    Default Calendar Stopped Showing Recurring Events
    21 Posts 3 Posters 4.2k Views 3 Watching
      BigSky
      I’m using MM 2.13.0 and I’m seeing some weird behavior with the default calendar. I set up a Google calendar this past weekend, configured it in MM using the secret address and it was looking good. Then when I checked it today to tweak the date formatting there were no events showing. I’ve tried everything I can think of and it’s just not loading. I created a new calendar with one test event and loaded it using the secret address, looks good. I then exported this original calendar and imported the events into this new calendar, and no events show up. Not even the test event that was previously working.
      Are there any known issues with the # of events the default calendar can handle? The only thing that’s a bit unique about this calendar is there are a lot (34) of recurring events each day.
      Thanks in advance for any troubleshooting suggestions…
      • AlvingerA Offline
        Alvinger
        There have been a lot of work done by @sdetweil on the calendar module. Try the develop branch which handles recurring events much better.
          sdetweil @BigSky
          @BigSky as suggested. Please get the develop branch.
          See here for instructions
          https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users/2
          Also, be careful. broadcastPastEvents conflicts w number of entries
          Past events are not shown, but count against number of entries
            BigSky
            Thanks for the suggestions, @sdetweil and @Alvinger but switching to the develop branch didn’t resolve the issue just yet. I’m going to create a new calendar and add recurring events one at a time to see if there’s a specific threshold that breaks the module. I’ll post my findings…
              sdetweil @BigSky
              @BigSky can u show one failing vevent from the ics file?
              ics is just text
                @sdetweil also set “DEBUG” in the log levels in config.js and the npm start >somefile to capture the log. Or,
                pm2 flush
                pm2 restart 0
                pm2 logs --lines=200
                  BigSky
                  Thanks for the tip on the log files. I’m actually seeing it sporadically working now. Other times it will say “No more events.” (or similar, I don’t recall exactly), and at other times it will appear to hang with the “Loading…” message. When I look at the log file the thing that jumps out at me is all the data it’s pulling for each recurring event. This calendar has something like 37 short events happening each weekday, and for each event I see the following in the log file (with the calendar URL anonymized). It appears to be pulling a full year of future events which may just be too much?
                  [2020-11-25 12:36:13.418] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/MYCALENDARNAME.ics - Interval: 300000
                  [2020-11-25 12:36:27.689] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/sport/formula1/rss.xml - Interval: 300000
                   start=Thu Sep 03 2020 08:55:00 GMT-0600 (Mountain Daylight Time) end=Thu Sep 03 2020 09:40:00 GMT-0600 (Mountain Daylight Time)
                   between=Tue Nov 24 2020 17:00:00 GMT-0700 (Mountain Standard Time) to Wed Nov 24 2021 16:59:59 GMT-0700 (Mountain Standard Time)
                  title=Academic Time dates=["2020-11-25T14:55:00.000Z","2020-11-26T14:55:00.000Z","2020-11-27T14:55:00.000Z","2020-11-30T14:55:00.000Z","2020-12-01T14:55:00.000Z","2020-12-02T14:55:00.000Z","2020-12-03T14:55:00.000Z","2020-12-04T14:55:00.000Z","2020-12-07T14:55:00.000Z","2020-12-08T14:55:00.000Z","2020-12-09T14:55:00.000Z","2020-12-10T14:55:00.000Z","2020-12-11T14:55:00.000Z","2020-12-14T14:55:00.000Z","2020-12-15T14:55:00.000Z","2020-12-16T14:55:00.000Z","2020-12-17T14:55:00.000Z","2020-12-18T14:55:00.000Z","2020-12-21T14:55:00.000Z","2020-12-22T14:55:00.000Z","2020-12-23T14:55:00.000Z","2020-12-24T14:55:00.000Z","2020-12-25T14:55:00.000Z","2020-12-28T14:55:00.000Z","2020-12-29T14:55:00.000Z","2020-12-30T14:55:00.000Z","2020-12-31T14:55:00.000Z","2021-01-01T14:55:00.000Z","2021-01-04T14:55:00.000Z","2021-01-05T14:55:00.000Z","2021-01-06T14:55:00.000Z","2021-01-07T14:55:00.000Z","2021-01-08T14:55:00.000Z","2021-01-11T14:55:00.000Z","2021-01-12T14:55:00.000Z","2021-01-13T14:55:00.000Z","2021-01-14T14:55:00.000Z","2021-01-15T14:55:00.000Z","2021-01-18T14:55:00.000Z","2021-01-19T14:55:00.000Z","2021-01-20T14:55:00.000Z","2021-01-21T14:55:00.000Z","2021-01-22T14:55:00.000Z","2021-01-25T14:55:00.000Z","2021-01-26T14:55:00.000Z","2021-01-27T14:55:00.000Z","2021-01-28T14:55:00.000Z","2021-01-29T14:55:00.000Z","2021-02-01T14:55:00.000Z","2021-02-02T14:55:00.000Z","2021-02-03T14:55:00.000Z","2021-02-04T14:55:00.000Z","2021-02-05T14:55:00.000Z","2021-02-08T14:55:00.000Z","2021-02-09T14:55:00.000Z","2021-02-10T14:55:00.000Z","2021-02-11T14:55:00.000Z","2021-02-12T14:55:00.000Z","2021-02-15T14:55:00.000Z","2021-02-16T14:55:00.000Z","2021-02-17T14:55:00.000Z","2021-02-18T14:55:00.000Z","2021-02-19T14:55:00.000Z","2021-02-22T14:55:00.000Z","2021-02-23T14:55:00.000Z","2021-02-24T14:55:00.000Z","2021-02-25T14:55:00.000Z","2021-02-26T14:55:00.000Z","2021-03-01T14:55:00.000Z","2021-03-02T14:55:00.000Z","2021-03-03T14:55:00.000Z","2021-03-04T14:55:00.000Z","2021-03-05T14:55:00.000Z","2021-03-08T14:55:00.000Z","2021-03-09T14:55:00.000Z","2021-03-10T14:55:00.000Z","2021-03-11T14:55:00.000Z","2021-03-12T14:55:00.000Z","2021-03-15T14:55:00.000Z","2021-03-16T14:55:00.000Z","2021-03-17T14:55:00.000Z","2021-03-18T14:55:00.000Z","2021-03-19T14:55:00.000Z","2021-03-22T14:55:00.000Z","2021-03-23T14:55:00.000Z","2021-03-24T14:55:00.000Z","2021-03-25T14:55:00.000Z","2021-03-26T14:55:00.000Z","2021-03-29T14:55:00.000Z","2021-03-30T14:55:00.000Z","2021-03-31T14:55:00.000Z","2021-04-01T14:55:00.000Z","2021-04-02T14:55:00.000Z","2021-04-05T14:55:00.000Z","2021-04-06T14:55:00.000Z","2021-04-07T14:55:00.000Z","2021-04-08T14:55:00.000Z","2021-04-09T14:55:00.000Z","2021-04-12T14:55:00.000Z","2021-04-13T14:55:00.000Z","2021-04-14T14:55:00.000Z","2021-04-15T14:55:00.000Z","2021-04-16T14:55:00.000Z","2021-04-19T14:55:00.000Z","2021-04-20T14:55:00.000Z","2021-04-21T14:55:00.000Z","2021-04-22T14:55:00.000Z","2021-04-23T14:55:00.000Z","2021-04-26T14:55:00.000Z","2021-04-27T14:55:00.000Z","2021-04-28T14:55:00.000Z","2021-04-29T14:55:00.000Z","2021-04-30T14:55:00.000Z","2021-05-03T14:55:00.000Z","2021-05-04T14:55:00.000Z","2021-05-05T14:55:00.000Z","2021-05-06T14:55:00.000Z","2021-05-07T14:55:00.000Z","2021-05-10T14:55:00.000Z","2021-05-11T14:55:00.000Z","2021-05-12T14:55:00.000Z","2021-05-13T14:55:00.000Z","2021-05-14T14:55:00.000Z","2021-05-17T14:55:00.000Z","2021-05-18T14:55:00.000Z","2021-05-19T14:55:00.000Z","2021-05-20T14:55:00.000Z","2021-05-21T14:55:00.000Z","2021-05-24T14:55:00.000Z","2021-05-25T14:55:00.000Z","2021-05-26T14:55:00.000Z","2021-05-27T14:55:00.000Z","2021-05-28T14:55:00.000Z","2021-05-31T14:55:00.000Z","2021-06-01T14:55:00.000Z","2021-06-02T14:55:00.000Z","2021-06-03T14:55:00.000Z","2021-06-04T14:55:00.000Z","2021-06-07T14:55:00.000Z","2021-06-08T14:55:00.000Z","2021-06-09T14:55:00.000Z","2021-06-10T14:55:00.000Z","2021-06-11T14:55:00.000Z","2021-06-14T14:55:00.000Z","2021-06-15T14:55:00.000Z","2021-06-16T14:55:00.000Z","2021-06-17T14:55:00.000Z","2021-06-18T14:55:00.000Z","2021-06-21T14:55:00.000Z","2021-06-22T14:55:00.000Z","2021-06-23T14:55:00.000Z","2021-06-24T14:55:00.000Z","2021-06-25T14:55:00.000Z","2021-06-28T14:55:00.000Z","2021-06-29T14:55:00.000Z","2021-06-30T14:55:00.000Z","2021-07-01T14:55:00.000Z","2021-07-02T14:55:00.000Z","2021-07-05T14:55:00.000Z","2021-07-06T14:55:00.000Z","2021-07-07T14:55:00.000Z","2021-07-08T14:55:00.000Z","2021-07-09T14:55:00.000Z","2021-07-12T14:55:00.000Z","2021-07-13T14:55:00.000Z","2021-07-14T14:55:00.000Z","2021-07-15T14:55:00.000Z","2021-07-16T14:55:00.000Z","2021-07-19T14:55:00.000Z","2021-07-20T14:55:00.000Z","2021-07-21T14:55:00.000Z","2021-07-22T14:55:00.000Z","2021-07-23T14:55:00.000Z","2021-07-26T14:55:00.000Z","2021-07-27T14:55:00.000Z","2021-07-28T14:55:00.000Z","2021-07-29T14:55:00.000Z","2021-07-30T14:55:00.000Z","2021-08-02T14:55:00.000Z","2021-08-03T14:55:00.000Z","2021-08-04T14:55:00.000Z","2021-08-05T14:55:00.000Z","2021-08-06T14:55:00.000Z","2021-08-09T14:55:00.000Z","2021-08-10T14:55:00.000Z","2021-08-11T14:55:00.000Z","2021-08-12T14:55:00.000Z","2021-08-13T14:55:00.000Z","2021-08-16T14:55:00.000Z","2021-08-17T14:55:00.000Z","2021-08-18T14:55:00.000Z","2021-08-19T14:55:00.000Z","2021-08-20T14:55:00.000Z","2021-08-23T14:55:00.000Z","2021-08-24T14:55:00.000Z","2021-08-25T14:55:00.000Z","2021-08-26T14:55:00.000Z","2021-08-27T14:55:00.000Z","2021-08-30T14:55:00.000Z","2021-08-31T14:55:00.000Z","2021-09-01T14:55:00.000Z","2021-09-02T14:55:00.000Z","2021-09-03T14:55:00.000Z","2021-09-06T14:55:00.000Z","2021-09-07T14:55:00.000Z","2021-09-08T14:55:00.000Z","2021-09-09T14:55:00.000Z","2021-09-10T14:55:00.000Z","2021-09-13T14:55:00.000Z","2021-09-14T14:55:00.000Z","2021-09-15T14:55:00.000Z","2021-09-16T14:55:00.000Z","2021-09-17T14:55:00.000Z","2021-09-20T14:55:00.000Z","2021-09-21T14:55:00.000Z","2021-09-22T14:55:00.000Z","2021-09-23T14:55:00.000Z","2021-09-24T14:55:00.000Z","2021-09-27T14:55:00.000Z","2021-09-28T14:55:00.000Z","2021-09-29T14:55:00.000Z","2021-09-30T14:55:00.000Z","2021-10-01T14:55:00.000Z","2021-10-04T14:55:00.000Z","2021-10-05T14:55:00.000Z","2021-10-06T14:55:00.000Z","2021-10-07T14:55:00.000Z","2021-10-08T14:55:00.000Z","2021-10-11T14:55:00.000Z","2021-10-12T14:55:00.000Z","2021-10-13T14:55:00.000Z","2021-10-14T14:55:00.000Z","2021-10-15T14:55:00.000Z","2021-10-18T14:55:00.000Z","2021-10-19T14:55:00.000Z","2021-10-20T14:55:00.000Z","2021-10-21T14:55:00.000Z","2021-10-22T14:55:00.000Z","2021-10-25T14:55:00.000Z","2021-10-26T14:55:00.000Z","2021-10-27T14:55:00.000Z","2021-10-28T14:55:00.000Z","2021-10-29T14:55:00.000Z","2021-11-01T14:55:00.000Z","2021-11-02T14:55:00.000Z","2021-11-03T14:55:00.000Z","2021-11-04T14:55:00.000Z","2021-11-05T14:55:00.000Z","2021-11-08T14:55:00.000Z","2021-11-09T14:55:00.000Z","2021-11-10T14:55:00.000Z","2021-11-11T14:55:00.000Z","2021-11-12T14:55:00.000Z","2021-11-15T14:55:00.000Z","2021-11-16T14:55:00.000Z","2021-11-17T14:55:00.000Z","2021-11-18T14:55:00.000Z","2021-11-19T14:55:00.000Z","2021-11-22T14:55:00.000Z","2021-11-23T14:55:00.000Z","2021-11-24T14:55:00.000Z"]
                  initial tz=America/Denver
                  corrected tz=America/Denver
                  start date/time=Thu Sep 03 2020 08:55:00 GMT-0600 (Mountain Daylight Time)
                  start offset=-360
                  start date/time w tz =Thu Sep 03 2020 08:55:00 GMT-0600 (Mountain Daylight Time)
                  event date=Wed Nov 25 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  event offset=-420 hour=7 event date=Wed Nov 25 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  offset
                  adjust up 1 hour dst change
                  adjustHours=1
                  duration=2700000
                  start offset=-360
                  event date=Thu Nov 26 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  event offset=-420 hour=7 event date=Thu Nov 26 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  offset
                  adjustHours=1
                  duration=2700000
                  start offset=-360
                  event date=Fri Nov 27 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  event offset=-420 hour=7 event date=Fri Nov 27 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  offset
                  adjustHours=1
                  duration=2700000
                  start offset=-360
                  event date=Mon Nov 30 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  event offset=-420 hour=7 event date=Mon Nov 30 2020 07:55:00 GMT-0700 (Mountain Standard Time)
                  offset
                  adjustHours=1
                  duration=2700000
                  AlvingerA 1 Reply Last reply Reply Quote 0
                  • AlvingerA Offline
                    Alvinger @BigSky
                    @BigSky You can limit the number of days in the future by setting the parameter maximumNumberOfDays to something like 30 which will fetch events occuring within the next month.
                      BigSky @Alvinger
                      @Alvinger Ugh. Of course. I knew that. Limiting it to 3 days prevents it from hanging but it’s still saying “No upcoming events” when there should be.
                      Below is the beginning and the end of the log file - it looks like some of these events should be displaying.
                      > magicmirror@2.14.0-develop start /home/pi/MagicMirror
                      [2020-11-25 13:47:38.222] [LOG]    Starting MagicMirror: v2.14.0-develop
                      [2020-11-25 13:47:38.248] [LOG]    Loading config ...
                      [2020-11-25 13:47:38.259] [LOG]    Loading module helpers ...
                      [2020-11-25 13:47:38.267] [LOG]    No helper found for module: alert.
                      [2020-11-25 13:47:38.556] [LOG]    Initializing new module helper ...
                      [2020-11-25 13:47:38.559] [LOG]    Module helper loaded: updatenotification
                      [2020-11-25 13:47:38.563] [LOG]    No helper found for module: clock.
                      [2020-11-25 13:47:39.427] [LOG]    Initializing new module helper ...
                      [2020-11-25 13:47:39.429] [LOG]    Module helper loaded: calendar
                      [2020-11-25 13:47:39.432] [LOG]    No helper found for module: currentweather.
                      [2020-11-25 13:47:39.434] [LOG]    No helper found for module: weatherforecast.
                      [2020-11-25 13:47:39.479] [LOG]    Initializing new module helper ...
                      [2020-11-25 13:47:39.480] [LOG]    Module helper loaded: newsfeed
                      [2020-11-25 13:47:39.481] [LOG]    All module helpers loaded.
                      [2020-11-25 13:47:39.686] [LOG]    Starting server on port 8080 ...
                      [2020-11-25 13:47:39.715] [LOG]    Server started ...
                      [2020-11-25 13:47:39.717] [LOG]    Connecting socket for: updatenotification
                      [2020-11-25 13:47:39.718] [LOG]    Connecting socket for: calendar
                      [2020-11-25 13:47:39.719] [LOG]    Starting node helper for: calendar
                      [2020-11-25 13:47:39.720] [LOG]    Connecting socket for: newsfeed
                      [2020-11-25 13:47:39.721] [LOG]    Starting node helper for: newsfeed
                      [2020-11-25 13:47:39.723] [LOG]    Sockets connected & modules started ...
                      [2020-11-25 13:47:40.178] [LOG]    Launching application.
                      [2020-11-25 13:47:44.284] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/MYCALENDARURLHERE/basic.ics - Interval: 300000
                      [2020-11-25 13:47:44.451] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/sport/formula1/rss.xml - Interval: 300000
                      [2020-11-25 13:47:44.788] [INFO]   Newsfeed-Fetcher: Broadcasting 12 items.
                       between=Tue Nov 24 2020 17:00:00 GMT-0700 (Mountain Standard Time) to Fri Nov 27 2020 16:59:59 GMT-0700 (Mountain Standard Time)
                      title=Academic Time dates=["2020-11-25T14:55:00.000Z","2020-11-26T14:55:00.000Z","2020-11-27T14:55:00.000Z"]
                      start offset=-360
                      offset
                      adjustHours=1
                      duration=2700000
                      start date/time=Thu Sep 03 2020 09:40:00 GMT-0600 (Mountain Daylight Time)
                      start offset=-360
                      start date/time w tz =Thu Sep 03 2020 09:40:00 GMT-0600 (Mountain Daylight Time)
                      event date=Thu Nov 26 2020 08:40:00 GMT-0700 (Mountain Standard Time)
                      event offset=-420 hour=8 event date=Thu Nov 26 2020 08:40:00 GMT-0700 (Mountain Standard Time)
                      offset
                      adjustHours=1
                      duration=600000
                      start offset=-360
                      event date=Fri Nov 27 2020 08:40:00 GMT-0700 (Mountain Standard Time)
                      event offset=-420 hour=8 event date=Fri Nov 27 2020 08:40:00 GMT-0700 (Mountain Standard Time)
                      offset
                      adjustHours=1
                      duration=600000
                      [2020-11-25 13:47:47.798] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
                      [2020-11-25 13:47:56.453] [LOG]    Shutting down server...
                      [2020-11-25 13:47:56.456] [LOG]    Stopping module helper: updatenotification
                      [2020-11-25 13:47:56.464] [LOG]    Stopping module helper: calendar
                      [2020-11-25 13:47:56.469] [LOG]    Stopping module helper: newsfeed
                      AlvingerA S 2 Replies Last reply Reply Quote 0
                      • AlvingerA Offline
                        Alvinger @BigSky
                        @BigSky I know, recurring events is not where the calendar module really shines…
                        There is work ongoing to address as many issues as possible. Could you provide an ICS-file that can be used for testing the above?
