    Problems with MMM-ModuleScheduler
    7 Posts 2 Posters 1.8k Views 2 Watching
    • Sandy2503S Offline
      Sandy2503
      Hi there,
      I have a problem with the module MMM-ModuleScheduler on my new Reaspberrys PI 4
      I crated my Mirror no a Pi3 with a working config.js.
      Now on the PI4 i creaded the Mirror with a fresh raspian buster os and a fresh Mirror (V2.11) and all my favrorit modules. Everything works fine but …
      When i use the Module MMM-ModuleScheduler and i disable the Screen in the power interface with the option “Turn monitor OFF” it works very well, but “Turn monitor ON” wont work. The Display stays blank.
      The same problem in my config.js
            module: 'MMM-ModuleScheduler',
            header: '',
              notification_schedule: [
                  notification: 'REMOTE_ACTION',
                  schedule: '00 5 * * *',
                  payload: {
                    action: 'MONITORON'
                  schedule: '30 22 * * *',
                  payload: {
                    action: 'MONITOROFF'
                  schedule: '0 4 * * SUN',
                  payload: {
                    action: 'RESTART'
      On my Pi 3 it works very well. but on the Pi4 the Display switch to “Blank Screen” but doesn`t wake up.
      Has anyone a hit oder fix for me ???
      Best Regards,
      Sandy2503
        sdetweil @Sandy2503
        @Sandy2503 yes. This has been reported before. Don’t rember the solution. Change command as I recall
          Sandy2503
          @sdetweil - i don`t remember …
            sdetweil @Sandy2503
            @Sandy2503 a little search does wonders
            https://forum.magicmirror.builders/topic/9257/mmm-remote-control-fix-monitor-on-off-tvservice-vcgencmd?_=1607200718668
              Sandy2503
              thanks for the fast replay - i have searched but i havn`t found this post .
              I will test it tomorrow.
              Best Regards
                Sandy2503
                @sdetweil - the fix thems to be for the old Version 1.x of RemoteControl & Scheduler.
                In my node_helper.js i find NO entrys like the posted from the link. :-(
                Best Regards
                  sdetweil @Sandy2503
                  @Sandy2503 well, they are there
                          monitorControl: function(action, opts, res) {
                              let status = "unknown";
                              let offArr = ["false","TV is Off","standby"];
                              let monitorOnCommand = (this.initialized && "monitorOnCommand" in this.thisConfig.customCommand) ?
                                  this.thisConfig.customCommand.monitorOnCommand :
                                  "tvservice --preferred && sudo chvt 6 && sudo chvt 7";
                              let monitorOffCommand = (this.initialized && "monitorOffCommand" in this.thisConfig.customCommand) ?
                                  this.thisConfig.customCommand.monitorOffCommand :
                                  "tvservice -o";
                              let monitorStatusCommand = (this.initialized && "monitorStatusCommand" in this.thisConfig.customCommand) ?
                                  this.thisConfig.customCommand.monitorStatusCommand :
                                  "tvservice --status";
                  just not in the same form…
                  also, the doc describes how to specify different ones without changing the code
                  https://github.com/Jopyth/MMM-Remote-Control#using-custom-commands
