    MMM-PIR-Sensor Off on Music
    1 Posts 1 Posters 195 Views 1 Watching
      MrTroya
      Hello everyone, I am using the MMM-PIR Sensor module (https://github.com/paviro/MMM-PIR-Sensor), so far everything works perfect, except that I also take advantage of the HDMI output of my Raspberry pi zero w to get audio, when it does not detect movement and the sensor turns off the HDMI output, the audio is also cut, is there any way to tell the module that if any sound is playing, you should ignore the HDMI shutdown by time? Thank you very much for your help.
