natebrown @sdetweil
              @sdetweil Thanks, also when i start up my Pi, it shows the “Raspberry Pi OS” Screen and I want it to be just black and how do I speed up autostart (I use sh).
                sdetweil @natebrown
                @natebrown if u had used the scripted install, it would have asked if u want to use the node process manager, pm to start at boot
                u can add it, see command for fixuppm2 here
                speed up? no idea
                • N
                  natebrown @sdetweil
                  @sdetweil 1st: Do i execute it in the MagicMirror folder and once its installed what do I do? And will it effect anything on MagicMirror?
                  S 3 Replies Last reply
                    sdetweil @natebrown
                    @natebrown the scripts don’t care, they adjust.
                    this script changes the installers/mm.sh
                      sdetweil @natebrown
                      @natebrown once it is installed. on next boot mm will start. if it fails pm2 will restart it. if you ctrl-q, pm2 will restart it.
                      minimize and use the pm2 command to stop, start, restart, view logs…
                      see pm2 --help
                        sdetweil @natebrown
                        @natebrown and turn off your sh script, else u will have two starting
                        • N
                          natebrown @sdetweil
                          @sdetweil how do i turn it off? ive just statted up my pi and magicmirror hasnt started.
                          S 2 Replies Last reply
                            sdetweil @natebrown
                            @natebrown pm2 stop 0
                            pm2 delete 0
                            pm2 save
                              sdetweil @natebrown
                              @natebrown pm2 logs --lines=50
                              • N
                                natebrown
                                @sdetweil said in NPM start, starts but with blank screen:
                                pm2 stop 0
                                pm2 delete 0
                                pm2 save
                                oh ok thanks. im also still getting the splashscreen on boot
                                  sdetweil @natebrown
                                  @natebrown there is a step during scripted install to add the mm splash screen.
                                  • N
                                    natebrown @sdetweil
                                    @sdetweil oh.now ive installed your scripts but now the autostart is not working, I’ve deleted all the pm2 things and it is still not working.
                                      sdetweil @natebrown
                                      @natebrown u don’t install my scripts. u use the scripts to do the different tasks
                                      each command is a cut and paste to execute.
