    MM freeze over night
    freezewificlean
    6 Posts 3 Posters 2.4k Views 3 Watching
      MajorC Project Sponsor
      I now have a clean OS installation and a clean MM installation. Stopped MM with
      pm2 stop MagicMirror
      and see, what it is doing over night.
      • FoziF Offline
        Fozi Project Sponsor @MajorC
        @MajorC which modules are you running? I had that with conflicting modules and activated one by one to find the culprit. It was a Google maps module in my case.
          MajorC Project Sponsor @Fozi
          @Fozi
          Good morning, with a clean OS and a clean but stopped MagicMirror my Raspberry ran for 48h without any freeze or wifi problem or what so ever. Even after the 48h I could access the OS via SSH.
          Now I rebooted the system, MagicMirror with only the default modules without any changes are running. Let’s see what is in the log’s after 48h.
          I am still looking for help, where I can find the right logs to look into.
          Thank you.
          • T Offline
            Tribun @MajorC
            @MajorC pm2 Logs can be found @
            /home/pi/.pm2/logs
            npm Logs @
            /home/pi/.npm/_logs
            different system logs @
            /var/log
            you can install the following module for better logging:
            https://github.com/shbatm/MMM-Logging
              My MM was running now for 48h without freezing. I don’t know what happened the last couple of times. Thank you to @Tribun ! I checked all the logs and found no problem. I will now start to install the first modules and see what’s going on.
