    Help with puppeteer ,cheerio and json
    9 Posts 2 Posters 1.1k Views 2 Watching
    • L Offline
      lolo
      Thanks for replay.
      I believe, I dint explained well.
      This is table from website. Screenshot.
      The data what i menage to collect is from prev sibling of tr class tableRow.
      What i wish to get is tr class datum as first date and then data of street, street number, time (all in span) as data object in array, till next tr datum and then same after.
      For each span id is different but they sharing same part of one number in id.
      I cant use for for each as element (td or tr) as plenty of them are useless.
      And here I’m stuck. I tried different approaches but then all data was multiplying or got empty object in arrays
      example from website
        sdetweil @lolo
        @lolo but u have the date already in the object. Sort them maybe, but cheerio should return the list in order.
        • L Offline
          lolo
          Yes I’m getting date , but this one is endWork (kraj). When the interruption will end, not to start. I know maybe I should use that.
          • L Offline
            lolo
            I think i managed to sort it out.
            	const $ = cheerio.load(html);
            	var water = [];
                    var waterList = [];
                    var el = $('#cphContent_cphSadrzaj_upVoda table tbody ');
            	if (el) {
                           var elementWater = $('#cphContent_cphSadrzaj_upVoda table tbody  span').filter(function () {
                              return $(this).text() === self.place;
                               }).parent().parent();
                         $(elementWater).each(function (jex, edate) {
                        const $edate = $(edate);
                        var startDate = $edate.prev().find('tr[class="datum"]>th>div').text().trim();
                        var street = $edate.find('span[id*="Label2"]').text();
                        var streetNmbr = $edate.find('span[id*="Label7"]').text();
                        var startTime = $edate.find('span[id*="Label8"]').text();
                        var endTime = $edate.find('span[id*="Label9"]').text();
                        var endWork = $edate.find('span[id*="Label10"]').text();
                        var water = {
                            startDate,
                            street,
                            streetNmbr,
                            startTime,
                            endTime,
                            endWork
                        waterList.push(water);
                        console.log(water);
                if (!el) {
                    console.log('No new entries!');
                var waterWork = JSON.parse(JSON.stringify(waterList));
                self.sendSocketNotification('ELECTRIC_POWER_DISCONNECTED', waterWork);
            Now i can get all data sorted by config.place
              startDate: '09.12.2020',
              street: 'ISTARSKA, Rijeka',
              streetNmbr: '64',
              startTime: '10:00',
              endTime: '14:00',
              endWork: '09.12.20'
              sdetweil @lolo
              @lolo cool
              • L Offline
                lolo
                This is output of my module. Any suggestion about styling.
                croatian
                I know there are more things to make it better but i have to learn it first.
                  sdetweil @lolo
                  @lolo i cannot help with look. Totally useless here
