    Problems with calendar
    5 Posts 2 Posters 335 Views 2 Watching
      jwaschit
      All calendars that I have tested show “loading”, but no calendar entry is shown.
      my config.js
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/home/pi/MagicMirror/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      /*	ipWhitelist: ["192.168.1.5", "::ffff:192.168.1.5", "::1"], 	// Set [] to allow all IP addresses */
      	ipWhitelist: [],
      	language: "de",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
                  position: "top_left",   // This can be any of the regions. Best results in left or right regions.
                      maximumNumberOfDays: 28,
                      maximumEntries: 10,
      						symbol: "calendar-check",
      						url: "http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      .pm2 log:
      > magicmirror@2.13.0 start /home/pi/MagicMirror
      [2020-11-16 16:48:10.759] [LOG]    Starting MagicMirror: v2.13.0
      [2020-11-16 16:48:10.807] [LOG]    Loading config ...
      [2020-11-16 16:48:10.819] [LOG]    Loading module helpers ...
      [2020-11-16 16:48:10.824] [LOG]    No helper found for module: alert.
      [2020-11-16 16:48:10.951] [LOG]    Initializing new module helper ...
      [2020-11-16 16:48:10.952] [LOG]    Module helper loaded: updatenotification
      [2020-11-16 16:48:10.955] [LOG]    No helper found for module: clock.
      [2020-11-16 16:48:12.121] [LOG]    Initializing new module helper ...
      [2020-11-16 16:48:12.122] [LOG]    Module helper loaded: calendar
      [2020-11-16 16:48:12.123] [LOG]    All module helpers loaded.
      [2020-11-16 16:48:12.445] [LOG]    Starting server on port 8080 ...
      [2020-11-16 16:48:12.481] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [2020-11-16 16:48:12.496] [LOG]    Server started ...
      [2020-11-16 16:48:12.497] [LOG]    Connecting socket for: updatenotification
      [2020-11-16 16:48:12.498] [LOG]    Connecting socket for: calendar
      [2020-11-16 16:48:12.499] [LOG]    Starting node helper for: calendar
      [2020-11-16 16:48:12.500] [LOG]    Sockets connected & modules started ...
      [2020-11-16 16:48:13.056] [LOG]    Launching application.
      I can’t see any create fetcher message at all.
      Thanks a lot for any support.
        sdetweil @jwaschit
        @jwaschit should be after launching application, from a test I did this morning
        [2020-11-16 10:04:21.032] [LOG]    Starting MagicMirror: v2.14.0-develop
        [2020-11-16 10:04:21.034] [LOG]    Loading config ...
        [2020-11-16 10:04:21.036] [LOG]    Loading module helpers ...
        [2020-11-16 10:04:21.036] [LOG]    No helper found for module: alert.
        [2020-11-16 10:04:21.049] [LOG]    Initializing new module helper ...
        [2020-11-16 10:04:21.049] [LOG]    Module helper loaded: updatenotification
        [2020-11-16 10:04:21.050] [LOG]    No helper found for module: clock.
        [2020-11-16 10:04:21.170] [LOG]    Initializing new module helper ...
        [2020-11-16 10:04:21.170] [LOG]    Module helper loaded: calendar
        [2020-11-16 10:04:21.170] [LOG]    No helper found for module: compliments.
        [2020-11-16 10:04:21.170] [LOG]    No helper found for module: currentweather.
        [2020-11-16 10:04:21.170] [LOG]    No helper found for module: weatherforecast.
        [2020-11-16 10:04:21.177] [LOG]    Initializing new module helper ...
        [2020-11-16 10:04:21.177] [LOG]    Module helper loaded: newsfeed
        [2020-11-16 10:04:21.177] [LOG]    All module helpers loaded.
        [2020-11-16 10:04:21.209] [LOG]    Starting server on port 8090 ...
        [2020-11-16 10:04:21.213] [LOG]    Server started ...
        [2020-11-16 10:04:21.213] [LOG]    Connecting socket for: updatenotification
        [2020-11-16 10:04:21.213] [LOG]    Connecting socket for: calendar
        [2020-11-16 10:04:21.214] [LOG]    Starting node helper for: calendar
        [2020-11-16 10:04:21.214] [LOG]    Connecting socket for: newsfeed
        [2020-11-16 10:04:21.214] [LOG]    Starting node helper for: newsfeed
        [2020-11-16 10:04:21.214] [LOG]    Sockets connected & modules started ...
        [2020-11-16 10:04:21.272] [LOG]    Launching application.
        [2020-11-16 10:04:21.800] [LOG]    Create new calendar fetcher for url: http://localhost:8090/modules/default/calendar/calendar.ics - Interval: 300000
        [2020-11-16 10:04:21.809] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          jwaschit
          Launching application is the last message in my log, there is no Create new xxx fetcher message at all.
          just a test with config.js.sample:
          [2020-11-16 20:21:35.961] [LOG]    Starting MagicMirror: v2.13.0
          [2020-11-16 20:21:35.973] [LOG]    Loading config ...
          [2020-11-16 20:21:35.982] [LOG]    Loading module helpers ...
          [2020-11-16 20:21:35.985] [LOG]    No helper found for module: alert.
          [2020-11-16 20:21:36.071] [LOG]    Initializing new module helper ...
          [2020-11-16 20:21:36.072] [LOG]    Module helper loaded: updatenotification
          [2020-11-16 20:21:36.073] [LOG]    No helper found for module: clock.
          [2020-11-16 20:21:36.758] [LOG]    Initializing new module helper ...
          [2020-11-16 20:21:36.759] [LOG]    Module helper loaded: calendar
          [2020-11-16 20:21:36.761] [LOG]    No helper found for module: compliments.
          [2020-11-16 20:21:36.763] [LOG]    No helper found for module: currentweather.
          [2020-11-16 20:21:36.764] [LOG]    No helper found for module: weatherforecast.
          [2020-11-16 20:21:36.831] [LOG]    Initializing new module helper ...
          [2020-11-16 20:21:36.831] [LOG]    Module helper loaded: newsfeed
          [2020-11-16 20:21:36.832] [LOG]    All module helpers loaded.
          [2020-11-16 20:21:37.020] [LOG]    Starting server on port 8080 ...
          [2020-11-16 20:21:37.046] [LOG]    Server started ...
          [2020-11-16 20:21:37.048] [LOG]    Connecting socket for: updatenotification
          [2020-11-16 20:21:37.050] [LOG]    Connecting socket for: calendar
          [2020-11-16 20:21:37.052] [LOG]    Starting node helper for: calendar
          [2020-11-16 20:21:37.054] [LOG]    Connecting socket for: newsfeed
          [2020-11-16 20:21:37.057] [LOG]    Starting node helper for: newsfeed
          [2020-11-16 20:21:37.058] [LOG]    Sockets connected & modules started ...
          [2020-11-16 20:21:37.193] [LOG]    Launching application.
            sdetweil @jwaschit
            @jwaschit thats what u are supposed to do, copy the sample to config.js and then modify from there
            I just did that and got
            [2020-11-16 13:28:39.666] [LOG]    No helper found for module: clock.
            [2020-11-16 13:28:39.786] [LOG]    Initializing new module helper ...
            [2020-11-16 13:28:39.786] [LOG]    Module helper loaded: calendar
            [2020-11-16 13:28:39.786] [LOG]    No helper found for module: compliments.
            [2020-11-16 13:28:39.787] [LOG]    No helper found for module: currentweather.
            [2020-11-16 13:28:39.787] [LOG]    No helper found for module: weatherforecast.
            [2020-11-16 13:28:39.793] [LOG]    Initializing new module helper ...
            [2020-11-16 13:28:39.794] [LOG]    Module helper loaded: newsfeed
            [2020-11-16 13:28:39.794] [LOG]    All module helpers loaded.
            [2020-11-16 13:28:39.825] [LOG]    Starting server on port 8090 ...
            [2020-11-16 13:28:39.827] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [2020-11-16 13:28:39.829] [LOG]    Server started ...
            [2020-11-16 13:28:39.829] [LOG]    Connecting socket for: updatenotification
            [2020-11-16 13:28:39.829] [LOG]    Connecting socket for: calendar
            [2020-11-16 13:28:39.829] [LOG]    Starting node helper for: calendar
            [2020-11-16 13:28:39.829] [LOG]    Connecting socket for: newsfeed
            [2020-11-16 13:28:39.830] [LOG]    Starting node helper for: newsfeed
            [2020-11-16 13:28:39.830] [LOG]    Sockets connected & modules started ...
            [2020-11-16 13:28:39.896] [LOG]    Launching application.
            [2020-11-16 13:28:40.521] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            [2020-11-16 13:28:40.530] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [2020-11-16 13:28:40.793] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
            [2020-11-16 13:28:40.908] [INFO]   Calendar-Fetcher: Broadcasting 2 events
            change your basePath back to “/”,
            basePath: “/home/pi/MagicMirror/”,
              jwaschit
              Thats it!!!
              Thanks a lot for your great support.
