    remotecompliments disappeared - please help
    47 Posts 2 Posters 15.7k Views 2 Watching
    • F Offline
      forjer @sdetweil
      @sdetweil So are you saying I should delete the Token.json file from /home/pi/MagicMirror/modules/MMM-RemoteCompliments/Drive and run node setup which will re-run the Setup.js script?
      • F Offline
        forjer @sdetweil
        @sdetweil I deleted the Token.json file and ran node Setup in the RemoveCompliments/Drive folder and was successful in re-completing the setup (following link, pasting code), but there was no change in function…RemoteCompliments is MIA…no header or anything.
        • F Offline
          forjer
          FWIW, I’m also running the default Compliments in the lower_third position. I’ve swapped positions between Compliements and RemoteCompliments and the result of that is Compliments works in both positions, RemoteCompliments doesn’t work in either position.
            sdetweil @forjer
            @forjer and the pm2 log?
            F 2 Replies Last reply Reply Quote 0
            • F Offline
              forjer @sdetweil
              pi@raspberrypi:~ $ pm2 logs
              /home/pi/.pm2/pm2.log last 15 lines:
              PM2        | 2020-12-28T21:29:05: PM2 log: pid=22698 msg=process killed
              PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-12-28T21:29:50: PM2 log: Stopping app:MagicMirror id:0
              PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=failed to kill - retrying in 100ms
              PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=process killed
              PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] online
              PM2        | 2020-12-28T21:46:00: PM2 log: Stopping app:MagicMirror id:0
              PM2        | 2020-12-28T21:46:00: PM2 log: pid=23422 msg=failed to kill - retrying in 100ms
              PM2        | 2020-12-28T21:46:00: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2        | 2020-12-28T21:46:01: PM2 log: pid=23422 msg=process killed
              PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] online
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              0|MagicMir |
              0|MagicMir | [2020-12-28 21:46:04.542] [LOG]    Starting MagicMirror: v2.13.0
              0|MagicMir | [2020-12-28 21:46:04.557] [LOG]    Loading config ...
              0|MagicMir | [2020-12-28 21:46:04.568] [LOG]    Loading module helpers ...
              0|MagicMir | [2020-12-28 21:46:04.571] [LOG]    No helper found for module: clock.
              0|MagicMir | [2020-12-28 21:46:07.600] [LOG]    Initializing new module helper ...
              0|MagicMir | [2020-12-28 21:46:07.601] [LOG]    Module helper loaded: MMM-RemoteCompliments
              0|MagicMir | [2020-12-28 21:46:07.602] [LOG]    All module helpers loaded.
              0|MagicMir | [2020-12-28 21:46:07.798] [LOG]    Starting server on port 8080 ...
              0|MagicMir | [2020-12-28 21:46:07.819] [LOG]    Server started ...
              0|MagicMir | [2020-12-28 21:46:07.821] [LOG]    Connecting socket for: MMM-RemoteCompliments
              0|MagicMir | [2020-12-28 21:46:07.825] [LOG]    Starting node helper for: MMM-RemoteCompliments
              0|MagicMir | [2020-12-28 21:46:07.826] [LOG]    Sockets connected & modules started ...
              0|MagicMir | [2020-12-28 21:46:07.960] [LOG]    Launching application.
                sdetweil @forjer
                @forjer sorry, I’ve run out of everything to look for. the error is gone now…
                • F Offline
                  forjer @sdetweil
                  @sdetweil In my developer log it mentions “RemoteCompliments: ‘MODULE_DOM_CREATED’ received: null” and “module.js:199 MMM-RemoteCompliments is suspended.” Is that a clue? It just doesn’t make sense. I tested it yesterday morning by putting in a really long compliment just to see how it looked on the screen. I then reverted it back to a short compliment. Later in the morning I did a sudo apt-get update and a sudo apt-get upgradejust before setting up remote desktop, VNC and pitunnel. Those are the only other things that I can think of where I changed some stuff.
                  developers window
                  Load script: modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
                  module.js:513 Module registered: MMM-RemoteCompliments
                  loader.js:148 Bootstrapping module: MMM-RemoteCompliments
                  loader.js:176 Load script: modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
                  loader.js:153 Scripts loaded for: MMM-RemoteCompliments
                  loader.js:155 Styles loaded for: MMM-RemoteCompliments
                  loader.js:157 Translations loaded for: MMM-RemoteCompliments
                  loader.js:195 Load stylesheet: css/custom.css
                  :8080/modules/default/clock//clock.js:46 Starting module: clock
                  main.js:508 All modules started!
                  :8080/modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js:222 MMM-RemoteCompliments: 'MODULE_DOM_CREATED' received:  null
                  Are there any other (perhaps more stable) modules where I can display a custom message (compliment) depending on the time of day? I had about 10 compliments programmed to display at their specified time slots throughout the day. And I liked the ability to control / override them easily with my phone via Google Drive.
                    sdetweil @forjer
                    @forjer the code and comments
                    // Hide module on startup.
                    			// If the module receives data, the module will reveal itself.
                    			self.hide(0);
                    			self.hidden = true;
                    which is reasonable, but it just reinforces no data.
                    sorry no idea on another module that does this other than the default compliments module with remotefile
                    • F Offline
                      forjer @sdetweil
                      @sdetweil Hmm…is there a simple way to hard code in a RemoteCompiment to force it to show? Just as a troubleshooting step to see it?
                      I guess I could consider the default compliments with remote file. Can I run a second default compliment module at the same time? Is it as simple as copying the folders and renaming them “compliments2” or something?
                        sdetweil @forjer
                        @forjer the default compliments module can be used multiple times without problem. you either pass the compliments as config parms or in a remotefile as config parm
                        • F Offline
                          forjer @sdetweil
                          @sdetweil So are you saying I can run two instances of compliments at the same time, shown in two different locations on the same display? And is this done by copying the compliments.js to make a “compliments2.js”?
                            sdetweil @forjer
                            @forjer yes, two instances, no need to copy the module
                            • F Offline
                              forjer
                              @sdetweil I’m sorry, I’m a little slow. And this is making my brain hurt. I really appreciate your patience with me.
                              How would this look in config.js? And how does it know which compliments go in what position of the MM?
                              What I’m after is a normal compliments module running in lower_third, and a second compliments module sliced into 10 time slots with a different set of compliments running in upper_third. I’ve just finished modifying the default compliments.js to get my 10 time slots and that seems to work, so I’m getting closer.
                              S F 2 Replies Last reply Reply Quote 0
                                sdetweil @forjer
                                @forjer modifying?
                                no need to modify ( never modify module source code)
                                code two modules wherever u want.
                                put the compliments text in the config block in config.js
                                I am on my phone so everything but the actual compliments
                                     module:"compliments",
                                     position:"lower_third",
                                     config:{
                                           compliments:{
                                                 same as in defaults section of code
                                                 whatever  compliments for module 1
                                           OR
                                            remotefile:"http://....... somefile on some server"
                                     position:"upper_third",
                                     config:{
                                           compliments:{
                                                 whatever  compliments for module 2
                                • F Offline
                                  forjer @forjer
                                  @sdetweil Progress. So I saved a copy of my modified compliments.js into a compliments2 folder as compliments2.js and renamed module.register to compliments2. I then reverted my compliments.js back to original. I then added a compliments2 section into my config.js. And now I have two separate compliments running! I tried that a few hours ago but I must have done something wrong so it didn’t work.
                                  In the way you coded it, would I be able to have the ability to run Module 1 with the default time slots (complimentArray) while Module 2 runs a different time slot schedule?
                                  Now I think I’d like to get a remotefile set up but I’m guessing I’ll run into some issue with remotefile for my compliments2.
                                  • F Offline
                                    forjer @forjer
                                    @sdetweil Also, is there a way to get my compliments2 to allow time splits at say 11:30 instead of just integer hours? Something like the following?
                                    afternoonStartTime: 11:30,
                                    afternoonEndTime: 13,
                                    It would appear the complimentArray would need to be adjusted by changing “hour” to something else?
                                    } else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
                                    	compliments = this.config.compliments.afternoon.slice(0);
                                    S 3 Replies Last reply Reply Quote 0
                                      sdetweil @forjer
                                      @forjer read the doc
                                      u can have different remotefiles too
                                      https://docs.magicmirror.builders/modules/compliments.html
                                        sdetweil @forjer
                                        @forjer if u need 10 time slots, then the compliments module would need changing as u might already have done. u should change your own copy, and then use that
                                        from the modules folder
                                        cp defaults/compliments mycompliments
                                        have to change the module register at the top to be the same as the folder name u create on the copy
                                          sdetweil @forjer
                                          @forjer looks like the default time slots are hour based. so another reason to make your own
                                          • F Offline
                                            forjer @sdetweil
                                            @sdetweil Thanks for all of you time and help. You are a wealth of knowledge.
                                            I’ve only been digging into this thing for a few weeks and I’ve seen so many of your posts helping others. Kudos!
                                            I like this kind of stuff, I just wish I had better core knowledge so I didn’t spend so much time looking stuff up and tinkering, but I guess that’s one way to learn.
                                            I have gotten my custom “compliments2” module to work, but still only with integers for time. There’s got to be a simple way to change that. I’ll keep looking.
                                            • 2 / 3
